alignment issues rock krawler 2.5 flex - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > alignment issues rock krawler 2.5 flex
Introducing MONSTALINER UV Permanent DIY Roll On Bed LineFree Shipping on Soft ShacklesNew! JK/U skid plate system.
Unread 05-25-2015, 06:27 PM   #1
stinad19
I lifted my wife's jku rubicon 2013 with a rock krawler 2.5 flex kit. It now pulls to the right, 2 different shops say it is due to camber FL -.6 FR-.7 Why would it pull from camber if it didn't before the lift
stinad19 is offline   Reply With Quote Quick reply to this message
Unread 05-25-2015, 06:32 PM   #2
SLADE
Brand new tires with the lift or used tires that got rotated around?
A difference in tread depth (even minimal) can cause a pull one way or another.
Did you change the steering stabilizer?
Some push and make it feel like the steering pulling.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
Unread 05-25-2015, 06:45 PM   #3
stinad19
First shop was with the worn OE tires in the same spots, second shop was with new 35 12.50s. It seams mostly pull right with the slope of the road if I drive on the wrong side of the road it won't pull up the slope. Do I need adjustable ball joints. Also should I push my LCA out a little for my caster.
Unread 05-25-2015, 06:53 PM   #4
SLADE
wheel width and backspacing?
Caster is good at 5.2.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 05-25-2015, 07:04 PM   #5
stinad19
Stock rubicon rims with 1.5" spacers
Unread 05-25-2015, 09:26 PM   #6
rich6700
I'm sure it's not a pull more like a drift. Bigger tires your going to need a better steering stabilizer.
rich6700 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 04:59 PM   #7
fratis
fratis's Avatar
No. If it's set up right you don't even need one for street driving.
-insert meaningless out-of-place political diatribe-
fratis is offline   Reply With Quote Quick reply to this message
