Alignment after lift and Camber question - JeepForum.com
post #1 of 15 Old 09-13-2013, 07:58 AM Thread Starter
Insane
Had an alignment after lift and noticed my front right camber was -0.7 and front left was -0.4. I realize the spec is around -0.6 to -0.1
With that said, the jeep is new and is this something the dealership would fix under warranty? I haven't done anything to put the camber off. In my mind, they should fix this if it isn't in spec.
Just curious if anyone has had similar and had it repaired.
TIA!
Insane is offline
post #2 of 15 Old 09-13-2013, 08:04 AM
mello
Those camber numbers will not hurt anything however there is no way to adjust camber except with off set ball joints. A lift does not effect camber because it is fixed into your inner C's. how are your tires wearing?
mello is offline
post #3 of 15 Old 09-13-2013, 08:06 AM Thread Starter
Insane
Tires seem ok, but I was just saying the jeep has 4k miles. And shouldn't be out of spec already. Seems like the dealer should make it right.
Insane is offline
post #4 of 15 Old 09-13-2013, 08:07 AM
COLOUXJ
2010 JK Wrangler
You know you cant fix the camber right? Without new ball joints
With the numbers being that close if you take it in again and have them check it you will probably be in spec. All depends on the setup done by the tech.
Same thing for dealer. They will probably keep measuring it untill its in spec because its that close. I dont see your numbers causing any problems.
COLOUXJ is offline
post #5 of 15 Old 09-13-2013, 08:14 AM
mello
If the dealer does alignment and camber is actually 1 degree out of spec on their machine the only way they will fix it is replace the whole front diff housing. They possibly will not do anything at all and if they replace housing it could still be out of spec. If you are running a MT tire and the camber was going to cause an abnormal tire wear you would notice it already.
mello is offline
post #6 of 15 Old 09-13-2013, 08:15 AM Thread Starter
Insane
Yup, when I said "make it right", I mean put in a new ball joint if necessary. I agree it's close...but just sayin'
Insane is offline
post #7 of 15 Old 09-13-2013, 08:44 AM
mello
The dealer would not put in a new ball joint unless its play was out of spec. They would probably put an adjustable one if you supplied the part for them
mello is offline
post #8 of 15 Old 09-13-2013, 08:51 AM Thread Starter
Insane
(-0.7) I thought it was.
one more question, the idividual tow on front left and front right were off (red), and still off after alignment, but the overall tow was well within limits, so was green. I asked about that and the tech said that you can't always get the individual tows within limits and what matters if overall tow is correct. Opinions?
Insane is offline
post #9 of 15 Old 09-13-2013, 08:59 AM
mello
You can bring individual toe into spec unless something is wrong with the steering or the tech did not know that you can adjust toe on both sides independent of steering wheel centering. If a ball joint is perfectly good camber can be off due the the inner C's being bent or just off from factory.
mello is offline
post #10 of 15 Old 09-13-2013, 09:00 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
That is a true statement. Due to frame flexation, bushing centers etc etc. Total toe (and cross toe on IFS/IRS suspensions) is the end goal.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #11 of 15 Old 09-13-2013, 11:05 AM
COLOUXJ
2010 JK Wrangler
But what I said earlier was true as well. If any shop remeasures it they could easily find that its in spec. There is a tolerance error on alignment machines
COLOUXJ is offline
post #12 of 15 Old 09-13-2013, 11:07 AM
COLOUXJ
2010 JK Wrangler
Can you explain to me how to adjust individual toe? There is one adjusting sleeve on the tie rod. The only thing That might be able to even out those number would be the draglink, but I still dont know how that would fix it.
COLOUXJ is offline
post #13 of 15 Old 09-13-2013, 11:32 AM
mello
There is a tie rod on each side that adjusts toe for its side. The adjustment sleeve on drag link near pitman arm is to center steering. The main thing is to acquire 1/8 toe in then center steering wheel .
mello is offline
post #14 of 15 Old 09-13-2013, 11:48 AM
brianjw
You're over thinking this. Is there a problem with the way the jeep is driving?
If you want to get real technical, you would adjust the passenger side toe by adjusting the drag link length with the steering wheel centered. Hold the passenger wheel completely still (not going to happen), and adjust the drivers side toe with the one adjustment sleeve on the tie rod.
Since everything moves around under there, you just generally set the overall toe. Then you center the steering wheel. The end result is the same.
The camber is .1 degree out of spec? Can you see .1 degrees? There is going to be a tolerance on the alignment machine as well. Plus the factory ball joints suck, period. You could probably kick/shake the tire around and move the ball joint enough to show it in spec. Don't sweat it.
brianjw is offline
post #15 of 15 Old 09-13-2013, 01:11 PM
COLOUXJ
2010 JK Wrangler
But that still only adjusts overall toe, not the toe for each wheel.
COLOUXJ is offline
