Airconditioner - JeepForum.com
post #1 of 12 Old 07-22-2013, 04:46 PM Thread Starter
bluemike05
Airconditioner
have a 2010 rubicon changed battery now no airconditioner. checked all fuses. any ideas?
bluemike05 is offline
post #2 of 12 Old 07-22-2013, 07:15 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Check to see if the fan comes on when the AC switch is turned on. If not, have the system checked for low pressure...ie. a slow leak. Mine turned out to be a small rock that had wedged in between the fins of the condenser and make a pin hole....I am installing a grill for keeping large rocks out.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 12 Old 07-22-2013, 08:21 PM
mello
Does the blower motor blow or is it not working either. Sounds like it needs to be reset.
mello is offline
post #4 of 12 Old 07-23-2013, 04:39 PM Thread Starter
bluemike05
how do you do a reset. don't think its low pressure. this happened when changing battery and cable flew onto wrong post.
post #5 of 12 Old 07-23-2013, 04:40 PM Thread Starter
bluemike05
by the way no the radiator fan does not come on.
post #6 of 12 Old 07-23-2013, 04:47 PM
mello
Find the fuse for the temperature control module and pull it should reset system.
mello is offline
post #7 of 12 Old 07-24-2013, 05:26 PM Thread Starter
bluemike05
pulled fuse m34 which the book said is the temp. control mod. did not help. still no ac and the radiator fan is still not switching on. thanks for the the replies it is giving me hope that this will be a simple fix.
post #8 of 12 Old 07-25-2013, 01:35 PM
RockyClymer
RedRock4Wheeler
No fan tells me the low pressure switch may be bad or you have low pressure. Have it checked.
NRA Life member
post #9 of 12 Old 07-25-2013, 01:45 PM
T00THD0C
When the cable thing happened did it make sparks? Something may have shorted out.
T00THD0C is offline
post #10 of 12 Old 07-28-2013, 06:41 AM Thread Starter
bluemike05
yes but everything else works great. would have thought fuses would have be the first to go. the only thing that did not work afterwards was one of the little "button" usb car chargers had to replace it.
post #11 of 12 Old 07-28-2013, 06:47 AM
mello
Does your fan work when engine gets up to temp and a/c off.
mello is offline
post #12 of 12 Old 07-28-2013, 03:50 PM
RockyClymer
RedRock4Wheeler
Good Lord. Check low pressure and at least rule it out.
NRA Life member
