Airbag Warning Light - JeepForum.com
post #1 of 6 Old 11-20-2007, 07:28 PM Thread Starter
rlabbott
2012 WK
So.. I have an intermitent Airbag Warning Light stay on in the cluster. On for a day, off for a day. On for a drive, off for next drive. Go to dealer. First they say can't duplicate. Then they go to drive vehicle around front so I can take it home. The light goes off. It's at this point the 'can't duplicate' story loses some of it's luster. They say they want to replace the clockspring. Does that make any sense? Has anyone had an Airbag Warning light issue resolved by a clockspring replacement? I would love to see the fault code that says 'replace clockspring' if airbag warning light staying on. Perhaps a drive to the good dealer an hour from my house will cure this.
rlabbott is offline
post #2 of 6 Old 11-21-2007, 12:47 PM
E-CAT
read the manual...
If you place something on the seat that is not all that heavy (like a backpack or purse), the light will come on to tell you that the airbag is off and will not deploy... it recognizes the weight, but also that it's not enough to activate the airbag. A person in the passenger seat will trigger the activation of the airbag.
If you have nothing on the passenger seat and it randomly comes on and off... maybe it just enjoys messing with you.
E-CAT is offline
post #3 of 6 Old 11-21-2007, 03:15 PM
motor_car
2010 JK Wrangler
To add to e-cat's post: If the pass seat is far back and the rear seat is folded down and pushing against the back of the pass seat, that may trigger the "pass airbag off" light randomly.
motor_car is offline
post #4 of 6 Old 11-21-2007, 05:45 PM
JeepNorth
I don't think he's talking about the passenger air-bag.
It could be a clockspring. More likely they just want to get in to look at the wiring. If you are getting the airbag light, it's obviously detecting a intermittent problem. I would replace the airbag module first before ripping the steering column apart.
I know it's a fair distance to the dealer. But the next time the fault comes up, take it to the dealer and leave it running to show them.
JeepNorth is offline
post #5 of 6 Old 11-21-2007, 07:09 PM
JK Unlimited
Had the same issue. Mine was a side air bag senor that went bad.
JK Unlimited is offline
post #6 of 6 Old 11-28-2007, 12:26 PM Thread Starter
rlabbott
2012 WK
Reporting back on the fix
The first dealer (very local) I had it at thought it was the clockspring, but then did not have the wheel puller tool required for the 07JK (can you imagine that?)
The good dealer I go to (an hour away) diagnosed it immediately, even though the light was not on when I took it there. They replaced the clockspring!
The lesson: A good service department with honest people who are trying their best means EVERYTHING!
If anyone lives in the South Florida area, and wants to know who the Good Dealer is... I'll be happy to tell you. (My opinion is based on 10 years of owning 5 jeeps in my family by the way. Not a snap judgement.)
rlabbott is offline
AIRBAG warning light dm0ney TJ Wrangler Technical Forum 5 04-20-2009 02:22 PM
Getting airbag warning light on the dash.... Smelt_one JK Wrangler Technical Forum 5 01-28-2008 02:25 PM
Airbag Warning Light Bigmotorjammer TJ Wrangler Technical Forum 2 10-08-2007 09:12 PM
Airbag Warning Light creepycrawly TJ Wrangler Technical Forum 6 09-07-2007 09:46 PM
Airbag Warning Light On usetobejeeper TJ Wrangler Technical Forum 15 05-23-2003 11:08 PM
