Air locker compressor, run time? - JeepForum.com
post #1 of 8 Old 12-07-2010, 10:48 AM Thread Starter
Maximous
2010 JK Wrangler
I recently installed a CKSA12 "Compact onboard air kit" for to provide air to my lockers. I guessing that there are many of these our there. Can someone tell me roughly how long the compressor comes on for when you initially turn it on? Does anyone run a pressure gauge in the vehicle? Is this needed? Do the lockers come unlocked as soon as you hit the switch? Where does the solenoid dump the line pressure when it's switched off?
Thanks in advance.
Maximous is offline
post #2 of 8 Old 12-07-2010, 04:01 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I am assuming you have ARB lockers - if so, they pretty much unlock when shut off AND when there is little or no load holding the dogs together inside the locker. If the air compressor has a minimal amount of storage and an auto shutoff (which it does) then the compressor would normally come on about every 10 to 15 minutes when locked as the air tubing, joints and locker seals do leak a small amount. If the solenoids are screwed into the side of the compress, then it should pretty much stay off when unlocked. I only use my lockers for at most a couple of minutes at a time through the obstacle as needed, then switch off.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 8 Old 12-07-2010, 04:06 PM
1222
RIP John
1222's Avatar
Just trying to refresh my memory; doesn’t the ARB lockers require something like 80psi to work correctly?
(2011-2016)
1222 is offline
post #4 of 8 Old 12-07-2010, 06:09 PM Thread Starter
Maximous
2010 JK Wrangler
I do have ARB lockers yes. I am more so wondering how long the compressor should be on initially to come up to the required pressure. I looked at a TJ or a friend of mines and the compressor is the next size ARB up from mine and it came on built pressure and turned off pretty quick. How long should the compressor initially come on for?
Also, can you hear the lockers lock? I can't so far. I can tell when the front is in because of the way it pulls but I can't really tell when the rear is in.
Thanks
Maximous is offline
post #5 of 8 Old 12-07-2010, 06:23 PM
nwbronco
2014 JK Wrangler
ARB lockers have a switch and a solenoid. The lockers require no less than 85psi and no more than 105psi. The solenoid will hold the air pressure in the line with the locker actuated until the switch is turned off. The solenoid then opens and releases the locker pressure. As long as the locker switch is on, the soleniod stays closed and the locker stays engaged. That is of course, if there are no leaks in the fittings/lines.
Bob K.
nwbronco is offline
post #6 of 8 Old 12-07-2010, 06:29 PM
RockyClymer
RedRock4Wheeler
The pressure should come up almost instantly, and when locked, the compressor should only come on about every 10 to 15 minutes at most.
NRA Life member
post #7 of 8 Old 12-07-2010, 07:15 PM Thread Starter
Maximous
2010 JK Wrangler
OK, thanks. I need to have another look at things because my comp stays on for at least a few minutes. The TJ I saw also came up very quick.
Thanks
Maximous is offline
post #8 of 8 Old 12-07-2010, 08:31 PM
RockyClymer
RedRock4Wheeler
Unless you are feeding a storage tank, it should stop pretty quickly. Even a small tank will take a minute or so sometimes. My old arrangement with a 2.5 gallon tank took about 90 seconds...do not use that setup anymore and only for a short time due to some technical and placement issues - finally went with a power tank.
NRA Life member
ARB Locker (Compressor) Question Dirt_sample JK Wrangler Technical Forum 8 09-17-2009 09:01 PM
MV50 compressor with ARB Air Locker Frank the Tank TJ Wrangler Technical Forum 9 09-11-2009 08:30 AM
Using ARB compressor for rubi locker gribbles TJ Wrangler Technical Forum 15 03-07-2009 03:43 AM
ARB Locker, but no compressor... now what? Frank the Tank TJ Wrangler Technical Forum 15 01-29-2007 12:17 PM
arb compressor for rubi locker orangetj05 TJ Wrangler Technical Forum 3 12-22-2006 07:18 PM
