Air bag light - JeepForum.com
post #1 of 4 Old 03-15-2010, 08:01 AM Thread Starter
bassin
Air bag light
Has anyone had trouble with the Air Bag warning light on the dash coming on for no reason. Took it to the dealer three weeks ago and they supposedly fixed the problem, NOT. Anyway to totally disconnect it light and all or just let the dealer worry with fixin it. It only comes on when no one is in the passenger seat.
bassin is offline
post #2 of 4 Old 03-15-2010, 11:30 AM
FC2TurboMSS
If you disconnect the electrical connector going to your passenger seatbelt assembly, you will get this light on your dash. I'm not sure about the driver's side, but I would assume the same for there too.
Check to make sure that connector is secure, as well as the wires that go into both halves. This connector is for the pyrotech device in your seatbelt and if its not hooked up, it gives that "airbag" alarm.
I have an aftermarket seatbelt on the passenger side and this light is lit on my dash all the time as there is not pyro device in my aftermarket seatbelt. I have not figured out if you can jumper the plug or insert a resistor anywhere to "cheat" the dash light. I'm afraid to just arbitrarily try something for fear of shorting out the computer or something.
Hope this helps.
"The World was large, now it is small. It was lonely, now it is crowded. It was dark, now the lights are on. Some day the old will be new again. Keep your guns close but your sword closer. For one day Man will again fear the dark of the World."
--The Zombie Prophet
FC2TurboMSS is offline
post #3 of 4 Old 03-15-2010, 04:58 PM
skiro98
Strange...I just called the dealer today to get mine looked at for this problem.
He says if something under 90(?) pounds is in the front seat that the light will come on. If it is always in that front seat then the light will think something is wrong and eventually stay on.
Well my daughter is in that seat quite a bit and she is under 90 pounds. So I guess it just needs to be recalibrated.
...at least thats what I was told.
skiro98 is offline
post #4 of 4 Old 03-15-2010, 05:05 PM
FC2TurboMSS
that could very well be the issue...i was just giving you the reason mine is on...lol
keep blowing tail light, turning singnals and interrior light fueses on my TJ bigtime13 TJ Wrangler Technical Forum 1 11-06-2009 07:34 PM
Interior light issues - dome light and wiring mess liminalhigh YJ Wrangler Technical Forum 0 07-20-2009 08:47 AM
Turn signal dash light stuck on, warning chime, no shift light. bmlawless TJ Wrangler Technical Forum 7 10-21-2008 09:29 AM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 05:48 PM
brake light/Hazard light fuse blows as soon as you install it! jeffro123 YJ Wrangler Technical Forum 6 08-23-2005 11:57 AM
