Aftermarket Light Switch Location? - JeepForum.com
post #1 of 14 Old 07-15-2010, 10:45 PM Thread Starter
Wranglin4Life
I am installing my KC Slimlites this weekend and was wondering where everyone was mounting their switches. If anyone has a pic that would be awesome but I just need and idea of a good location. Thanks
Wranglin4Life is offline
post #2 of 14 Old 07-15-2010, 11:10 PM
MilitaryJK4455
2010 JK Wrangler
Above the driver side speaker... perfect spot, out of the way and convenient spot to go through the firewall.
MilitaryJK4455 is offline
post #3 of 14 Old 07-15-2010, 11:22 PM
miked2905
2009 JK Wrangler
There are a million threads on switch locations, try the search box.
'09 JK- 3.25", 35s, 5.13s, trussed/sleeved d30 ARB
'88 Grand Wagoneer - 6", 33s, 5.3L/4l60e/241C
miked2905 is offline
post #4 of 14 Old 07-15-2010, 11:30 PM
fernjack
I put mine here .....easy to get to . Built this power distribution panel to use relays and fuses for the aux. lighting .
fernjack is offline
post #5 of 14 Old 07-16-2010, 12:31 AM Thread Starter
Wranglin4Life
Or if you have nothing decent to say how about you dont say anything at all. I understand their is a search box.... Im not an idiot, I didnt feel like searching for hours and asked for some pictures and you can always count on some smart mouth kid to say "try using the search box"
post #6 of 14 Old 07-16-2010, 12:32 AM Thread Starter
Wranglin4Life
Fernjack - U built that panel under the hood? Looks pretty cool. I have never wired in lights before so this should be interesting. Haha
post #7 of 14 Old 07-16-2010, 07:02 AM
fernjack
I really recommend using a relay they are cheap and easy to install ........You'll do fine it's not that hard . Pm me if you have a question or post ....lots of guys on here know how to wire up lights .
fernjack is offline
post #8 of 14 Old 07-16-2010, 08:40 AM
JKNorth
Wiring lights is pretty simple. If you're going to buy the KC Slimlights, get the kit with the wiring harness and it's pure cake.
I put the switches to the left of the steering wheel, above the speaker. One thing I did change from the KC kit was the switch. The KC switches are oval, and I went with a round switch that fits a bit better there.
As others have mentioned, once you pull the side panel off the dash, there's a foam filled hole there that is convenient access through the firewall.
There are switch panels available for the bottom of the centre console, but I have a net there and I like it. There's also the S-Pod which gives you a Rolls Royce solution with a panel at the top of the windshield and a fuse/relay box under the hood, but I could never bring myself to spend the $400 for a set of lights.
2008 Sahara Unlimited
33" DuraTrac's, 2" BDS spring lift, LOD Mid-width bumper, Rock Hard skid plates, Riddler diff covers, Rubi rock rails, Benchmark evap skid
JKNorth is offline
post #9 of 14 Old 07-16-2010, 10:24 AM
1222
RIP John
1222's Avatar
x's2
(2011-2016)
1222 is offline
post #10 of 14 Old 07-17-2010, 01:03 AM
stanware
I bought the daystar panel that goes in the bottom of the center console thing. I should have just done the above the driver side speaker thing, but too late...
stanware is offline
post #11 of 14 Old 07-17-2010, 04:01 AM
kudah
JK switches
here you go.
Robert
kudah is offline
post #12 of 14 Old 07-17-2010, 04:34 AM
mrsig
The KC Slimlites are very easy to put in but I used the Daystar Switch Panel and rockers! I use the switch from my Piaa's them to light up my other switches.
At night the green or red light from my Piaa's put just enough light on the other switches so I can see them in the dark.
07 JKU To see mods & my Jeep in Action @
CEO of Black Sheep 4x4s
Member of CCJ, White Jeep Club Member #137.
mrsig is offline
post #13 of 14 Old 07-17-2010, 10:38 AM
krutj
2009 JK Wrangler
Originally Posted by kudah View Post
JK switches
here you go.
Nice link....thanks!
This is what I like about JF...I never would find all these links and info myself!!
-- Joel --
krutj is offline
post #14 of 14 Old 07-20-2010, 10:28 PM
JKNorth
JK switches
here you go.
Oh man, I like that even better than the S-Pod! Great placement and the bin would be handy.
Still, I'm happy with the $10 solution vs. $450 for a single set of lights...
JKNorth is offline
JK Wrangler , light switch location , switch location , wrangler
Factory Fog Light switch with aftermarket lights. Mooseknuckles TJ Wrangler Technical Forum 15 01-16-2010 07:28 PM
aftermarket horn wired to switch, would like stock to work on switch as well hilton00 TJ Wrangler Technical Forum 14 01-02-2010 03:11 PM
location of backup light switch on 6speed? yellowismellow TJ Wrangler Technical Forum 17 02-19-2009 06:06 PM
fog light switch location jgillespie YJ Wrangler Technical Forum 4 04-02-2008 08:23 PM
backup light switch location ????? Jim Runge TJ Wrangler Technical Forum 4 04-10-2003 11:50 PM
