After lift install traction control light coning on randomly? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > After lift install traction control light coning on randomly?
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineThe Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!
Unread 08-06-2013, 06:23 PM   #1
04WJfreedom
Installed the 3.5" rock krawler X factor lift today. I went for my first test drive before using aev procal and everything was fine.
Went back home used aev procal to set tire size went for another test drive and now the traction control light comes on every 30 seconds while moving and makes as noise like when the abs kicks in? Any ideas why this would happen?
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 06:36 PM   #2
LVCapo
The Voice of Reason
LVCapo's Avatar
2015 JK Wrangler
You need to center your steering wheel. make sure your wheels are straight, you'll notice your steering wheel is slightly cocked to one side. Have your wife/GF/BF sit in the driver seat to watch the steering wheel. Take a 15mm wrench or socket and loosen the two nuts on the turnbuckle, turn it until steering wheel is straight (have assistant tell you which way to turn)...tighten down nuts....take it for another test drive....may take a few minutes for light to go out.
LVCapo is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 06:43 PM   #3
04WJfreedom
Oh ok so the steering wheel being off center would do that? Hmmm seems like an easy fix. Thanks
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
Unread 08-06-2013, 08:39 PM   #4
mello
The procal has a steering wheel straightening feature that makes it a breeze.
mello is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 08:44 PM   #5
OH9JK
2009 JK Wrangler
Yep Jeep thinks it is in a slide.
ProCal will make this job a piece of cake (or pie if you prefer)
http://www.aev-conversions.com/ishee...User_Guide.pdf
OH9JK is offline   Reply With Quote Quick reply to this message
Unread 08-06-2013, 09:44 PM   #6
1222
Make mine a Jeep!
1222's Avatar
Congrats on your new Jeep.
Just to add a bit, sometimes it takes a few tries to get it right. So, say itís all straightened up in your garage but after a test drive you might find that itís still a bit off, donít worry just adjust it some more. Also Iíve had better luck without the ProCal and so have others.
1222 is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 08:03 AM   #7
duneslider
I would agree with not using the procal. It will get you close without having to keep getting up to look at the steering wheel but once close you need to go for a quick drive and make fine adjustments to get it perfect. It took me 3-4 quick drives to get mine where I wanted it.
duneslider is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 08:54 AM   #8
ferninaz
ferninaz's Avatar
Please make sure to check your nuts and bolts in about 500 miles to make sure nothing has backed out.
ferninaz is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 09:58 AM   #9
tonka_yellow
make sure your sway bar is horizontal
tonka_yellow is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 02:33 PM   #10
04WJfreedom
Thanks for the replies guys I'm going to try it with out the procal first and go from there!
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
Unread 08-07-2013, 02:44 PM   #11
SubAtomicGenius
2011 JK Wrangler
You can do it without the procal, but the steering wheel center indicating feature is a nice to have.
SubAtomicGenius is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 03:24 PM   #12
zpayne08
Light came on in mine after finishing the lift today too. Glad I searched and saw this. Btw, is your jeep dune color or dozer?
zpayne08 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 04:20 PM   #13
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
ferninaz - I always fill my tank and tighten my nuts before off-roading.....
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 02-28-2014, 06:02 PM   #14
invest2m4
Not sure if it was mentioned, but a lot of people don't actually understand the Procals steering centering feature. It is meant to be used when the Jeep is on an alignment rack. The wheels are obviously straight, so when the steering is centered, it tells you. The result, is centered steering.
However, it goes one step further (and this is why it's important to do it on a rack). It recalibrates the traction control and ABS. Often times (and it happened to me), you can center the steering after a lift, but you still have issues with the Jeeps traction control and ABS. The fix is the Procal on a rack.
invest2m4 is offline   Reply With Quote Quick reply to this message
