AEV's Procal Module 08 Wrangler - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > AEV's Procal Module 08 Wrangler
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 09-27-2013, 01:59 PM   #1
leeg2000
2014 JK Wrangler
So i had my transmission looked because its doesnt seem to be shifting correctly. After Mr Transmission done their test, they said it needed to be reprogrammed per a TSB. Which will cost about $80 from the dealership. Question is does anyone know if AEV's procal will reprogram it? i know it does a lot of different things with newer JK's. Wasnt sure about my model though. any input would be great. thanks
leeg2000 is offline   Reply With Quote Quick reply to this message
Unread 09-27-2013, 03:41 PM   #2
ROCKR8R
Reprogrammed how? What is your tranny doing? Are you running bigger tires and a lift?
-Dan
ROCKR8R is offline   Reply With Quote Quick reply to this message
Unread 09-27-2013, 04:57 PM   #3
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
ditto - all the Procal does is take the revised tire diameter and diff gear ratio into account to reset the auto shift points...if your auto is currently working, then why would it need reprogrammed? Your profile does not seem to indicate lift or large tire use.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 09-27-2013, 05:01 PM   #4
leeg2000
2014 JK Wrangler
It's not shifting correctly. For instance if it's in 3rd gear and I'm going up a hill it "bogs" down but never shifts to second. It's the same thing if I'm off-road and it's in second gear if I'm going up a hill at a slow pace it will bog down and never switch to 1st gear it would probably die if I didn't manually change it or completely let off the gas pedal. I looked up the tsb for it and in 2009 I believe it was posted and it had to do with the trani not changing between 1 and 2nd like it's supposed too. And yes I'm running 305/70r16 With a 2.5 inch lift.
Unread 09-27-2013, 05:37 PM   #5
RockyClymer
RedRock4Wheeler
Yeah, that is basically a 33 in tire...guess you need some re-flashing of your ECM at the dealer.
NRA Life member
Unread 09-27-2013, 05:52 PM   #6
leeg2000
2014 JK Wrangler
Yeah. The main reason I was asking is because I found a place that is selling the module for $80. But if it won't fix the issue I won't bother.
Unread 09-27-2013, 06:57 PM   #7
Spank
2014 JK Wrangler
Reprogramming for aftermarket parts is different than reprogramming per a TSB. Were you given a number for reference?
'14 Wrangler Unlimited Rubicon
Spank is offline   Reply With Quote Quick reply to this message
Unread 09-27-2013, 07:14 PM   #8
JIMBOX
The TSB can correct certain shifting parameters,but the dealer won't corrrect the shift requirements for 33" tires, you'll hafta get at least a AEVPM-
Mine has allowed me to alter my shift avenues whenever I want a tiresize change--
There are many other programs available in the AEVPM and for $149 bucks it's well worthit-
I've used mine for over 4 years with no problemo-
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote Quick reply to this message
Unread 09-28-2013, 07:42 PM   #9
leeg2000
2014 JK Wrangler
JIMBO
Thanks! I'll just the module. Planned on buying one eventually, gives me a better excuse to get one lol
