AEV Procal and other tuners - JeepForum.com
post #1 of 11 Old 11-04-2013, 07:30 AM Thread Starter
Mfrancis
2014 JK Wrangler
I had a conversation with my dealership about their policy on lifts. They don't mind them and it's basically a common sense thing with the warranty. If the a/c quits working, it obviously wasn't the fact I lifted my jeep.
One interesting part of the conversation, however, is that the service advisor specifically said not to touch the computer. They have some way of knowing if you do it yourself. The procal was on my list of purchases, but now not so much. Anyone else come across this? I also wonder what would happen if it was done by a specialty shop I.e. 4 wheel parts or a local shop.
Black 2014 JKU Sport S, 6 speed manual, 3.73 rear end, 2.5" AEV Dualsport XT w/ Bilstein 5100s, 255/75/17 Goodyear Wrangler A/T, Rubicon rock rails, front grill mesh mod, Jeep door sill guards, matte black Jeep grill emblem, matte black exhaust, Synrgy upper and lower bolt swap(highly recommend), tires pending...
Mfrancis is offline
post #2 of 11 Old 11-04-2013, 07:41 AM
brianjw
That should be common sense if they understand it isn't a performance tuner. Being that its simply a calibration tool. You aren't changing spark, timing etc with it.
If they don't understand it, being one in and show them if you're really THAT concerned about it.
Now if the computer totally craps out when you plug it in that's another thing.
brianjw is offline
post #3 of 11 Old 11-04-2013, 07:55 AM
jeepfan30
2014 JK Wrangler
I just picked up a 2014 JKU last week from a local dealer. My jeep came with a 3" Lift and 35's...it also came with the ProCal. Les Schwab installed the lift for the dealer and included the ProCal in the deal. My dealer said the same, Jeep has to prove that the lift caused the damage and Les Schwab covers the lift warranty.
I had a similar battle with my 2008 GC after the 4" lift, the front diff seized up 500 miles after the lift was installed. Jeep said it was the lift but 4 wheel parts called them and said prove it since they installed it. Turned out Jeep paid for the front diff replacement.
3" EVO Enforcer, Fox 2.0 Shocks, 4.56 w/Truetracs, Coast F&R DS, 35" Toyo M/T, Warn Zeon 10-S
jeepfan30 is offline
post #4 of 11 Old 11-04-2013, 10:55 PM
suicideking
Unless they're volunteering to update the computer every time you mod something, you will want to use the Procal.
Tire change, gear change are two major things the Procal will do. It does have many other useful features. One that I use all the time is the 'center steering' setting. After wheeling, my steering is often off center. The procal will help you fix it.
Besides, if you're really paranoid about the dealer complaining, you can always set your Jeep back to factory.
suicideking is offline
post #5 of 11 Old 11-05-2013, 10:21 AM Thread Starter
Mfrancis
2014 JK Wrangler
He didn't offer to do it for free. Said it would be an hour of labor. Lame.
Mfrancis is offline
post #6 of 11 Old 11-05-2013, 05:34 PM
brianjw
See why he doesn't want you to buy a procal now? $$$
brianjw is offline
post #7 of 11 Old 11-05-2013, 05:45 PM
suicideking
Yup, scam!
Out of all the people on the forums, I haven't read one person mention the dealer complaining that a Procal was used. They just try to scare you so you'll pay them an hour of labor every time you make a change.
My dealer tried to talk me out of a 5 tire rotation (because it takes them more time). I told him either rotate all 5 according to the diagram I gave him, or don't rotate the tires and I will pay someone else to do it. Sure enough, they rotated all 5.
post #8 of 11 Old 11-05-2013, 05:45 PM
TheBoss
The procal is a cheap and invaluable tuner it's simple to use. If you need to take theJeep to the dealer for service just return it to the stock settings and your done. A former Jeep engineer designed the damn thing.
TheBoss is offline
post #9 of 11 Old 11-05-2013, 05:56 PM Thread Starter
Mfrancis
2014 JK Wrangler
That's why I was curious. As much as you folks talk about them, I was sure I should have come across this by now if it was an issue. Thanks for the input.
Mfrancis is offline
post #10 of 11 Old 11-06-2013, 08:57 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Just keep in mind - procal is NOT a tuner. A tuner modifies the engine operating parameters. The procal is a calibrator - modifies tire size speedo etc...
Calling it a tuner and suggesting the use of a tuner WOULD raise questions by the dealer. Most good service writers already know the difference and have no big issue with the ProCal.
One thing you may want to employ in your strategy - is whenever a reflash IS required - unpair the procal before you take the jeep in - then have them set the computers base line to tire size etc to your mods - that way you are not paying for them to recalibrate - its part of the reflash you are already paying for (or having done under service bulletin/warranty)!
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #11 of 11 Old 11-06-2013, 11:58 AM
JTPhoto
JTPhoto's Avatar
Most dealers can only program to a 33' tire anyway.. Not sure if their system allows for gear ratio changes other then stock as well.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
