AEV 4.5" SC Suspension Lift Review? - JeepForum.com
post #1 of 11 Old 09-08-2011, 10:54 PM Thread Starter
credd24
2010 JK Wrangler
Within the next month after doing a lot of research on Lifts and making money to get one, I have pretty much decided on going with the AEV 4.5 SC lift. I was looking to see what some of the fellow JK members who maybe run this lift or know about the lift can share their feedback or experience with it?
credd24 is offline
post #2 of 11 Old 09-09-2011, 09:33 AM
SADISTIC
2011 JK Wrangler
I have the 3.5" kit on my 2011; LOVE IT
The only differences are springs, and I assume, slightly longer track bars; the control arm drop brackets are drilled for both kits.
Don't know if you were planning on installing it yourself but if you have the tools (pretty basic) and ability, I wouldn't pay anybody to install it. The kit is a breeze to install, the instructions are very thorough, and there are not any aggravating angles and measurements to dial in afterwards.
I easily fit 35 KM2's (actually 33.75") on the 3.5" and many say you can fit 37's.
I had a '05 TJ with a RC 6" LA before this JK, I needed something I could travel in for work a little more comfortably; this kit allowed for the larger tires and off road performance as well as the ability to comfortably travel all over the S.E.
You won't regret going with this kit
SADISTIC is offline
post #3 of 11 Old 09-09-2011, 10:55 AM
aristobrat
2010 JK Wrangler
I also run the 3.5" (on 35" KM2s) and love it. There are a few 4.5's in the Jeep club I'm in, and comparing notes, they love theirs too. Sounds like the 4.5" handles just as well as the 3.5".
For me, my JK handles better on-road (sitting ~5" taller between the lift/tires) than it did on the stock suspension, especially when cornering -- way less body roll. It's also handled anything off-road I've pointed it at, but my testicular fortitude usually ends at "high medium" in difficulty, although I've done a few "red" trails at Rausch Creek (and big things at Uwharrie) with no issues. The AEV suspension eats up bumpy Forest Service roads in the GWNF, to the point that when I wheel there with my Jeep club, I can't lead ... I end up going too fast because I'm not getting jarred around like most of the other Jeepers.
Based on the threads I've seen around, the biggest objections to the AEV lifts have nothing to do with performance/owner satisfaction. They're typically "it's too expensive for the parts you get with it" or "it's just a bunch of brackets". IMO, in regards to price, if you can do an apples to apples comparison between two lifts, AEV doesn't usually end up being significantly more expensive. In regards to the use of brackets, that's fairly unique to the AEV lifts, and seems (IMO) to play a key role with the AEV handling being rated so highly. Lots of opinions on these two matters!
aristobrat is offline
post #4 of 11 Old 09-09-2011, 11:20 AM
guarnibl
2009 JK Wrangler
For the price, there isn't a better lift on the market for overall use. I don't think it's that expensive considering what it offers. Yes, it uses brackets, etc., but at the end of the day it gets the job done better than 95% of what's on the market.
I am actually taking it off of my jeep -- but only because I'm going to a 5.5" rock krawler long arm stretch with coilovers/bypasses in each corner (diff. rear axle to fit the coil overs in the rear). It wont handle as well on the highway once I do this. For people that use their Jeep day to day and want the best possible off road performance at the same time without sacrificing highway driving -- you can't, won't, beat AEV. The progressive rate springs are awesome The only thing I recommend is if you're going at a decent speed over rougher terrain -- air bumps might not be a bad addition. EVO sells some good 2.0" ones. Otherwise Poly sells King air bumps for a good price too. Seeing as you're in Georgia though I don't think you'll need them.
2009 Jeep Wrangler Rubicon (6mt) (in progress)
- 42x14.50 MTR's, Custom Cage, FF D60's F/R w/ ARB's and 5.38's, 4 Link Rear, 3 Link Front, 14" RR King 2.5's, 18" RR Fox 2.5's, Fox Air Bumps
- 108" wheel base
guarnibl is offline
post #5 of 11 Old 09-09-2011, 02:29 PM
Avernar
2010 JK Wrangler
I have the 4.5" on my 2010 and it handles better than stock. Even my friends noticed it doesn't lean as much in the corners as it used to.
Avernar is offline
post #6 of 11 Old 09-09-2011, 06:41 PM Thread Starter
credd24
2010 JK Wrangler
Thanks for all these posts. It really helps out. Everything yall have said basically describes what I've heard bout AEV and im pretty convinced and excited bout the upcoming purchase
credd24 is offline
post #7 of 11 Old 09-09-2011, 09:58 PM
KPJ
2010 JK Wrangler
I have the 4.5" AEV suspension and it is fantastic. Better ride, and, remarkably, handling than oem, even with 4.5" of lift and 5" of tire diameter...
JPK
KPJ is offline
post #8 of 11 Old 09-13-2011, 10:22 AM Thread Starter
credd24
2010 JK Wrangler
JPK
What size wheels and tires are you running?
credd24 is offline
post #9 of 11 Old 09-13-2011, 10:58 AM
1222
RIP John
1222's Avatar
Another vote for AEV. That’s what I had on my ’08 and until the shocks took a dump it was the best thing that I did to my Jeep. It was the 3.5 but other than an extra inch in height they’re the same.
1222 is offline
post #10 of 11 Old 09-14-2011, 02:34 PM
4LCKDRUBIUNLTD
2010 JK Wrangler
4.5 AEV Premium here. Fits my DD needs & handles well offroad. Another satisfied customer here Only thing I didnt like was using the rear sway links upfront...
4LCKDRUBIUNLTD is offline
post #11 of 11 Old 09-14-2011, 09:03 PM
KPJ
2010 JK Wrangler
AEV Pintlers, 8.5" x 17" with 4.7" back spacing.
12.5 x 37" BFG.
JPK
KPJ is offline
aev , lift , reviews
RockKrawler 3.5" Suspension long term review. Xtremjeepn JK Wrangler Technical Forum 16 01-17-2012 03:55 PM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 07:04 PM
Rusty's 4" lift rant\review Fastbeeatch YJ Wrangler Technical Forum 6 08-06-2004 04:52 AM
Needed: Review of Rough Country 3" lift Slider_88YJ YJ Wrangler Technical Forum 6 07-21-2003 01:10 PM
