AEV 3.5" Premium Review - JeepForum.com
post #1 of 30 Old 11-17-2009, 12:11 PM Thread Starter
s1edneck700
Just got to put some driving time on my new AEV lift that I installed last night. First impression was WOW....my jeep is HUGE! Moving on to more relevant matters, the install was pretty easy. Instructions were thorough enough to get vital points across and I did not have any difficulty aside from the random rusted bolt or 2.
Fit and finish of the lift is great. Everything looks like it is top notch and built to last. Did not have any problems with tolerances or clearance of parts. No clunking or squeaking of any kind. Only problem is that at full droop, the rear coils come unseated. I had to reseat the right rear because the top isolator was off center when I dropped the jacks.
Have not gotten a chance to take it off road yet, but here are my on road thoughts. First and foremost, the gearing. I was sooo convinced that 3.73 was inadequate even for a stock wrangler, but, knowing that these vehicles are no speed machine, I decided to give it a shot. I truly believe the daily driver and occasional moderate wheeler does NOT need a gear job. I was pulling 2300 rpm in O/D doing 65 with the 35" mt/r kevlars (and yes I reprogrammed with the procal). MPG was 17.1. Around town there is more than enough power to scoot in and out of lanes. Just hit the O/D off button everytime you get in and you will be fine, and preserve your lifetime powertrain warranty!! Moving on from the gearing, the handling is stupendous. I need to dial in a bit more caster with my Currie front upper control arms (aiming for 6.25 degrees), but even at 5 degrees it was good enough to live with. BTW I used my Ipod level app to set the caster, what a cool little tool!
Appearance. I was sceptical at first about the weight assumption that is built into the AEV lift. Oh well, decided to go for it anyway. I don't think it could sit any more perfect. I will have pictures soon! But I am very happy with the way it accommidates 35's. Going to put the front air dam back on to help conceal some of the linkage and give it a cleaner, more factory look.
All in all I could not be happier with the setup. I am very excited about not having to regear and retaining my warranty. The product looks great and performs well. I know DocJake is waiting to hear a solution for mounting a spare pintler on the tailgate. I will be working on it, had no time to sleep last night cuz I wanted this done so bad.
s1edneck700 is offline
post #2 of 30 Old 11-17-2009, 12:24 PM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
good to hear you like it. now post up some pics
you might need some limiting straps if the coil is coming unseated at full droop. I wouldn't want to worry about that while on the trail.
-Matt
mattman8706 is offline
post #3 of 30 Old 11-17-2009, 02:10 PM
ncb
Congrats on the lift. I have read about the issue with the rear springs. Take a look at these spring retainers.
JKS REAR COIL SPRING RETAINERS JEEP WRANGLER JK 1600:eBay Motors (item 380165117501 end time Dec-03-09 19:49:02 PST)
ncb is offline
post #4 of 30 Old 11-17-2009, 04:10 PM
Jodyblip
Good to hear!! my 3.5 premium is backordered from quadratech and supposed to be drop shipped from AEV soon i hope!!
Jodyblip is offline
post #5 of 30 Old 11-18-2009, 08:56 AM
crazymax
I just installed my AEV Premium Lift along with a full set of Teraflex control arms last week. Install was very straightforward. This replaced a 2.5" Teraflex coil and shock lift. Haven't been offroad, but it handles much better on the road. Especially when hitting a bumb on a corner at higher speeds (like an offramp from the freeway). I haven't had an aligment done yet, but with the Teraflex Control arm recommendations, steering is perfectly centered and is doesn't pull to either side when driving or braking.
My only bugger with the install, was putting the in the bolts for the front bump stops. It took quite a bit of patience.
crazymax is offline
post #6 of 30 Old 11-18-2009, 09:42 AM
BigMikeATL
2014 JK Wrangler
You guys with the AEV 3.5" Premium Lifts suck! I hate you!
I'm jealous as hell!
2014 2D Rubicon, 2.5" Metal Cloak Game Changer ARB, ProComp 7069 17x9, Goodyear MTR Kevlar 35's, ACE Pro Series Bumpers, Warn M8000
2011 Grand Cherokee Overland HEMI MyGig Tow Pkg
2009 2D Rubicon SOLD
BigMikeATL is offline
post #7 of 30 Old 11-18-2009, 12:48 PM Thread Starter
s1edneck700
Update:
Dialed in more caster. I am at 5.8 degrees now. Tracking is much better and bump steer has decreased. Will give it one more turn tonight to get me into the 6 degree range, which should make everything just right. Going to throw the front air dam back on tonight to clean up the look a little bit and protect the drag link turnbuckle from roadspray in the winter, which seized my last one (I replaced the turnbuckle and tie rod end with the aev lift). Pics coming as soon as I get the camera from my buddy.
post #8 of 30 Old 11-18-2009, 02:02 PM
Xtremjeepn
Originally Posted by s1edneck700 View Post
Update:
Tracking is much better and bump steer has decreased. .
There is no bump steer with the AEV kit. This term is thrown out too much and misunderstood.
The steering wheel moving when the Jeep hits a bump is normal. "Bump steer" is an actual change of direction induced by bumps due to improper steering geometry. You WANT to feel the road and bumps in the steering, you DON'T WANT it to change your direction of travle(or have to fight the wheel to keep the Jeep straight)
Cole Ford
Xtremjeepn is offline
post #9 of 30 Old 11-18-2009, 02:19 PM Thread Starter
s1edneck700
Hmmm, I'm not sure I understand what you are saying. I will have to drive it with that in mind to differentiate between feeling the road and changing the intended course of the vehicle. The only time I really get a jolt that is worth noticing is if I hit a big manhole cover with one wheel or something else that doesn't involve both front wheels hitting the bump at the same time/intensity. I am having a toe measurement taken right now at my dealership to make sure that is spot on as well for the 35's.
Also, just want to make sure this issue isn't taken out of context. This is NOT a problem, just fine tuning of the setup. This lift rides impeccable and handles/steers better than any other lifted/altered ORV I have been in. Even the install is simple, so the average joe can save some cash. Props to AEV for such a high-value product, and thanks for the input on this thread!
Edit: Alignment measurements came in. Camber is -0.5 degrees on left front, -0.4 degrees right front. Factory spec allows no more than -0.6, so I am good there. Toe is 1/16th" toe-in. I will put one turn into the tie rod tonight, should give me just what I'm looking for. Will post results.
post #10 of 30 Old 11-18-2009, 02:43 PM
Jodyblip
bump steer is when hitting a dip manhole railroad tracks whatever causes your jeeps front wheels to actually turn when your springs compress even though your steering wheel is straight. it will feel no different than NOT having bump steer you still should feel the bump so to speak
Jodyblip is offline
post #11 of 30 Old 11-18-2009, 02:55 PM
Xtremjeepn
Think of it this way. Hit a bump with your hands off the steering wheel. The wheel will move with the bump but the Jeep should continue mostly straight. (give that the bump does not slow one wheel enough to make a minor change in direction). BUMP steer will actually CHANGE the dircetion fo the Jeep and you will have to correct for it.
Cole Ford
post #12 of 30 Old 11-18-2009, 03:02 PM
chickenhawk7
BigMike, I know what you mean. I was hatin' too, then I got my own. I think you will really like the lift when you decide to pull the trigger.
chickenhawk7 is offline
post #13 of 30 Old 11-18-2009, 09:04 PM
scbroder
2009 JK Wrangler
+1, wheels move, but steering wheel does not.
scbroder is offline
post #14 of 30 Old 11-18-2009, 10:42 PM Thread Starter
s1edneck700
Gotcha on the bump steer......the guys on the AEV forum gave me the whole schpeel. Makes sense, just more feedback because the scrub radius is bigger with the pintlers vs the stock backspacing.
On a different note, got the spare on. Trimmed the daystar isolators to side and proceeded to take the sawzall to the bumper. Cut a crescent-like hole where the tire was hitting. Fits like a fricken top now! Also put the stock front air dam back on, looks much cleaner in the front and should help keep road spray and crap from getting up in the engine compartment like last winter. Sorry for not posting pics yet, too busy tuning this bastard all night and working during the day.
post #15 of 30 Old 11-19-2009, 06:42 AM
BigMikeATL
2014 JK Wrangler
That is one sweet looking rig!
Poly Performance Jeep Jk 4" Stage 3 lift versus AEV / Nth degree 3.5 " Premium lift TDmaster JK Wrangler Technical Forum 20 02-08-2013 03:43 PM
Nth degree 3.5" premium lift >>>>>>> MattJK09 JK Wrangler Technical Forum 16 11-30-2009 06:32 PM
Rough country "premium 2.2" shocks. How do they ride ? jcole JK Wrangler Technical Forum 15 07-01-2009 05:20 PM
07 X with 17" premium rims, Goodyear tire failure Justin04TJ JK Wrangler Technical Forum 6 09-19-2007 02:49 PM
Ignition Module: "OE" vs. "Premium" Tshark299 YJ Wrangler Technical Forum 3 01-08-2005 04:29 AM
