AEV 3.5" Premium Lift - JeepForum.com
post #1 of 72 Old 04-27-2011, 08:03 PM Thread Starter
RubiNoob
2010 JK Wrangler
What is / are the biggest reasons NOT to get this lift?
RubiNoob is offline
post #2 of 72 Old 04-27-2011, 08:27 PM
chickenhawk7
cost?
chickenhawk7 is offline
post #3 of 72 Old 04-27-2011, 08:30 PM
BAMAJK
2009 JK Wrangler
I haven't heard any reasons not to, other than it retains the stock control arms, which is not necessarily a bad thing.
BLUE JEEP #237
BAMAJK is offline
post #4 of 72 Old 04-27-2011, 09:17 PM
fishgutz
2010 MK Patriot
Originally Posted by chickenhawk7 View Post
cost?
Ditto.
I fit 37's with a 2.5" Rock Krawler lift.
fishgutz is offline
post #5 of 72 Old 04-27-2011, 09:52 PM
Sweetleader
2009 JK Wrangler
Originally Posted by fishgutz View Post
Ditto.
Big tires on a small lift wont let you get very much articulation however.
Sweetleader is offline
post #6 of 72 Old 04-28-2011, 01:53 AM
1222
RIP John
1222's Avatar
For what you get, quality and performance, I think the AEV Premium kits are priced just right and are one of the best.
(2011-2016)
1222 is offline
post #7 of 72 Old 04-28-2011, 04:59 AM
BLK2000TJ
If your only concern is fitting tires then there are cheaper lift's out there. If you want your Jeep to handle as good if not better than stock on road be very capable off-road then the AEV suspension is hard to beat.
2010 JKU Rubicon 3.5" AEV , AEV Pintlers 35" KM2's , AEV Bumpers, AEV Hood / Snorkel
2008 JKU (Daily Driver)
2000 TJ Auto 4.5 RE Superflex ,35" MTZ 's , Warn ,Viking, LoD, RockHard,AEV, JKS, ARB's, Vanco Big Brake Kit ,Currie etc. etc.etc.
BLK2000TJ is offline
post #8 of 72 Old 04-28-2011, 06:42 AM
aristobrat
2010 JK Wrangler
For me, it seems like most of the things that some consider cons, I consider pros.
For example, a typical con listed goes like this. "For the price, all you're getting is a bunch of brackets. Other lifts, for the same price, give you more adjustable parts". To me, the pro in that statement is those brackets have a ton of engineering behind them to move stock parts to the specific angles that give your JK the ride that AEV is renown for. IMO, adjustable parts alone can't do that.
On the same note, another frequently mentioned con is "AEV lifts are non-adjustable". Somewhat true -- you can switch between 3.5" and 4.5" springs, but that's about it. There is nothing about the lift to adjust or "dial-in" after installation. To me, that's a pro. At the end of installing the lift, your axles are centered and your caster is restored. No messing around trying to find the precise lengths for adjustable trackbars/control arms to achieve those characteristics. To others, that's a con. They want to be able to tweak the characteristics of their ride. For me, it rides awesome immediately post lift, and I wouldn't want to tweak anything.
To address issues that are normally corrected by buying front control arms, AEV uses a control arm drop bracket. This bracket ends up slightly changing the angle of your stock lower control arms, and majorly changes the angle of the upper control arms. The pros are that it addresses a lot of drive issues, like flighty steering, reducing the front-end dive that happens if you nail your breaks, bumps feeling less jarring, less drive-shaft vertical travel, etc. Also, the bushings on the stock control arms are supposed to be better than aftermarket control arms, but I don't have any personal experience with that. The con is that it leaves your front control arms sitting a little below the frame level.
The Premium lifts also include the AEV jack base (which lets you use your stock jack in sand/mud, also lifts your stock jack up so it works with bigger tires) and the AEV ProCal (which reprograms your JK for bigger tire/gears/other features). IMO, both are useful tools and their value should be considered into the price. Even if you don't need them, you can easily resell them and pocket the cash.
I really really really like my AEV 3.5 Premium lift. I love how my JK handles on-road (especially how there's less body roll in corners than stock, even though it sits about 5" higher than stock now), and I've had no problems off-road with it. I'm actually not allowed to lead when my Jeep club goes on trail rides because I barely feel the bumps and ruts that really jar them, so I "go too fast". And granted, I'm Mid-Atlantic, so there's not a bunch of huge West Coast/AZ type of rocks out here, but my 4-door JK with the AEV lift has been able to crawl over everything that other JKs with similar height lifts have.
aristobrat is offline
post #9 of 72 Old 04-28-2011, 06:57 AM
skivviss
2010 JK Wrangler
i am not knocking AEV, or disagreeing (really!) just pointing out the counter point.
on moving mounting locations with brackets instead of adjustable arms/bars. if the load and configuration of your jeep is done when you install the AEV lift and it matches their expected weight and configuration then a bracket is as good as adjustable. but if you install the lift, and then later a bunch of mods that change the weight then the brackets may not be putting the arms and trackbars in the best position. adjustable is adjustable and grows with your jeep mods.
but like aristobrat said, for some that is a con and for some that is a pro.
skivviss is offline
post #10 of 72 Old 04-28-2011, 06:58 AM
smess
Junior Member
2011 JK Wrangler
I had this lift on my previous two jeeps, I now have the teraflex and while the aev is great the teraflex is better. not sure the cost difference between the two but at the end of the day the teraflex is hard to beat with product and customer service.
smess is offline
post #11 of 72 Old 04-28-2011, 07:35 AM
chickenhawk7
Smess, I like your AEV beaklocks though. They look real good on your silver JK.
post #12 of 72 Old 04-28-2011, 07:59 AM Thread Starter
RubiNoob
2010 JK Wrangler
I really like your reasoning here. If I decide to install this lift myself, it will be my first lift install, and I'm afraid I'm just not knowledgeable enough to be able to dial in things to make them just perfect. Alternatively, If I were to have it installed by someone, I don't trust THEM to be able to dial things in perfectly either (there is no 'offroad jeep installer' around me).
I'm curious, I already have a Superchips flashpaq, I believe this can set the tire size, is there any reason for me to keep the ProCal then?
RubiNoob is offline
post #13 of 72 Old 04-28-2011, 09:10 AM
Blu-Jacket
2009 JK Wrangler
The ProCal has other functions, one being the abilitiy to check the centering of the steering wheel post lift. Does the flashpaq have this capability?
Blu-Jacket is offline
post #14 of 72 Old 04-28-2011, 11:30 AM
taoshum
Just installed the kit you are considering. Download the instructions from AEV and read them carefully.
They "recommend" after-market wheels and they "recommend" a smaller front drive shaft. Note "recommend", not "require". It's a subtle play on words with huge $$$ impact.
If you don't get after-market wheels with 4.5" Backspacing, then the OEM wheels need a 1.5" spacer or there's a big chance that the brake lines will rub the tires. Not good if you value operational brakes.
The OEM drive-shaft will interfere with the OEM tranny skidplate at high articulation angles, especially when the driver's side wheel drops. So you either get a new skid plate or a new drive shaft or there's a big chance that you'll damage the front drive shaft at some point.
So, the kit costs about $1700, wheels about $600, drive shaft about $500, might as well get new tires, $1200; so now the kit is up to $4000. Oh, I forgot, new steel brake lines, $300.
Maybe you can figure out a way to get the OEM stuff to work "OK" but be aware of the risks.
BTW: It was my first install as well so I was lucky enough to get help from a friend. It is definitely a two person job and it took us 2 full days. I've put in about 2 more days trying to adjust brake lines and the drive shaft problem. The AEV estimate on time was 6-8 hours, maybe 12 hours for a "novice".
see http://www.jeepforum.com/forum/f96/a...blems-1202968/ for a discussion of the brake stuff. Skidrow has a plate that will clear the drive shaft, BTW... $300 or so.
Other than that, it's great!!!
Geezer from NM
"Wisdom isn't cheap; we pay for it with pain
taoshum is offline
post #15 of 72 Old 04-28-2011, 04:29 PM
1222
RIP John
1222's Avatar
When you lift the JK 3-4 inches no matter what kit you use sooner or latter you will have to replace the front drive shaft. After market wheels or spacers are required on any JK with 35 plus tires with just about any type of lift. When you have as much flex that the AEV kit gives you then yes the drive shaft will make some kind of contact with the tranny pan in extreme situations. I believe that is also true with other kits where the flex is the same. The drive shaft will hit the OE skid if you donít remove it or get an after market skid, which is a good idea anyway. Same is true of other kits with similar capabilities. After market brake lines are not required.
The only hard part is bending the front steel brake lines. If I were to do it over again I would get extended lines for the front instead of bending the OEs.
So, what Iím trying to say is that doing it right is no different than any other kit out there.
(2011-2016)
1222 is offline
Poly Performance Jeep Jk 4" Stage 3 lift versus AEV / Nth degree 3.5 " Premium lift TDmaster JK Wrangler Technical Forum 20 02-08-2013 02:43 PM
AEV / Nth Degree 3.5" Premium Lift mthomp83 JK Wrangler Technical Forum 131 12-15-2011 01:28 PM
AEV 3.5" Premium Lift or Mopar 4" Lift??? CorpJeep JK Wrangler Technical Forum 25 12-30-2010 09:40 AM
Nth degree 3.5" premium lift >>>>>>> MattJK09 JK Wrangler Technical Forum 16 11-30-2009 05:32 PM
Rough country "premium 2.2" shocks. How do they ride ? jcole JK Wrangler Technical Forum 15 07-01-2009 04:20 PM
