AEV 2" Spacer Kit Issues-Front Brake Lines - JeepForum.com
post #1 of 3 Old 08-20-2012, 07:11 AM Thread Starter
rockitdoc
1. Got the rear in ok, but now have some noises coming out from there when I go down bumps in reverse Hmm.
2. Front was another story. NOT fun at all. Still can't figure out how to remove the steel bracket that locates the brake and ABS lines on '10 and newer JK's. The AEV instructions say to remove this and then zip tie the lines to the shock. They show a picture with a vise-grips doing the job of folding the steel bracket back so the brake line can be removed. This is impossible. I tried with various pliers, crowbars, etc, and bent the piece only slightly, but not enuf to remove the brake line. Cutting it is not an option since the brake line would be damaged. Any ideas?
rockitdoc is offline
post #2 of 3 Old 09-07-2012, 05:59 AM
GreenRenegade
Yeah, that was a fun one. Start on one side with the vice grips while the thing is still bolted to the frame. Pull down hard (watch knuckles). It will pull (bend) the whole thing silver edge down towards the bracket. Re-grip if necessary and get on the corner. WATCH BRAKE LINE! Don't pinch. Start pulling down. If the vice grips slip, tighten up a bit and try again. As it spreads, move the vice grips inwards a bit until the whole lip spreads enough to get the line out. It took me a while, but it does work.
2013 Wrangler Rubicon 2dr
GreenRenegade is offline
post #3 of 3 Old 09-07-2012, 06:02 AM
GreenRenegade
Pics
Relocate Front Brake Lines...4" Lift Kit Question glenn-91YJ YJ Wrangler Technical Forum 8 06-17-2010 09:14 PM
Front Brake Lines w/ 2.5" lift. What did you guys do with yours ? fleck JK Wrangler Technical Forum 15 04-07-2010 02:32 PM
front brake lines with 4" lift Tooch YJ Wrangler Technical Forum 0 01-18-2010 11:05 AM
Installing Extended Front Brake Lines (20") thejafe TJ Wrangler Technical Forum 19 02-14-2007 03:08 PM
Front brake lines damonejeep YJ Wrangler Technical Forum 5 09-30-2002 10:32 PM
