AEV 2.5" with GY Duratac 315/70R17 rubbing? - JeepForum.com
post #1 of 26 Old 01-08-2014, 04:18 PM Thread Starter
grangerdw
I am looking at running duratac 315/70R17 on AEV Pintler wheels and AEV 2.5" lift.
Is there any rubbing at either max wheel turn or under extreme articulation?
Thanks!
grangerdw is offline
post #2 of 26 Old 01-08-2014, 05:30 PM
Prot
Prot's Avatar
2014 JK Wrangler
Thanks!
Have a look at the Will it rub? Sticky.
If the backspacing is 4.5" then you will be fine, although 3" lift would be a little better. Are you keeping the stock fenders?
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #3 of 26 Old 01-08-2014, 07:28 PM Thread Starter
grangerdw
I did look there first, must have missed it. I am keeping stock fenders for a while then going to metalcloak over lands. AEV claims 35" x 12.5 tires will not rub but these are a little wider.
I am not stuck in these tires actually. Just looking for an aggressive looking tire that will last for a while on road.
Thank you for the reply
post #4 of 26 Old 01-08-2014, 07:51 PM Thread Starter
grangerdw
Went back and reread the sticky. I can not find where running pintler wheels with 315/70r17 is addressed. I see 35" with stock wheels but thatis a little different. And maybe I am oover thinking this but AEV claims no rubbing with 35" and their wheels which is close but not the same. I am open to their 3.5 and metalcloaks, but am trying to avoid driveshaft issues.
Sorry for the dumb questions but i want to make sure i am spending right the first time.
post #5 of 26 Old 01-08-2014, 08:56 PM
Jared89
2011 JK Wrangler
I don't know if I am reading this right. But a 315/70-17 is Not wider than 35/12.5-17. You might want to try Google it is your friend. All the information is out there and has been covered MANY times. From your post above I don't think you understand a 35/12.5-17 is bigger than a 315/70-17 is every aspect except rim diameter.
2011 rubi- 2.5" teraflex-35" nitto trail grapplers on xd addicts-shrockworks stubby bumper-20" light bar-TF proformance rotor kit - aluminum Psc crusher flares-
Jared89 is offline
post #6 of 26 Old 01-08-2014, 08:56 PM
Prot
Prot's Avatar
2014 JK Wrangler
3" or less you will not have drive shaft issues.
My 2007 had 315/70-17 BFG AT tires which I ultimately replaced with the same size Duratracs. The Duratracs were better in virtually every single way except wear. The BFG's wore like iron compared to my Duratracs showed noticeable wear rather quickly. I still have the Duratracs and they will go on my 2014 whenever I get around to getting the lift installed.
The brand of wheel is of no consequence. The measurement is what matters. Pick your favorite wheel 17" X 9" with 4.5" backspacing and you will be good with 315/70-17 tires. The Duratracs run on the small side, so the 2.5" lift will be fine. Trim the pinch seam. It is worth noting that my 2007 definitely needed to have the pinch seam trimmed but my 2014 is made different and the pinch seam does not stick out in the way therefore no trimming needed. It is like it came pretrimmed.
Also worth noting is many lifts give a little more height than advertised because the manufacturer is accounting for heavy bumpers, winch, etc.
The main thing is to stick with a reputable brand. Install the track bars and brackets loose, with the Jeep in the air. Make adjustments and tighten everything with the Jeep on the ground. This will help you get your axles centered. If this axles are not centered, you will have death wobble. It may take a few changes of underwear before you get rid of the death wobble. With centered axles, setting the toe, checking caster, and proper torque, you will avoid soiled underwear. When I had my 2007, I would keep a spare set of underwear in my glove compartment. It was that horrible until I got it figured out.
Prot is offline
post #7 of 26 Old 01-08-2014, 09:21 PM Thread Starter
grangerdw
Thank you for the response, if it only consisted of giving me crap about asking a question. From my google search, prior to posting, I learned the duratac 315/70R17 is actually 34.4" and 12.7" wide per the goodyear website. Or, put another way, .4" smaller and .2" WIDER than a BFG MT KM2.
The question is, will the somewhat smaller, yet wider tire rub at either full compression or full wheel turn.
Not trying to be an ***, but I did research this a bit before posting here.
Cheers,
granger
post #8 of 26 Old 01-08-2014, 09:25 PM Thread Starter
grangerdw
Great information and thank you very much!
The pintler wheels are only 8.5" wide. Not sure how much of a difference that will make?
great quote.
btw, same color 2014 I am working with. Copperhead Pearl is a great choice!
post #9 of 26 Old 01-08-2014, 09:27 PM
PapaFu
I'm running exact same set up on 2013 JKU - stock bumper and fenders - with no issues. Just installed the AEV Dual Sport and have the 315/70/17 duratracs on Mickey Thompsons Classic Baja Lock 17x9 wheels with 4.5" back spacing (zero offset). The duratracs are 34.4" actual size in diameter. No other mods needed (re: pinching seams, etc referenced above). I did re-gear from 3.21 to 4.56 to compensate for added weight of tire. Mostly because I'm in hilly/mountains a good bit.
PapaFu is offline
post #10 of 26 Old 01-08-2014, 09:42 PM
JTPhoto
JTPhoto's Avatar
AEV Pintler wheels are listed on AEV website as 5.2" backspace. I am thinking that's a rub on the control arms unless the the AEV lower arms are curved in enough to avoid rub.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #11 of 26 Old 01-08-2014, 09:45 PM Thread Starter
grangerdw
Awesome, thanks!!!
post #12 of 26 Old 01-08-2014, 09:46 PM Thread Starter
grangerdw
Nice catch. Anyone have experience with these wheels, or at least ones with similar backspace?
post #13 of 26 Old 01-08-2014, 10:06 PM
PapaFu
Weird. Their site also lists the offset as +10mm. On a 8.5" width, zero offset should be 4.25" backspace with +10mm equal to 4.62" back spacing?? For what it is worth, the owner of the shop that did my work put the same AEV 2.5" lift on his wife's JKU and said she has the Pintler wheels as well. Not sure which wheels, but he mentioned she had 35s.
PapaFu is offline
post #14 of 26 Old 01-08-2014, 10:13 PM
jimk403
2009 JK Wrangler
You will eventually have driveshaft issues. It may take longer to manifest itself at only 2.5", but eventually you will need at least a new front shaft.
I suggest doing more research on tires before drinking the Duratrac kool-aid. I had them, but won't run them again, ever.
Just my opinion, yours will differ.
Proud owner of: '09 Rubicon Unlimited, '90 XJ, '88 XJ, '77 J-10
jimk403 is offline
post #15 of 26 Old 01-08-2014, 10:19 PM
PapaFu
How are the tires going to contribute to drive shaft issues (vs another tire of same size/weight)?
PapaFu is offline
