AEV 2.5 on 35s - Page 3 - JeepForum.com
post #31 of 33 Old 10-12-2013, 10:07 AM
mudb8
want it rite or rite now?
mudb8's Avatar
Who can show me a worn out axle end or frame end flex joint on a stock JK track bar? They dont bend either unless they get yanked on as a recovery point.
Steering kits and trackbar relocation from aev utilize factory components for a reason. Having those componets will allow full use of long travel shocks without binding up steering links that 2.5" lifts are limited by without further modification.
Nth degree recognized these things early on and produced parts that work and utilize proven components. 4" of lift with near stock geometry including draglink and track bar angles.... Go figure.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #32 of 33 Old 10-12-2013, 10:08 AM
JTPhoto
JTPhoto's Avatar
Originally Posted by brianjw
I guess I'll find out soon, when my metalcloak arms show up for my aev 3.5" lift. The advantage of having near level lower control arms is obvious, but I'm going to see how much the ride changes without the brackets.
The biggest difference I noticed is the road shock when hitting road cracks and potholes. The brackets definitely made them less noticeable.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #33 of 33 Old 10-12-2013, 10:55 AM
brianjw
I actually ordered all but the front lower controls initially with the intention of retaining the brackets, but it seemed stupid. I would not really be taking advantage of the control arms if I didn't use them all anyway. Plus If I recall correctly the metalcloak front lower arms can't be adjusted to stock length. I can't really move the front axle around much with the larger diameter aev springs, synergy sector shaft brace etc, tight clearance in there and moving things around more may create an issue.
brianjw is offline
