AEV 2.5” on 35’s - Page 2 - JeepForum.com
post #16 of 33 Old 10-10-2013, 12:17 PM
ROCKR8R
Originally Posted by RyanE5 View Post
Why don't you like the AEV 3.5"? Right now I'm between the AEV 2.5", AEV 3.5", and RK 2.5" Max Flex (which I hear is more like a 3.5"+).
Because once you get that height, I don’t like my Jeep being held together by brackets. Also if ever you wanted to grow from that lift you end up throwing most of the components away, so you spend money twice.
I would want adjustable control arms instead of AEV’s drop brackets
I would want an adjustable front trackbar instead of AEV’s “bent OE” one
I would want sway bar quick disconnects
I would want extended brake lines instead of or in addition to drop brackets
The good about the kit is it is priced WITH shocks, a high steer kit and a Procal.
-Dan
ROCKR8R is offline
post #17 of 33 Old 10-10-2013, 01:59 PM Thread Starter
RyanE5
-Dan
Thanks for your input. Now I'm between the AEV 2.5 and RK 2.5 Max Flex, the RK is about $500 more after the add-ins are tallied up. I'm leaning more towards the AEV to keep the height a little lower.
2012 JK Rubicon, Crush. RK 1.5" Max Travel, Bilstein 5100, 35" MTZ.
RyanE5 is offline
post #18 of 33 Old 10-10-2013, 02:07 PM
MoonyJohn
MoonyJohn's Avatar
AEV will ride best. I have the 2.5" with bilsteins and it rides awesome even with no weight added like a winch and bumper
MoonyJohn is offline
post #19 of 33 Old 10-10-2013, 02:44 PM
ROCKR8R
The Rock Krawler kit also comes with lower control arms. Got to decide if that is worth the money to you or not. If I was shopping for a kit again, I would get the RK 2.5" Max too.
As far as AEV riding better...That is opinion based. The RK kit will ride just as good. I had my pieced together kit riding well too.
-Dan
ROCKR8R is offline
post #20 of 33 Old 10-10-2013, 06:15 PM
gillbot
I was going to put 35's on my 2dr till everyone started telling me it might rub without at least 2" of lift. I've been trying to trade my 35's off for 32/33's but so far no takers. I just don't want to get into a lift yet.
gillbot is offline
post #21 of 33 Old 10-10-2013, 07:00 PM
ROCKR8R
How about a leveling kit? You can fit 35's but you will have to trim fenders or buy flats. Also trim pinch seam and rock tails if it is a Rubicon.
You can get into this http://www.roughcountry.com/jeep-sus...kit-634-7.html
or this http://www.roughcountry.com/jeep-sus...-kit-651c.html
-Dan
ROCKR8R is offline
post #22 of 33 Old 10-10-2013, 07:49 PM
gillbot
I already put JKU Rubi 18/59 springs on it. I'm not sure I want to add more lift, trim fenders, bumper and all that. It's just a base Sport that won't see much off road so I don't think the effort to fit 35's is worth it when a 32/33 will be plenty without having to lift it.
gillbot is offline
post #23 of 33 Old 10-11-2013, 05:40 AM
SoK66
2009 JK Wrangler
I put an AEV 2.5" with drop brackets on a club member's 2010 JKUR. I was impressed with the end result. She's running 33s right now but a regear and 35s may come later. As soon as it was on there she came over to Moab with us and ran Behind The Rocks with no issues at all. What I like about it is the retention of stock drivelines, no steering or front & rear pinion angle correction needed and good flex characteristics. Great value, too, considering the overall performance vs some of the el cheapo kits out there.
SoK66 is offline
post #24 of 33 Old 10-11-2013, 06:47 AM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
AEV 3.5" here and added extended brake lines. 2 years and 14k miles later ZERO issues.
Sent from my over priced iPhone.
PhatBasturd is offline
post #25 of 33 Old 10-11-2013, 09:40 AM
ROCKR8R
Well typically you don't have a lot of issues with a 2.5" kit. The 2.5" AEV kit is a good kit.
-Dan
ROCKR8R is offline
post #26 of 33 Old 10-11-2013, 09:43 AM
ROCKR8R
No one is saying it is plagued with issues. I just desire more out of a lift at that height. For the price of the AEV 3.5 and 4.5” lifts you can get other brands that come with lower control arms, adjustable trackbar, sway bar disconnects etc…
-Dan
ROCKR8R is offline
post #27 of 33 Old 10-11-2013, 09:57 AM
PhatBasturd
1976 CJ7
-Dan
Never said anybody said that. Just posting my experience with 3.5" of AEV brackets.
post #28 of 33 Old 10-11-2013, 11:42 AM
JTPhoto
JTPhoto's Avatar
There was a huge difference in ride quality when I added the Geo brackets to my 3.5" lift. Handling was never an issue before or after. The geo brackets change the angle of the control arms, adjustable control arms do nothing to address that angle. The only thing that can match that angle is a long arm kit where the control arm brackets are moved to a new location.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #29 of 33 Old 10-12-2013, 10:01 AM
SoK66
2009 JK Wrangler
Correct, the drop brackets like AEV uses approximate the same control arm angles you'd get with a long arm. TnT Customs makes some that are more robust than AEVs, and just like the AEV brackets can be retrofited to any short arm suspension.
Whether using front end drop brackets or a full blown long arm conversion, the improvement in stability, ride quality & handling needs to be experienced. Slight loss in ground clearance but a relatively minor issue real world.
SoK66 is offline
post #30 of 33 Old 10-12-2013, 11:05 AM
brianjw
I guess I'll find out soon, when my metalcloak arms show up for my aev 3.5" lift. The advantage of having near level lower control arms is obvious, but I'm going to see how much the ride changes without the brackets.
brianjw is offline
