AEV 2.5 on 35s - JeepForum.com
post #1 of 33 Old 10-07-2013, 12:23 PM Thread Starter
RyanE5
AEV 2.5 on 35s
I have a 2012 JKR and I want 35s without spending an absolute fortune. A spring lift (rather than a BB) looks like a good idea because I think that will help eliminate the brake dive that the stock suspension has. This is a daily driver with some off roading, so a good on road ride is important. Im thinking the AEV 2.5 lift is what I want, but Im not sure if 35s will fit. Many of the Jeeps I see have 35s and the AEV 3.5 or RK 2.5 (which is 3.5+). Id like to stay as low as I can while keeping the stock fenders. Will the AEV 2.5 fit 35s?
2012 JK Rubicon, Crush. RK 1.5" Max Travel, Bilstein 5100, 35" MTZ.
RyanE5 is offline
post #2 of 33 Old 10-07-2013, 02:38 PM
sean0168
2014 JK Wrangler
That is the exact set up I have and it works fine
sean0168 is offline
post #3 of 33 Old 10-07-2013, 05:32 PM
jeremylj1972
AEV 2.5 With 315s (basically 35s)
jeremylj1972 is offline
post #4 of 33 Old 10-07-2013, 05:46 PM
MoonyJohn
2.5 here with flats and with regular flares. Both cleared perfectly fine when flexing
MoonyJohn is offline
post #5 of 33 Old 10-08-2013, 11:46 AM
rha600
AEV 2.5" and 35" (or so they say) MTs.
And some super cool flexing here in South Florida. haha. I got bored one day at lunch, but at least it will give you some sort of idea.
rha600 is offline
post #6 of 33 Old 10-08-2013, 04:26 PM
ROCKR8R
http://www.quadratec.com/products/16190_2500_07.htm
Less expensive than the AEV. Does wonders.
-Dan
ROCKR8R is offline
post #7 of 33 Old 10-08-2013, 06:46 PM
brianjw
-Dan
Barely cheaper, not progressive springs, cheapo teraflex shocks vs Bilstien shocks.
brianjw is offline
post #8 of 33 Old 10-08-2013, 08:34 PM Thread Starter
RyanE5
Why did you get the flat fenders if they cleared the regular ones?
RyanE5 is offline
post #9 of 33 Old 10-09-2013, 08:52 AM
ROCKR8R
Another option that will still do the trick.
-Dan
ROCKR8R is offline
post #10 of 33 Old 10-09-2013, 10:57 AM Thread Starter
RyanE5
-Dan
See, this is what makes me wonder... ROCKR8R has 35's and a Teraflex 3.5" lift, MoonyJohn has AEV 2.5" but added flat fenders.
But they both say 2.5" is good.
If I get the 2.5" will I end up changing it later? Should I just get the AEV 3.5 from the start??
RyanE5 is offline
post #11 of 33 Old 10-09-2013, 11:04 AM Thread Starter
RyanE5
deleted
RyanE5 is offline
post #12 of 33 Old 10-09-2013, 05:39 PM
MoonyJohn
I cut down the stocks and the police pulled me over for a fix it ticket, so I bought bushies. Would have prefered the stocks though.
post #13 of 33 Old 10-09-2013, 06:00 PM
ROCKR8R
I added height because I am crazy. My lift started life as a 2.5" TF. I was going to go 37's prior to selling my Jeep. Which is why I went taller and cut my fenders. I do not like the AEV 3.5 and 4.5 lift, so no I wouldn't say go for an AEV 3.5". Plus going higher is a whole 'nother ball game. You can build off the AEV 2.5" if you wish in the future.
For my 3.5" of height I added adjustable control arms and aftermarket driveshafts.
-Dan
ROCKR8R is offline
post #14 of 33 Old 10-09-2013, 07:59 PM Thread Starter
RyanE5
-Dan
Why don't you like the AEV 3.5"? Right now I'm between the AEV 2.5", AEV 3.5", and RK 2.5" Max Flex (which I hear is more like a 3.5"+).
RyanE5 is offline
post #15 of 33 Old 10-10-2013, 06:00 AM
bhoch
RyanE5 - here is my '12 JK with the RK 2.5" Max Flex - I netted about ~3.25" front and ~3" rear when I installed this. It's sitting on 33's till I need need new tires, then will be on 35's.
Sorry it's the only pic I can find currently...
bhoch is offline
