Advice on Jeep Rubicon 2012 2 door - JeepForum.com
post #1 of 3 Old 03-11-2013, 07:16 PM Thread Starter
ncuglieva
I have a rubicon 2012 automatic gear that i use for offroad here in peru, we have desert with very big dunes, i have upgrade my jeep with a 2.5 lift with king shocks i olso have a Genright suplementary tank with 20 galons and mikey thompson 33 tires, my problem is that when i go in Hi i get into the cut of the dune with to much rpm and when i go on Low i cant pass 40 mph, what options do i have to change my transfer case?
ncuglieva is offline
post #2 of 3 Old 03-11-2013, 07:35 PM
awinski
what do you mean too much rpm? are you saying you are at a high rpm? if so i don't see the problem. there shouldn't be any reason to change transfer cases and you also shouldn't be doing any sort of high speed in 4 low. if anything, a differential gear change is what you're after.
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #3 of 3 Old 03-11-2013, 08:12 PM
Ruby_Tuesday
I think a rubi transfer case is a direct swap for a non rubi case.
Ruby_Tuesday is offline
