Adjustable rear track bar/ bracket question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Adjustable rear track bar/ bracket question
Year End Clearance Sale! Save 20%Santa Kolak Announces: Kolak Exhaust 20% Off Sale!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO
Unread 11-07-2014, 09:00 PM   #1
Vetteguy
A few months ago I put an OME 4" lift on my 2012 4dr Rubicon. It came with a rear track bar relocation bracket. I now have an adjustable rear track bar I'm plan on installing. The question I have.
Remove the bracket and install the adjustable bar? OR
Keep the bracket AND install the adjustable bar?
Thanks
Vetteguy is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 09:22 PM   #2
cmsorey
Beach goer
cmsorey's Avatar
I'd keep it on there for a rainy day never know u might go bigger, and I'm pretty sure it's on there to correct the angles of the lift for flex
cmsorey is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 11:24 PM   #3
LVCapo
The Voice of Reason
LVCapo's Avatar
Keep the bracket and add the adjustable track bar. The stock brackets are a real weak point. Even a bolt on aftermarket bracket adds strength to the setup.
LVCapo is offline   Reply With Quote Quick reply to this message
Unread 11-07-2014, 11:37 PM   #4
jwmbishop
2011 JK Wrangler
Ideally - to maintain roll center - if you widen the track width with less backspace - the track bar should be made longer to return the same proportion of track bar length to track width... AND should be close to level (axle side slightly below frame side) when sitting at curb height.
Sometimes this means both...
J Wm Bishop EA, ASADE
Alcohol - because great stories never run on gasoline...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 07:07 AM   #5
JLH
2015 JK Wrangler
Like what Jwmbishop said, keep the trackbar bracket to help maintain the roll center. This Teraflex video touches on why raising the trackbar location is important. Fast forward to about 0:50 in the video if you want to skip the nonsense.
https://www.youtube.com/watch?v=AKUoyukFhoo
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
JLH is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 07:12 AM   #6
Vetteguy
Thanks guys
That's what I was thinking, but wanted others opinion on the matter!
