Adjustable Ball Joint & Camber & A bent axle?? - JeepForum.com
post #1 of 24 Old 09-02-2010, 02:28 PM Thread Starter
muttytruckster
So I did a google search of an adjustable ball joint for the JK and I found another forum that repeatably said that if your camber is out of tolerance you have a bent axle, most likely the 'C' Is this true or just BS?
Couldn't a worn ball joint cause the camber to be out???
Since my camber is out (-0.80 degrees driverside and -1.0degrees passenger side) and I have only wheeled slightly hard on my stock rubicon wheels and tires, I just don't see how I could of bent my axle thus why I am questioning it?
Also I have been doing searches for adjustable ball joints, so if anyone is using a set and they have their feeling/experience with them, I am all ears. Or all eyes in this case.
2007 Jeep Wrangler Unlimited Rubicon -JKUR
Rescue Green 6-Spd, 33" KM2s- 17 x 8 BlackRock Series 909 wheels, Stainless Steel Gibson Exhaust & AFE Air Intake, Superchips, Aberle Front Bumper&10.5K Winch, PiAA ATP Lights
muttytruckster is offline
post #2 of 24 Old 09-02-2010, 02:38 PM
tjkj2002
2002 KJ Liberty
Have you checked your ball joints? They may be bad but if they are tight then yes something is bent.I have never seen a adjustable balljoint for a solid axle like what the JK uses keep it's adjustment or last very long.
tjkj2002 is offline
post #3 of 24 Old 09-02-2010, 02:47 PM Thread Starter
muttytruckster
Wait I am confused?? I thought if they were bad then there was play in them thus they won't be tight.
post #4 of 24 Old 09-02-2010, 05:01 PM
KPJ
2010 JK Wrangler
He is agreeing with your statement. You are missreading his post.
Tp paraphrase to make it clearer: If your current ball joints are tight, then something is bent.
JPK
KPJ is offline
post #5 of 24 Old 09-03-2010, 07:49 AM
Tireguy
2009 JK Wrangler
Here is the answer...
http://www.power-21.com/federalmogul...D%20VIN%201&t=
Adjustable ball joint by Federal Mogul/Moog...
Part# is K7403..covers several models of Jeep.
Tireguy is offline
post #6 of 24 Old 09-10-2010, 11:36 AM Thread Starter
muttytruckster
Since I haven't had a chance to see for myself if my ball joints are slightly bad, lets just assume they are fine. I have measured the distance between my level concret floor to the bottom of the front axle tube on the passenger side, I also did the same to the driver side and the measurements are dead on. Which would leave me the 'C' on the each end of the axle. Aside from replacing the whole axle. Is there anything I can do to RECTIFY the small bend. Keep in mind I have a caster on Passenger of -1.0 and on driverside of -.80.
post #7 of 24 Old 09-10-2010, 11:52 AM
tavic
2010 JK Wrangler
If it's only a small bend, sometimes sleeving the axle housing will straighten them back up. Not to mention sleeves help prevent bending.
tavic is offline
post #8 of 24 Old 09-10-2010, 12:02 PM
Ajaxxx
2010 JK Wrangler
My front axle was at -0.7 of camber on the driver side from the factory. I had everything checked at 200 miles. I'm going to get a 1 upper ball joint to get the camber positive and stop the Jeep from pulling.
IowaAndy
Ajaxxx is offline
post #9 of 24 Old 09-10-2010, 01:02 PM
KPJ
2010 JK Wrangler
I think that you would need to also measure somewhere toward the center of the tube to the floor to determine if the tube is bent.
To picture this, think of a telephone or power cable strung between poles. X distance from each pole it may be the same height off the ground, but it is sagging in the center...
JPK
KPJ is offline
post #10 of 24 Old 09-10-2010, 07:14 PM Thread Starter
muttytruckster
I am curious in your experience. If your jeep was new why did you get an alignment. I curious because I did some off roading only with the stock wheels and tires and I didn't do any three wheeling. See profile pictures
IowaAndy
post #11 of 24 Old 09-10-2010, 07:32 PM
USAntigoon
Retired from Forum
So what is wrong.. Is it puling to one side..? ...
What makes you believe the camber is the culprit.. What are the alignment readings (done professionally).. Pulling to one side might have other root causes..!!!!
USAntigoon is offline
post #12 of 24 Old 09-10-2010, 09:12 PM Thread Starter
muttytruckster
No its not pulling..... I had it alignedby a shop with a brand new laser alignment system...and they said my caster is off.... driver side -.08 and -1.0 passenger side....according to people above..... its either a bad ball joint or something is bent..
post #13 of 24 Old 09-10-2010, 09:16 PM
KPJ
2010 JK Wrangler
Camber isn't the culprit, it is the symptom. It is a symptom of a bent axle tube, or C's.
JPK
KPJ is offline
post #14 of 24 Old 09-10-2010, 09:34 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
OK, I am confused - is it caster or camber - two different things...the OP is mentioning Camber which is an indication of bent axle, bent C or bad ball joints. Caster is another animal and I think you got them mixed up because they don't sound like caster numbers. there are ball joints that can be installed to correct the camber, but if the angle was caused by a bent axle or C, then it just corrects and does not fix the bending problem...also, I am not sure that the amount of difference in your numbers is critical - someone with more knowledge chime in - what does it matter that one is -1.0 and the other -0.8 - seems pretty small to me to cause a problem...could be manufacturing tolerance?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #15 of 24 Old 09-10-2010, 11:39 PM
Warlord2
I agree .2 is hardly anything and can even be a calibration error. All the people that I have seen with bent axles or C's can actually see it with the naked eye and it usually takes some hard wheelin with atleast 35" tires. Like seriously, I have landed HARD (digging my bumper) on my front end while jumping the dunes and still havent seen a bend yet.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
alignment , ball joints , camber , front axle problem , JK Wrangler , wrangler
Need camber adjust - Is there an adjustable ball joint avail? Randynet TJ Wrangler Technical Forum 5 03-04-2012 07:14 PM
adjustable ball joint kit05 TJ Wrangler Technical Forum 1 09-05-2009 01:52 PM
caster/camber offset ball joint? any one else have these? DUGA BOY TJ Wrangler Technical Forum 4 05-06-2009 11:40 AM
Ball Joint Camber ??? dawnskaybug TJ Wrangler Technical Forum 18 07-07-2007 12:47 AM
Adjustable ball joint and fixing bent axle MeGAMoE TJ Wrangler Technical Forum 2 10-03-2006 11:23 AM
