Adding Teraflex Leveling kit and Rubicon JKU shocks and springs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Adding Teraflex Leveling kit and Rubicon JKU shocks and springs
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 03-25-2014, 09:20 AM   #1
DeVo24
I have an almost completely stock 08 JK X. I got the Teraflex kit for xmas and was waiting for warm weather to put it on, just a tiny bump up. Then I tripped over some brand new JKU Rubicon springs and shocks on Craig's list for a steal. The wheels started turning and I got em. Im going from 12/54 to 18/59, or roughly that at least. Everything I've read the install seems pretty simple, too simple. I did have one other Forum tell me that my track bar MAY be too short when Im done. Has anyone run a combo like this? It's my DD so I have to get it done in one weekend and having to wait on unexpectedly needed parts could be a problem. Any advise is appreciated.
DeVo24 is offline   Reply With Quote
Unread 03-25-2014, 09:48 AM   #2
ROCKR8R
I am assuming you got the spacer leveling kit? Yes you can run Rubi springs/shocks and your pucks. You may gain an 1" or 1.5" with the Rubi items then the leveling kit will lift the front to level it out. When all said and done you may have 2" of height gained and a leveled rig, should look good. Throw on some 33's and you will be good to go. I doubt you run into track bar problems. Some people do not need them with a 2.5" lift.
-Dan
ROCKR8R is offline   Reply With Quote
Unread 03-25-2014, 10:06 AM   #3
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
IMO you do not NEED track bar adjustment at 2.5 inches, but the axle WILL be off center. It is just a mater of what you will accept for an incomplete lift.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 03-25-2014, 11:28 PM   #4
DeVo24
So would it be correct to say that if I want everything to line up perfect I should go with the new track bar? Front and rear? Also since it looks like im going to get 2-2.5 inches based on estimates would a track bar made for 2.5-6" be useless or just an unnecessary upgrade. Considering its my DD id rather get one and return it than not have it and have to wait. Id also like to do this once......until I break something.
Unread 03-26-2014, 05:13 AM   #5
jddausch
I'm running the same set up on my 2012 Sahara, no issues. I'm only running one front spacer, it's all I needed with the 18/59 swap. May need to put the other one back in after winch install this week
'91 YJ 4 banger
'94 YJ 4.0L
'84 CJ7 258 I6
'12 JK Sahara
jddausch is offline   Reply With Quote
Unread 03-26-2014, 07:00 AM   #6
COLOUXJ
2010 JK Wrangler
It would be pretty much useless. I am running a stock front trackbar at 3" of lift and I cannot tell the axle is off center by looking at it.
"When i die, bury me with my jeep. Its never been in a hole it can't get out of"
Black Jeep Society
My JEEP helped win a War > Your Honda mows my grass!!
Mechanical Engineers Build weapons Civil Engineers build targets
Originally Posted by cyberpyrot View Post
is it a plink plink kerrrrdunk? or more of a brrrrrconk doc doc miiiidge pang!!!? or is it a badonk ka donk? if it is the latter its just the normal fat *** of the JK
COLOUXJ is offline   Reply With Quote
Unread 03-26-2014, 02:12 PM   #7
DeVo24
Did you put it all on at once and did it mess with your alignment at all? I can't find it now but I read one post about having to get an alignment after putting on the leveling kit but I only saw it once.
Unread 03-27-2014, 12:11 PM   #8
WAC_Jeeper
WAC_Jeeper's Avatar
You may need to re center the steering wheel. This can be done with a pipe wrench to adjust the drag link. That's it as far as alignment for this application.
12 JKR 2 door, MCE Gen III Flares, Teraflex 1.5" Perfomance Leveling kit, 35" MTRs, ARB bars front/rear, ARB diff covers, ARB Dual Compressor, AEV DOT-compliant beadlocks, Warn Zeon 8
97 TJ, MCE fenders and flares, heavily used and reliable on 35's.
MCE, LLC
Patented Off-Road Plastic "FLEXIBLE FENDER" - made in the USA - A Modern Twist on a Classic Icon
www.flexiblefenders.com
***LIKE us on Facebook! http://www.facebook.com/pages/Bothel...547844?ref=sgm***
WAC_Jeeper is offline   Reply With Quote
