Adding extra front tow hooks upside down? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Adding extra front tow hooks upside down?
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-08-2015, 07:31 AM   #1
muffpuff
2009 JK Wrangler
So the other day I was at the dump throwing stuff out, and there was a full set of factory painted fender flares in my color, and a complete front bumper including the tow hooks.
I'm wondering if I can take those tow hooks and put them on my Jeep, facing downwards. So there are sort of a mirror image arrangement, as it were, with four hooks instead of just two.
It looks like I would have to cut holes in the bottom of the bumper similar to the ones in the top, and I can do that. Whether they will attach is the question.
Before I start wrenching to find out, does anyone know the answer? Is the hole pattern such that they would fit?
Are the stock bolts long enough?
muffpuff is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 07:52 AM   #2
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
Why would you want them facing down?
Those "tow" hooks would turn into "terrain" hooks and catch anything you run over and need to back off from.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Fox 2.0 shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
"Don't give up 5 minutes before the miracle occurs."
HappyTrails is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 09:43 AM   #3
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
For pulling little sissy rocks out of the way to get to the big juicy ones?
How does an open hook aiming down hold the strap loop when tension goes away? I would think it would just fall off!
But to answer at least some of the question - you would have to stack em and the oem bolt would then be too short...
J Wm Bishop EA, ASADE
I am a LEADER - not a FOLLOWER. Unless its a really steep hill with a good chance of falling off the mountain - then screw that YOU'RE going first...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 02:54 PM   #4
muffpuff
2009 JK Wrangler
It's only a couple of inches, I don't think they will hang me up. I just thought it would be useful if a hook broke.
Does the hole pattern prevent mounting them upside down? And would a grade 8bolt be strong enough?
Unread 01-08-2015, 06:32 PM   #5
1222
Make mine a Jeep!
1222's Avatar
Not the answer you’re looking for but not all ideas are good ones and some just need to go straight to the trash. This is not meant to be an insult; many of my own great ideas have landed there.
1222 is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 07:13 PM   #6
222Doc
222Doc's Avatar
or you could use it to recover fishing nets?
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 06:25 PM   #7
muffpuff
2009 JK Wrangler
Two fish cracks in one day!!
Unread 01-09-2015, 07:00 PM   #8
muffpuff
2009 JK Wrangler
And the actual answer to the question I actually asked is no.
Not because you think it's a dumb idea, or because it might catch brush, but because the bolt holes aren't in a rectangle but a rhombus. So when I turn the hook plate upside down in a vertical plane, the (now) top holes are too wide apart and the (now) bottom ones are too close together.
Thank you for your help!
Unread 01-09-2015, 07:28 PM   #9
SLADE
Actually, your lucky that those who actually answered your question had actual constructive criticism and was actually sensible with their response to an idea that they actually thought was rather bad regardless if the holes actually lined up or not....
I hope I actually helped.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
