Actual stock rim width - 17x7.5 or 17x8 - JeepForum.com
post #1 of 17 Old 08-31-2012, 02:32 PM Thread Starter
Gomofast
Gomofast's Avatar
Most people on here say that the stock JK 17 inch rims are 17x7.5 however the build sheet on my '08 JK Unlimited X states that they are 17x8. So what gives?
Forgive me if this has been covered already. I've searched but haven't been able to find the answer.
08 JK Unlimited X, 2" Black Diamond lift, 33's, 1.5" wheel spacers, stubby bumper mod.
98 TJ Sport, 4" Rough Country Lift, homemade discos,
35" BFG Mud Terrain T/A KM's, 4.56 gears, Detroit Truetrac
up front, factory Trac-Lok out back,Warn M8274 8000lb
winch, York OBA, rock guards, custom intake, 48" HI Lift.
Gomofast is offline
post #2 of 17 Old 09-01-2012, 09:49 PM
lowendrider
2011 JK Wrangler
I have a set of takeoff 17" Moabs from a '10 model and they are clearly stamped on the back 17x7.5
lowendrider is offline
post #3 of 17 Old 09-02-2012, 01:42 AM
aldaman
Yup, they are 17x7.5" with 6.25" backspacing.....
aldaman is offline
post #4 of 17 Old 09-02-2012, 07:01 AM
Jeepedjeep
all 2013 rubicons are 17x8 it says on my build sheet and I called
Jeepedjeep is offline
post #5 of 17 Old 09-02-2012, 02:24 PM
LVCapo
2015 JK Wrangler
Yeah, we've had this discussion on here before and it left a lot of people scratching their heads....I had an '07 and it was 17x7.5/6.25" BS.....a lot of other people confirmed this.....and then others started posting that they had 17x8/5.5" BS. Maybe there are/were two different rims produced, maybe different years (most that had the 17x8 were '10 owners)?
LVCapo is offline
post #6 of 17 Old 09-02-2012, 03:11 PM
Jeepedjeep
I that's why I called and was like ? When I saw 17x8 on my build sheet
post #7 of 17 Old 09-02-2012, 03:23 PM Thread Starter
Gomofast
Gomofast's Avatar
Where on the back are they stamped? Can you see it with a tire mounted on the rim? I will check mine when I pick up the jeep on Tuesday.
Gomofast is offline
post #8 of 17 Old 09-02-2012, 03:29 PM Thread Starter
Gomofast
Gomofast's Avatar
Interesting. The build sheets I have are for an 08 and an 09 and they both say 17x8. I am picking up the 08 on Tues, so I will check to see if they are marked.
Gomofast is offline
post #9 of 17 Old 09-02-2012, 08:10 PM
lowendrider
2011 JK Wrangler
The wheels I have don't have tires mounted at the moment but if I remember right its on the backside where the spokes are. I think with a flashlight and the wheel in the right position it should be visible with tires mounted and on the Jeep.
post #10 of 17 Old 09-02-2012, 08:47 PM Thread Starter
Gomofast
Gomofast's Avatar
Ok I'll take a look.
Gomofast is offline
post #11 of 17 Old 09-04-2012, 08:52 AM
WXman
The stock wheels are stamped 17x7.5"... and 44.45mm offset. This translates to 6.0" of backspacing, NOT 6.25" like is commonly and falsely spread around the forums.
The stock base wheels are 16x7.0" and the offset isn't stamped onto them but when I measured them myself I got 5.75" of backspacing.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #12 of 17 Old 09-04-2012, 06:31 PM
LVCapo
2015 JK Wrangler
I got my information directly from Chrysler stud....so if anyone is spreading false information, its the manufacturer
LVCapo is offline
post #13 of 17 Old 09-12-2012, 02:33 PM Thread Starter
Gomofast
Gomofast's Avatar
I checked mine, and just as WXman said, they are marked "17x7.5" and "44.45 offset", even though my build sheet specifically says 17x8 wheels.
So that's where the confusion comes from. As Capper5016 said, "if anyone is spreading false information, its the manufacturer"
I suppose the only way to know for sure would be to measure them, but my guess is that the info cast into the wheel is probably correct.
Gomofast is offline
post #14 of 17 Old 09-17-2012, 08:09 PM
djm
My window sticker only says 17 inch wheels. The build sheet specifically says 17 x 8 inch wheels. I looked at the back of my spare tire/wheel and the wheel is stamped 17.5
I'm sure that clears everything up !
Dan - NJ
djm is offline
post #15 of 17 Old 12-01-2016, 11:08 AM
JeepersRKeepers
Stock wheel width...
I've seen a lot of stuff about whether the stock jeep wheels are 7.5" or 8". On my 2016, the stock Wrangler Sport S, the wheels are in fact 7.5" wide. With that you could theoretically run a tire as big as a 285 70 17 (33") on the stock wheel, but you'll probably need wheel spacers/adapters to kick the wheels out to avoid rubbing the lower sway bar links (Jeep). And you'll probably want to think about a lift kit, at least 2.5" minimum, again to avoid rubbing and suspension issues. In my opinion, when it comes to the numbers, one word explains the differences... ROUNDING. It's not uncommon when there is a decimal situation on automotive specs for manufacturers to round their numbers up or down. For example, the actual displacement of a Chevy 350, 5.7 litre is a little less than that. For the most part, numbers are rounded for marketing purposes and to describe a vehicle's general specifications. Additionally, would a Ford Mustang be nearly as cool if instead of a 5.0 badge it was 4.896 c.i.? Usually the number is rounded up or down to the nearest tenth to meet truth in advertising requirements and reflect approximate vehicle specs. Of course bigger, wider, whatever is better right? Remember car makers want to sell cars, so if having an 8" wheel is more desireable than 7.5"or a 5.0, 5.7 Hemi, or 6.6L diesel is perceived as better or cooler... well you know how that will work out. Remember too that 7.5 does round up to 8.0", so technically for general purposes the slight difference is acceptable. Nobodies being dishonest here. Where it gets tricky though is when you want to know the exactly what you've got when trying to determine fitment of aftermarket parts: tires, suspension systems, brakes etc. At that point knowing the exact measurements becomes super important especially when modifying a vehicle with non OEM parts. Again, this is my opinion, but maybe it will clear up a few things. OIIIIIIIO
JeepersRKeepers is offline
17x7.5 , 17x8 , rims , stock , wheels
full width front with stock width rear? redrubi03 YJ Wrangler Technical Forum 28 01-23-2012 05:46 AM
TJ--axels--full width vs. stock width smithcon TJ Wrangler Technical Forum 2 06-05-2010 05:19 PM
35x12.5 on 17x7.5 stock rims sicmopar JK Wrangler Technical Forum 6 04-11-2010 01:05 PM
Xenon tube style rear flare actual width sportcoupe TJ Wrangler Technical Forum 11 10-07-2008 08:49 AM
Whats the actual width of the warn 6" and 7" trail flares? Hodakaguy TJ Wrangler Technical Forum 1 07-03-2004 09:44 AM
