ABS/ Traction Control Lights on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > ABS/ Traction Control Lights on
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREESpartan Locker Special Forum Prices Dana 30 44 60 Ford 8.8
Unread 12-10-2013, 11:20 AM   #1
Monkeybomber
I went wheeling at Rausch a week ago. While going through a water hazard, my ABS and traction control lights came on. The ABS pulsed a little, stopped, and then the light remained on. I checked the codesusing and it turned up C2116. I googled it and it means Low/ high voltage to ABS pump. Since then I've checked the fuses which are fine. From what I've been reading the only other two options I have are:
1. Pray its a bad ground error and that solves everything
2. Replace the Brake Control unit
I doubt the dealer will honor the warranty, there's clear damage to the gas tank skid and my rock rails. SO my question is, how hard is it to replace a brake control unit or a hydraulic control unit? Has anyone else dealt with this code?
Monkeybomber is offline   Reply With Quote
Unread 12-10-2013, 12:22 PM   #2
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Take it to the dealer and see what they say. All they can say is to deny the claim but worth a try. They can at least read the codes and tell you what is wrong. Might just be a wheel sensor.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
www.militaryjeepers.com lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline   Reply With Quote
Unread 12-11-2013, 12:44 AM   #3
timbotrog
2014 JK Wrangler
More than likely just a wheel speed sensor that is playing up.
timbotrog is offline   Reply With Quote
