ABS question - JeepForum.com
post #1 of 4 Old 10-03-2006, 02:15 PM Thread Starter
Existence
ABS question
Hi guys,
The one concern I have with the JK is the ABS on rough conditions. All the other cars I have driven with ABS don't brake so well on rough sand roads. Has Jeep "detuned" the ABS to perform in the rough?
There are two types of pedestrians, the quick and the dead.
Existence is offline
post #2 of 4 Old 10-03-2006, 02:30 PM
Hip2u77
Originally Posted by Existence
Hi guys,
Yeah, It allows more lock up in 4 wheel drive. All the systems (ABS, Stability, etc.) are all tuned differently for 2wd, 4wd high, and 4wd low.
Hip2u77 is offline
post #3 of 4 Old 10-03-2006, 02:58 PM
Karamba
And that is the beauty of computer controls. Knock on electronics all you want - but how else can you get one relatively simple system (ABS sensors, computer and brake actuators) performing so many duties (ABS, traction control/limited slip, stability control) in such a variety of conditions (highway, off-road).
Now all we need is to switch to electric drive - no complex transmissions, flat torque from 0 to max...
Karamba is offline
post #4 of 4 Old 10-03-2006, 04:48 PM
Hip2u77
I agree completely. An electric drive system would be waaay better than a tranny. Someone say torque??? For those that don't know. . . go look at what drives a train.
Not to mention if the gas motor was used as a generator for those electric motors. "Honey. . . power's out again." "Oh, Ok, I'll go fire up our new 2020 XYZ Wrangler and plug the house in . . ."
Hip2u77 is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
