ABS light(can you clean the sensor) also ESP/bas - JeepForum.com
post #1 of 12 Old 03-02-2010, 02:26 PM Thread Starter
jeepbronco1
I broke my axle 2 days ago and had to take the abs sensor off to change the axle.. I was a little bit rough with the sensor and probably got it dirty!! So my ABS light is now on any one know if the sensor can be cleaned.
Also is that sensor correlated to the ESP/BAS light because its on as well. My steering was jacked to the right but I straightened it out!!! any help would be appreciated thanks!!
GREENERNSHlT - Homebuilds- tube fenders, infloor storage, bumpers, cage, sliders...etc
My TRUCK/SUT Build
http://www.jeepforum.com/forum/f96/jeepbronco1-sut-build-my-mini-truck-build-aka-bobbed-top-1178064/
jeepbronco1 is offline
post #2 of 12 Old 03-02-2010, 02:39 PM
Seanie
Yes, the computer uses the ABS sensors to help with ESP. I'm not sure about BAS. How were you rough with it?When you replace the axle, you don't have to take it completely out of the hole in the back of the assembly, just enough to get it out of the way. Try gently cleaning it with some water. It gets dirty anyways, but you might have gotten something on it. Make sure the wires are connected all the way too.
Seanie is offline
post #3 of 12 Old 03-02-2010, 03:16 PM
toyota4x405
Have you straightened your steering wheel yet? If so, just unplug the negative cable for about 30 min, then after a few drives it will automatically go off. If you haven't straightened your steering wheel yet, Get under your JK, and look for your drag link. There is a collar with 2 bolts in it. Loosen them and turn the collar. You will be amazed how much a little turn on the collar will turn the steering wheel. Here is a picture. It is in the top left of the picture.
Green Jeep Club Member #254
2007 Jeep Wrangler Unlimited, Jeep Green
Originally Posted by GonzoTJ View Post
'REAL Jeepers don`t cry about other Jeepers not waving at them!'
toyota4x405 is offline
post #4 of 12 Old 03-02-2010, 03:17 PM
Seanie
Of course, you mean top right?
Seanie is offline
post #5 of 12 Old 03-02-2010, 03:24 PM
toyota4x405
Oh yea, sorry. A little too many of these already.
post #6 of 12 Old 03-02-2010, 04:21 PM Thread Starter
jeepbronco1
had to remove the entire assembly I broke inner and outer shafts and the ujoint somehow pressed out the lower ball joint.... that being said i kinda bent the sensor pulling it out... Some one asked if the steering wheel is has been corrected and it has.. I already adjusted it looks to be lined up I havent drove it more than 5 minutes...so when I go to work tomorrow will see if it goes off that being the esp/bas light.... for the abs light I might need to clean or replace it.... Ive heard of extra brake wear and such ..whats everyone think on that it doesnt pull or drive erratic at all....
My TRUCK/SUT Build
post #7 of 12 Old 03-02-2010, 08:33 PM
wTheOnew
If the system notices that something's out of wack it should just ignore it. I know when my wheel wasn't centered and the ESP/BAS light came on SOLID it shut the systems off. It's only doing something when it's blinking.
Georgia Institute
of
Technology
wTheOnew is offline
post #8 of 12 Old 03-02-2010, 08:50 PM Thread Starter
jeepbronco1
cool thanks for the info
My TRUCK/SUT Build
post #9 of 12 Old 03-02-2010, 11:52 PM
Seanie
The extra brake wear is on the rear pads and is from BAS. So, since it should be disabled, your brakes will last longer. That's a plus!
Seanie is offline
post #10 of 12 Old 03-03-2010, 06:41 AM Thread Starter
jeepbronco1
true true . thats a good way to look at it
My TRUCK/SUT Build
post #11 of 12 Old 03-03-2010, 07:23 AM
toyota4x405
Jeepbronco, it took a couple of days before mine went off. I even work 20 miles from home. So take the negative off the battery, then drive it around for a few days before you start looking at something else.
post #12 of 12 Old 03-03-2010, 09:05 AM Thread Starter
jeepbronco1
Alright I'll keep it in mind . Only thing is if the abs light us some how interconnected with the ESP/bas light , I'll need to clean or replace the sensor...
My TRUCK/SUT Build
O2 sensor/engine light question ScottioTJ TJ Wrangler Technical Forum 6 09-18-2008 06:15 PM
Check engine light and Cat sensor brhibler TJ Wrangler Technical Forum 7 07-15-2007 07:40 PM
Backup light sensor on an AX-15? Richmond88yj YJ Wrangler Technical Forum 4 08-24-2006 07:12 PM
brake light sensor jeeper-creepers TJ Wrangler Technical Forum 2 05-08-2005 06:14 PM
Changed O2 Sensor - CE Light Still On sportjeeptj99 TJ Wrangler Technical Forum 3 11-08-2003 11:18 PM
