ABS - EPS/BAS - Traction Control warning lights - JeepForum.com
post #1 of 5 Old 12-10-2010, 05:21 PM Thread Starter
TxJeepGuy2
I get the following three warning lights on my dash every morning.
After I start the Jeep it dings, the lights stay on for about a second, it dings again then the lights disappear?
It just started a week ago...any ideas? I have an appointment to take it in in the morning, but would like other opinions.
Bryan . . JKU 2007 (First Production Year)
- Jeep Green - Sahara -
3" lift - 35" Fierce Attitude M/T Tires
TxJeepGuy2 is offline
post #2 of 5 Old 12-10-2010, 06:14 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Have them check the codes if any - all my lights come on right before I start it...has been since I got it...but no dings...sounds like an error code is lurking in there somewhere.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 5 Old 12-10-2010, 08:24 PM
182329
Guest
2009 JK Wrangler
This just happened to me. It was the left (driver) front speed sensor that was malfunctioning. It was covered under warranty, which is always a good thing!
Best of luck,
Matt
182329 is offline
post #4 of 5 Old 12-21-2010, 04:40 PM Thread Starter
TxJeepGuy2
I'm still having this problem. Took it to the dealer and they said that no codes or DTC's set??? They did some flashes and a fender recall work. But the lights still come on in the morning, then it dings, and they disappear.
I was going to take it in again and ask about the speed sensor.
Anyone else have any additional suggestions???
post #5 of 5 Old 01-07-2011, 10:01 PM Thread Starter
TxJeepGuy2
Just an update...
The codes were being continuously reset because I had a bad battery. So if someone does a search and finds this, and you have the same problem...check your battery. After I replaced mine all the warning lights went away.
Airbag/ESP-BAS/Traction Control lights on JoeJoeBean JK Wrangler Technical Forum 4 04-24-2010 10:17 PM
Traction Control??? RedRider07 JK Wrangler Technical Forum 23 09-18-2009 06:55 AM
Brake and traction control/ESP lights after lift. Any suggestions?? Michele07JK JK Wrangler Technical Forum 2 07-14-2009 09:46 AM
8.8 with traction control? Fun2Jeep YJ Wrangler Technical Forum 9 03-08-2009 09:43 AM
I Need Traction Control PLUR TJ Wrangler Technical Forum 7 04-09-2002 10:51 AM
