Abs brake esp bas traction control lights all at once - JeepForum.com
post #1 of 9 Old 12-21-2012, 07:52 PM Thread Starter
rkperry1
Had some snow fall today and was going up an icy hill, stopped slid backwards some, then goosed it up the hill, wheels spun and to stop the abs worked fine. Then while spinning the brake light abs light traction control light and ESP bas light all came on at once?? Vehicle preformed the same with the lights on but now no anti lock brakes just slid. No thumping in brake pedal. Parked it turned it off and restarted it, lights were on then went off. Took it for another drive and anti lock breaks were back? What gives?
2001 Grand Cherokee 4.0 Inline. 4 inch Lift with Bilsteins, 245/75/16 BFG ATs. Westin bull bar, Halos, 12" JL Audio W7
rkperry1 is offline
post #2 of 9 Old 12-21-2012, 09:42 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Wrong forum...but my guess is that the vehicle thought it was going somewhere you weren't steering to...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 9 Old 12-21-2012, 10:02 PM Thread Starter
rkperry1
Why is it wrong forum? Is this not the jk forum? My sig must be out of date I recently got a jk
rkperry1 is offline
post #4 of 9 Old 12-22-2012, 07:59 AM Thread Starter
rkperry1
Anymore ideas? Bump.
rkperry1 is offline
post #5 of 9 Old 12-24-2012, 09:16 AM Thread Starter
rkperry1
Anyone? Have any ideas??
rkperry1 is offline
post #6 of 9 Old 12-24-2012, 08:49 PM
Rtone1583
2009 JK Wrangler
The ABS/ESP/Cruise Control systems are all related by the sensors that provide information to them. The two sensors that I know about (there may be more, not sure) are the wheel speed sensors and the steering angle sensor (in the steering column). Under normal operating conditions, the various systems use the information provided by one or more of the sensors to function correctly.
ABS and cruise rely primarily on the wheel speed sensors and the ESP relies on both wheel speed and steering angle. Under certain conditions, the information provided by the sensors is too far outside of "normal" and the computer shuts down all three systems until the problem is fixed.
From personal experience ('09 JKU by the way), I took a hard knock on a trail once. No physical damage was done but it knocked the alignment off by a considerable amount. While driving straight down the road, my steering wheel was off to the left by about 90 degrees. All things (vehicle speed and reported steering angle) being considered by the computer, it saw this as abnormal (possibly even impossible) so it assumed a fault condition was present and shut down all three systems. The following day I had an alignment done and the problem went away with no ill effects or replacement of any parts.
As far as what caused yours, it would probably be pretty much impossible to pinpoint exactly but, considering the speed at which the computer reads the information from the sensors, any instant during the slipping and sliding you described could have returned information that the computer saw as abnormal and shut all the systems down and since there was no damage to any of the systems, once you shut the Jeep off and restarted it, the computer cleared what had happened during its last run cycle.
Sorry for the long winded reply but that's the only way I could think to explain the situation.
Also, on a side note, the JK's are loaded with more sensors than any other Wrangler in production history but the engineers designed the sensor systems with a fail safe limp mode (I believe this is true for all monitored systems). Barring catastrophic failure of a monitored system, the computer will go into limp mode to allow you to get to a repair shop or back home.
Rtone1583 is offline
post #7 of 9 Old 12-28-2012, 09:25 PM Thread Starter
rkperry1
Awesome write up man, this totally makes sense, i was spinning the tires while sliding backwards and had my wheel turned. thanks a ton!
rkperry1 is offline
post #8 of 9 Old 03-18-2015, 10:52 AM
j_niko
2009 JK Wrangler
Just went through this with my 09. Replaced sensor in drivers side rear and presto, lights are out (after driving a few feet). $25.00 fix. Took about an hour only because the hole that the sensor went in was too tight and I had to sand it out and also lightly sand down sensor.
2000 - Sahara
1997 - Sahara
j_niko is offline
post #9 of 9 Old 03-18-2015, 11:35 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Read chapter #3 especially.... - the conditions you created for the computer to solve were WAYYY out of parameter (spinning fwd rolling backward steered left sliding right more than the programmers could graph into the algorithms) so it went to a fail safe (disabled) mode until ign off and back on.... the lights on and off when restarted was the test and passing brought it back on line.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
