6" Lift Kit help - JeepForum.com
post #1 of 21 Old 07-05-2013, 06:55 PM Thread Starter
warriorwrangler
6" Lift Kit help
I am considering buying the 6 inch rough country 4 door lift (link below) before I do I want to know if I would have to replace the front and rear driveshafts after I install it or if any other parts would need to be purchased in order to properly run this system. Plus any reviews of the lift would be greatly appreciated.
http://www.roughcountry.com/jeep_jk_6flex.html
warriorwrangler is offline
post #2 of 21 Old 07-05-2013, 07:14 PM
Mudzilla6661
2010 JK Wrangler
it says under the note section:
• 2012-2013 models require exhaust modification to
clear front driveshaft.
• Exhaust Extensions or Exhaust Y-pipe (4-door
ONLY) available below
• Front and rear driveshafts are Required to replace the factory limited travel shafts.
• 2 door kit also includes front and rear coil spring
spacers.
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline
post #3 of 21 Old 07-05-2013, 09:17 PM
JTPhoto
JTPhoto's Avatar
What size tire do you plan on running 44"?
There are many issues that come with this high of a lift. Number one being caster which can only be corrected by a C cut and turn or aftermarket diff housing. To do a 6" lift properly you are looking in the neighborhood of 6K.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #4 of 21 Old 07-05-2013, 09:28 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Yup, in that range $1k per inch lift for a well behaved and properly set up lift would be the norm,.....so, if the kit is short of that, it is also short of parts. A 6" lift on a JK is ridiculous in my opinion, not needed and raises the COG unnecessarily. You could run 44s at that lift, if you had a D80 f/r and full hydraulic steering lol
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 21 Old 07-05-2013, 10:15 PM
222Doc
222Doc's Avatar
If I was you I would forget this lift. JUNK no one runs a short arm 6" lift, that is LONG arm country. You do not use a drop pit arm and Lowered trackbar. You RAISE the track bar mount and FLIP the drag on JK at 3+ lifts.
Having a Zero caster wont work as said. you need a custom made front axle with a turned up pinion, so you can have some caster.
Install this kit and be ready for a match of death wobble. T
222Doc is offline
post #6 of 21 Old 07-06-2013, 02:05 AM
SubAtomicGenius
2011 JK Wrangler
Rough *** Country! That's a lot of lift on a JK, man. If you're going that way, you gotta do it right and that costs $$$$$.
SubAtomicGenius is offline
post #7 of 21 Old 07-06-2013, 07:49 AM
RockyClymer
RedRock4Wheeler
To the OP, why a 6 inch lift in the first place...that is extremely high for a JK as noted above. That was not uncommon on a TJ (with a long arm kit), but is not really necessary on a JK. On second thought, if you do it, RC is not the way to go...
NRA Life member
post #8 of 21 Old 07-06-2013, 08:28 AM
HappyTrails
HappyTrails's Avatar
warriorwrangler, all of the above posts are correct.
Listen to what they say! Very rarely will you see a JK (your model of Wrangler) on such an extreme lift height. The costs out weigh the benefits, by far.
The JK has very large wheel wells compared to previous generations of Wranglers. i.e. With only 2.5" of lift, and trimming the fenders, I am able to run 37's on mine.
I would look at a different brand of lift kit. Teraflex and Rock Krawler seem to get the most favorable feedback from users on this forum. There are others out there that are also great. Do some more research before you drop your hard earned $$$ on something this expensive and regret it.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #9 of 21 Old 07-06-2013, 11:19 AM
Mudzilla6661
2010 JK Wrangler
I just got the AEV 2.5 kit. I will let you know how it handles. I will hopefully have it installed in a couple of weeks. I tried to keep the low center of gravity.
post #10 of 21 Old 07-06-2013, 11:35 AM
LTGreek
What do you plan on overcoming with this lift kit.
Once you go long arm you can't really go back.
LTGreek is offline
post #11 of 21 Old 07-06-2013, 11:38 AM
LTGreek
Read the part about LA kits. It will help.
http://www.aev-conversions.com/educa...d-questions/92
This is a bit long, but I would read it before I do something so extreme.
http://www.aev-conversions.com/educa...d-questions/60
LTGreek is offline
post #12 of 21 Old 07-06-2013, 01:25 PM Thread Starter
warriorwrangler
I am not a big crawler or anything I am 90 percent highway. Does his change anything or would it still not perform correctly unless all the othe the modifications are done. I have 33's on a the moment but plan on going bigger down the road. Main reason I wan the lift is just I like to be high off the ground and think it looks better. I know I'm gonna get some flak for that but hey, it's just what I like. So there is no cheap way really to do a 6 inch lift that's what I am hearing? I know it is not necessary and all that but it does look great. I would think there would be a relatively inexpensive way to get this lift to work for mainly highway. Thanks so much for the info and I am going to check out those links after work LTGreek. Grandchee I look forward to your review!
post #13 of 21 Old 07-06-2013, 01:45 PM
JTPhoto
JTPhoto's Avatar
Actually it's getting it to work for highway that's the expensive and hard part. At 6" lift you will have no caster which means no road manners, handling will be atrocious and overall not very safe. Unless you spend a lot of money to have it done properly of course.
As for looks. A 6" lift will just look stupid with anything less then a 40" tire. Just think about this a minute, 37" work and look perfect with a 2.5" lift and flats or a 4" lift and stock fenders.
^^Jeff^^
JTPhoto is offline
post #14 of 21 Old 07-06-2013, 02:07 PM Thread Starter
warriorwrangler
So if I got a 2.5 inch suspension lift that could be installed and would drive safely without any other modifications? Then if I put a 2 inch body lift would it still be alright?
post #15 of 21 Old 07-06-2013, 02:12 PM
JTPhoto
JTPhoto's Avatar
Body lifts are not bad in 1" but 2" will cause its own set of problems.
^^Jeff^^
JTPhoto is offline
