5 inch backspacing with 35x12.50 - Page 2 - JeepForum.com
post #16 of 23 Old 01-18-2014, 09:11 AM
4x4Cajun
2014 JK Wrangler
Originally Posted by LuigiROX View Post
Looks really good I like how the tires do not stick out- Did you do any thing to stop the rubbing?
Thanks.
Not really, I just didn't turn the steering wheel all the way to full lock. If I did and felt the tire rubbing, I would just back off a bit. Not like I was losing any turning radius anyway.
2014 JKU Rubicon X, Billet Silver, auto trans, leather, tow package, color matched top and fenders, 430N Nav and remote start. Plus all the stuff that comes with the X package Previous: 2011 Unlimited Sahara, Nav Auto, Rusty's 3.25 Lift Kit, Rug Ridge Bumper, 18 x 9" Pro Comp 7031, 35x12.50 Nitto Trail Grapplers, XRC8 Winch, 4.88s...
4x4Cajun is offline
post #17 of 23 Old 01-29-2014, 01:43 PM
ar325
thanks for the post
ar325 is offline
post #18 of 23 Old 01-30-2014, 01:48 AM
hdtrader
Originally Posted by medijeep View Post
I too run 35x12.50x17 Nitto Trail Grapplers. The rims are 17x9 Ion Alloys with 5" BS. Had to trim the front air dam and the rear wheel well next to the rocker guards.
So anything less than 5" backspacing would make the tire stick out beyond the fender flares more? And positive offset (+10mm) would move it out even more?
hdtrader
Huntsville, Alabama...the Greater Tennessee Valley
...screw a bunch of smilies
hdtrader is offline
post #19 of 23 Old 01-30-2014, 06:59 AM
medijeep
I cant speak for the offset, but yes, less backspacing will cause your tire to stick out further.
medijeep is offline
post #20 of 23 Old 01-30-2014, 08:01 AM
SLADE
Wheel width plays a roll when going off of back spacing. A 17x9 with 5" BS will stick out 1" farther than a 17x8 with 5" BS but a 17x8" with 4" BS will be equal to the 17x9 with 5" BS.
The Offset is the Wheel mounting surface's relation to the centerline of the wheel.
Backspacing is the wheel mounting surfaces relation to the inside bead (relation/location to the vehicle).
The backspacing needed remains constant but the offset can vary from one wheel to another.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #21 of 23 Old 01-30-2014, 11:16 AM
JoonHoss
2011 JK Wrangler
Double post :
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #22 of 23 Old 01-30-2014, 11:17 AM
JoonHoss
2011 JK Wrangler
Agree (mostly) but the tire/rim calculator I use states only 1/2" increase (inside or outside) for a 1" increase in rim width for the same backspacing? If the offset is the same, then they would stick out 1" full inch
www.rimsntires.com/specspro.jsp
Hoss
JoonHoss is offline
post #23 of 23 Old 01-30-2014, 12:32 PM
SLADE
Hoss
If the backspacing remains the same from an 8" wheel to a 9" wheel, The inside bead of both wheels remains at the same location. The additional 1" will be added to the outside of the wheel. The offset of both wheels will be different though.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
