5.13 gears in a dana 30 - JeepForum.com
post #1 of 15 Old 08-04-2010, 09:02 PM Thread Starter
kking08
2010 JK Wrangler
tommorow i was planning on having my gears installed but i saw on antoher forum that you may have to change the carrier to install 5.13 gears? is this true or not?
kking08 is offline
post #2 of 15 Old 08-04-2010, 09:13 PM
nwbronco
2014 JK Wrangler
Depends on the gearing you have now.
nwbronco is offline
post #3 of 15 Old 08-04-2010, 09:16 PM Thread Starter
kking08
2010 JK Wrangler
i have 3.21
kking08 is offline
post #4 of 15 Old 08-04-2010, 09:31 PM
nwbronco
2014 JK Wrangler
You have read correctly. The break is at 3.73 Below that, you'll need a carrier swap to get to 5.13 on a dana 30.
Bob K.
nwbronco is offline
post #5 of 15 Old 08-04-2010, 09:32 PM
fan45acp
2010 JK Wrangler
Originally Posted by kking08 View Post
i have 3.21
Dana 30 front axle on a JK will have to change the carrier..yep..J.H.
fan45acp is offline
post #6 of 15 Old 08-04-2010, 09:34 PM Thread Starter
kking08
2010 JK Wrangler
where is the best place to get a carrier?
kking08 is offline
post #7 of 15 Old 08-04-2010, 09:38 PM
nwbronco
2014 JK Wrangler
Same place you got the gears.
nwbronco is offline
post #8 of 15 Old 08-04-2010, 09:39 PM
fan45acp
2010 JK Wrangler
Got mine from Jeep Parts, Jeep Accessories & Jeep Soft Tops From The Jeep Parts Experts - Quadratec
fan45acp is offline
post #9 of 15 Old 08-04-2010, 09:43 PM
Kenbo-Slice
Try East Coast Gear Supply or 4x4groupbuy.com.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #10 of 15 Old 08-04-2010, 11:01 PM
rballman
not trying to hijack, but since you are talking about 5.13s and a D30 what the hell....
Is having 5.13s in the D30 more prone to breakage than installing 4.88s?
2007 Wrangler X - Jeep Green, 4" lift, 4.88s, locked rear, custom bumper/fender/cage, rolling on 35s w/ 15s
Colorado Jeep Club member #2007
rballman is offline
post #11 of 15 Old 08-04-2010, 11:07 PM
Warlord2
Having higher gears always make them more prone to stripping, as there is less surface area for the teeth. I havent seen any reports of it so I guess it hasnt been a big problem. In early 07 they didnt even make 5.13's for d30 for this very reason.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #12 of 15 Old 08-04-2010, 11:15 PM
rballman
I guess adding a locker in the mix would just be dump then huh?
rballman is offline
post #13 of 15 Old 08-04-2010, 11:20 PM
ScotZ
American to the Bone
ScotZ's Avatar
I don't think adding a locker would hurt a thing.
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas.
- Aldous Huxley
ScotZ is offline
post #14 of 15 Old 08-04-2010, 11:39 PM
ge2
Gold Member
ge2's Avatar
I have had 5.13s in my front 30 with ARB lockers, for over two years now. I've never had a single problem with this setup.
ge2 is offline
post #15 of 15 Old 08-05-2010, 12:12 AM
Warlord2
Well adding a locker will always create less wheel slip wich will cause more stress on the gears and axle. Just depends on how heavy your foot is and the climbing you do. Ive seen people break d60 axles turning 37"s and I have seen people running 37"s using upgraded d30's have no problems for years, most always carry a spare axle though.....
Warlord2 is offline
gear question , gears , JK Wrangler , wrangler
Will spider gears from dana 30, fit in a dana 35? jeeper92 TJ Wrangler Technical Forum 5 07-31-2010 08:21 AM
dana 44 gears work on dana 35? OH92 TJ Wrangler Technical Forum 4 01-12-2010 10:23 AM
dana 30 gears from a 94 Yj gears into a 2005 tj jewem TJ Wrangler Technical Forum 5 12-16-2009 03:21 PM
Dana 35 Gears Fit Into Dana 44 Diff. _JEEP_ YJ Wrangler Technical Forum 7 10-03-2008 10:02 AM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
