4WD won't engage in 2008 6 speed manual trans. - JeepForum.com
post #1 of 13 Old 10-31-2013, 06:11 PM Thread Starter
pastime
Just happened today to daughter's jeep. Had it in 4WD earlier this summer, no problems. It's never been off road. She's had the jeep for 4 years. The shifter slips in like butter. No light either. Please tell me it's a linkage thing.
pastime is offline
post #2 of 13 Old 10-31-2013, 06:21 PM
ronjenx
ronjenx's Avatar
If the lever is floppy, one of the plastic bushings has broken, allowing the cable to disconnect from the lever in the console, or the lever on the t-case.
ronjenx is online now
post #3 of 13 Old 10-31-2013, 07:30 PM
Lynhalla
Lynhalla's Avatar
agree with ronjenx.....probably one of the plastic bushings. $3.00 at dealership. by extras. check the one in linkage by transfer case first. if its not that one you will have to remove center console. If you need to do this, easiest way i found to remove shifter knobs is to put wrench at bottom and one good whack with hammer should remove
___________________
2008 JK Unlimited X
RIPP stage 2 supercharger, R/K xfactor 5.5" long arm coilover susp., 40"x13.5" G/Y kevlars, 17x9.5 Raceline beadlocks, EVO gussets and sleeves, Yukon chromoly shafts, Artec trusses, T/W drive shafts, Eaton lockers, G2 5:13 gears, ORFAB front bumper with smittybuilt 12000 winch, Body Armor rear bumper, ORFAB roll cage, Mastercraft Baja seats, SPOD
Lynhalla is offline
post #4 of 13 Old 10-31-2013, 08:35 PM
fxbrry
Yep sounds like a broke bushing. Mine broke in my 07 leaving me stuck in 4lo. Had to crawl underneath to shift it by hand. I bought an aftermarket linkage than replaces the factory plastic one with a metal one. Now I dont have to worry about it breaking again. Cant remember the name of the company. Precision Adapters or something like that.
fxbrry is offline
post #5 of 13 Old 10-31-2013, 10:18 PM
Imped
Imped's Avatar
Get under it and put your eyes on the linkage......
You've got a better chance of figuring out the cause than we do.
OlllllllO
IndyORV
Imped is offline
post #6 of 13 Old 11-01-2013, 04:04 AM
Waltjason
2011 JK Wrangler
Or it could be the stupid little orange clip that holds the cable into the bracket under the jeep. That is the one that broke on my 08 not the ones that were previously mentioned. Easy fix and 2 bucks later. Here is a photo of it
Waltjason is offline
post #7 of 13 Old 11-01-2013, 04:05 AM
Waltjason
2011 JK Wrangler
I carry 2 extras in the glove box now due to it braking when I needed it
post #8 of 13 Old 11-01-2013, 04:38 AM
metaldemon7
That doesn't look like the plastic bushing on my 2012. I was going to post a picture of the brass one I made to replace it, but my IPhone picture are too big for this site.
metaldemon7 is offline
post #9 of 13 Old 11-01-2013, 06:14 AM Thread Starter
pastime
Thank you for your replies. Good to hear it doesn't sound like a major expense, and glad she discovered it before the snow flies. I'll let her know your replies and set her mind at ease, and encourage her to join the Jeepforum. It's always been a big help to me with my old '97's problems.
pastime is offline
post #10 of 13 Old 11-01-2013, 08:19 AM
JIMBOX
YUP, there are several points of linkage failure-
This is one and a good picture so you should have a couple extras in the glovebox along with
The nylon bushing that holds the cable conn AT THE XFER CASE SHIFT LEVER-Pt#1-68064273AA, these are about $.60 cents ea !
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #11 of 13 Old 11-01-2013, 09:16 AM
Treelover1
Okay Pastime I joined....Thank you everyone for the info, very helpful and will save me some $$$
Treelover1 is offline
post #12 of 13 Old 11-01-2013, 01:06 PM
1222
RIP John
1222's Avatar
Welcome to the forum.
Good to hear that your problem is a simple fix as far as costs goes. When you get a chance please fill out your profile, it does come in handy when others are trying to help you. Look forward to seeing you around.
1222 is offline
post #13 of 13 Old 11-02-2013, 05:46 PM Thread Starter
pastime
You guys are awesome. Thanks for the help.
pastime is offline
