4 wheel drive lever wont engage - JeepForum.com
post #1 of 16 Old 07-06-2010, 11:51 AM Thread Starter
Thx1158
2010 JK Wrangler
Well after having my 2010 Rubicon for a week, I pulled it in the yard and wanted to see how the sway bar disconnect, 4L and lockers worked. I put it in N, pulled my 4WD selector from 2 to 4HI and it moved back slightly then just went all floppy in the gate....nada....nothing....just 2WD. Called the dealer and waiting for them to get back to me to bring it back in. I hope this isnt an indicator of Quality.....overall I love the thing!
Thx1158 is offline
post #2 of 16 Old 07-06-2010, 12:01 PM
boostedboxer
2010 JK Wrangler
That's an easy fix..slide up under it and have someone move the lever..you'll see where the cable has popped off..just clip it back on
boostedboxer is offline
post #3 of 16 Old 07-06-2010, 12:07 PM Thread Starter
Thx1158
2010 JK Wrangler
Thank you! I figured it was something simple like that. I never had that happen on my other Jeeps and wasn't sure if I should mess with it or not since I only have a couple hundred miles on it.
Thx1158 is offline
post #4 of 16 Old 07-06-2010, 12:25 PM
dirtyjpwrangler
yup same thing happened to me. I bought an extra one of those clips (83 cents or something like that) incase it ever happens again.
Edit: found my old thread, complete with pictures - check it out
'08 X, Jeep Green, 6 speed, 32" BFG MT's, power options, rubi rock rails, front grab handles, soft top all year round ...oh yea and dirt.
dirtyjpwrangler is offline
post #5 of 16 Old 07-06-2010, 01:03 PM
McKBrew
JK Wrangler
Common issue. Let the dealer fix it. When mine happened they replaced the whole cable.
I have only had this happen once and have been in and out of 4WD several times since, so I wouldn't expect it to be a routine thing.
McKBrew is offline
post #6 of 16 Old 07-06-2010, 01:34 PM
daggo66
2009 JK Wrangler
First do not go directly from 4 hi to 4 lo. Second, read your owner's manual so that you know the proper procedure for engaging 4 lo. You can't just throw the lever back. The purpose of the plastic bushing is to prevent damage from people doing just that.
You need to have the transmission in neutral and the vehicle rolling slightly, no more than 2-3 mph. The lever will easily slide into 4 lo.
Tom
daggo66 is offline
post #7 of 16 Old 07-06-2010, 02:06 PM Thread Starter
Thx1158
2010 JK Wrangler
It wasn't a case of "throwing the lever back". I did read the owners manual and I was in my yard, at a full stop in neutral going from 2wd to 4WD hi. I do understand that there are no syncros and you should be rolling slow going to LO....never made it that far...LOL
Thx1158 is offline
post #8 of 16 Old 07-06-2010, 02:39 PM
xj37
2014 JK Wrangler
This is good to know that thr cable can pop off. Sort of wished they did not change it from how it was on the YJs and TJs.
xj37 is offline
post #9 of 16 Old 11-25-2013, 09:54 AM
Thomas95
Heey i got a 1998 jeep grand charoke an the lever wont move in to 4 well drive its like its stuck in 2 idk what to do
Thomas95 is offline
post #10 of 16 Old 11-25-2013, 10:09 AM
ROCKR8R
This is the JK sub section.
-Dan
ROCKR8R is offline
post #11 of 16 Old 11-25-2013, 10:29 AM
COLOUXJ
2010 JK Wrangler
You do not have to be moving. I typically am stopped when I go into 4lo. If the gears are not quite lined up I move forward or back a little bit and try again. And you cant just throw the lever back from 4hi anyway. There is a stop that prevents this.
COLOUXJ is offline
post #12 of 16 Old 11-25-2013, 11:10 AM
brianjw
The manual does recommend that you be rolling slightly to shift into 4 low. You can often shift it when stopped but its a pain l rock it around when it needs it.
brianjw is offline
post #13 of 16 Old 11-25-2013, 11:13 AM
ronjenx
ronjenx's Avatar
The plastic bushing isn't designed to prevent damage, as suggested above.
It's no more than a poorly designed bushing/retainer.
It's possible to do lots of damage before the bushing fails.
ronjenx is online now
post #14 of 16 Old 11-25-2013, 11:51 AM
1222
RIP John
1222's Avatar
Iím always stopped when I shift into 4low and have for the most part never had a problem. I can count on one hand when I ever had to move the Jeep slightly to aid in engaging low and still have a couple of fingers left. That includes my dearly departed í08 JK too.
1222 is offline
post #15 of 16 Old 11-25-2013, 12:20 PM
brianjw
Originally Posted by 1222
I’m always stopped when I shift into 4low and have for the most part never had a problem. I can count on one hand when I ever had to move the Jeep slightly to aid in engaging low and still have a couple of fingers left. That includes my dearly departed ’08 JK too.
Mine doesn't shift that well when I'm completely stopped. I'd say more often then not I have to move it slightly to shift into 4 low. Weird.
brianjw is offline
4x4 , 4 wheel drive , lever , stuck
4 wheel drive wont engage.. please help brokenwrangler YJ Wrangler Technical Forum 2 03-30-2010 10:11 PM
HELP!!! 4 Wheel Drive Wont Engage!!! Mikelstracer YJ Wrangler Technical Forum 3 01-30-2009 11:17 PM
4 Wheel low wont engage. Zombi TJ Wrangler Technical Forum 3 08-06-2008 06:18 PM
4 wheel drive wont engage cody11ca YJ Wrangler Technical Forum 2 01-24-2008 10:04 PM
4 wheel drive wont engage ex-toyota YJ Wrangler Technical Forum 7 11-10-2004 10:25 PM
