4" Rough Country Lift questions - JeepForum.com
post #1 of 5 Old 04-22-2009, 07:41 AM Thread Starter
cyberpvnk
I'm looking at buying this lift : http://www.roughcountry.com/jeep_jk_4.html
What I'm wondering is whether or not I will have any problems with the driveshafts or driveline height. I can't spend another dollar on my Jeep until next year after this lift, tires and wheels so shafts and gears are out of the question.
The other alternative is to buy this lift: http://www.roughcountry.com/jeep_jk_2perf.html
But from what I can tell I'll then need spaces putting the total cost right around the 4" (but possibly with no added stress on driveshafts)
My tire/wheel combo is going to be BFG KM2's in 35x75x16 on ProComp 7089's.
Any input is appreciated.
MyGIG REN for sale, works perfectly.
Looking for a 2DR JK softtop in good condition. Located in ILL.
cyberpvnk is offline
post #2 of 5 Old 04-22-2009, 07:53 AM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
I am lifting 4.5 inches and I will be putting in a bigger shaft. My buddy rode his around without a new shaft for a couple weeks and said it rode like crap.
You can fit those 35s on with that second lift and it will be a lot cheaper...
-Matt
mattman8706 is offline
post #3 of 5 Old 04-22-2009, 07:59 AM
N2rock
N2rock's Avatar
I have the RC 2.5" lift (very happy with it). I didn't want to go higher due to the very issues you are talking about. SO...
I'm running 35" KM2's. The tires rubbed the fenders when fully stuffed- did not do any damage, just makes a lot of noise. So I added a 2" body lift. I know people always talk down about body lifts. But it was the perfect solution for me- it raised the fenders up enough to get rid of the rubbing at full stuff. It was cheaper than a 4" lift along with all the other issues that a 4" lift can bring out.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 5 Old 04-22-2009, 08:42 AM Thread Starter
cyberpvnk
Do you find that you get high centered alot when on trails or rocks? I got high centered 3 times on the last outing and it was crappy to have to get yanked constantly. What I'm hoping is that the combination of the 2.5" lift and 3 inch larger tires will get me high enough to get over those obstacles.
It sucked watching TJ's get right over stuff because of a BB.
post #5 of 5 Old 04-22-2009, 09:59 AM
N2rock
N2rock's Avatar
getting high centered happens no matter what you have (I've seen 4" lift on 37's get high centered).
Proper spotting and the right line will prevent the majority of high centering. Do I get high centered? Of course I do. Does it bother me- not one bit. I have a strap and a winch for that very reason.
but dude- you have a 2dr JK. Bone stock you have a better breakover angle than a lot of the lifted TJ's. I think you might actually need lockers.
N2rock is offline
Got a few "rough country lift" questions... PharmD2B JK Wrangler Technical Forum 6 01-18-2010 02:28 PM
Rough Country 2.5" suspension lift...Questions for those you have installed this.. ddonjon TJ Wrangler Technical Forum 18 05-19-2009 11:06 AM
Rough country 1.25" body lift, fan shroud questions hesstondc TJ Wrangler Technical Forum 6 12-20-2008 09:22 PM
Have questions on 4" Rough country lift ZeroG TJ Wrangler Technical Forum 9 12-19-2008 03:53 PM
Rough Country 3" lift Questions Protoxis YJ Wrangler Technical Forum 7 12-13-2002 02:46 PM
