4" RC lift with control arms - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 4" RC lift with control arms
GenRight Offroad at CCOR! 706-207-4140Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaWarn, Smitybilt, Engo, Rugged Ridge Winches at CCOR
Unread 01-07-2010, 08:17 PM   #1
MilitaryJK4455
2010 JK Wrangler
4" RC lift with control arms PICS!
Ok, first, im wondering what the point is in replacing the factory control arms when the only benefit to the aftermarket ones is that they have grease fittings? is it really worth it? and second, What is the deal with the cam bolt on the front lower control arms? why cut into your frame to fit that cam bolt in when you can just use the factory hardware and it works just fine. Thats where i am right now with this lift. I got the front end taken apart and the lower control arms put in then ran outta time. But im going back at 9am tmrw to try and finish the job. I hope that i am competent enough to do this right.... Is it really as hard as im making it out to be or am i just over thinking it way too much?
MilitaryJK4455 is offline   Reply With Quote
Unread 01-07-2010, 08:38 PM   #2
MilitaryJK4455
2010 JK Wrangler
Really? nobody has any info on this?
Unread 01-07-2010, 09:06 PM   #3
wv2jeep
The holes must be ovaled out to adjust the caster angle of your front end.If you put the bolt back in the stock location after the lift your axle will have a forward tilt,causing the steering to not want to straight.Just cut them out ,you can see where they are stamped with small a die grinder cutoff wheel or nock them out with a chisel.when you pot the cam bolt that came with the kit back in adjust it so the bolt is toward the front of the jeep in the ovaled out hole. drive it and see how it drives,if you aren,t happy take it and get it aligned or adjust it try over. hope that helps.
wv2jeep is offline   Reply With Quote
Unread 01-07-2010, 10:25 PM   #4
MilitaryJK4455
2010 JK Wrangler
Nowhere near done but its a start.
From the side
A closer look, only lower control arms are on
Still needs to go on
Also needs to go on
35" BFG KM2's
17" XD spys
My AEV Procal and Jack thingy came in today too! This thing is really small!
Will try to take some more pics tomorrow since i will have more time.
Unread 01-07-2010, 10:30 PM   #5
silbotta
1991 XJ Cherokee
Awesome man
-Sil
silbotta is offline   Reply With Quote
Unread 01-07-2010, 10:33 PM   #6
MilitaryJK4455
2010 JK Wrangler
Thanks bro. Hope i can get it finished and done right tomorrow.
Unread 01-07-2010, 10:40 PM   #7
river2c
The stock control arms are not adjustable. Aftermarket front lower control arms are adjustable and used to increase castor. Cam bolts are not the preferred way of adjusting the castor. They can be knocked loose and you will lose your castor adjustment.
2012 JK Rubicon 2dr 6sp Black Forest Green
river2c is offline   Reply With Quote
Unread 01-07-2010, 10:43 PM   #8
MilitaryJK4455
2010 JK Wrangler
My aftermarket control arms arent adjustable. they are just bent tubes. other than the cam bolt they are in no way adjustable.
Unread 01-07-2010, 10:57 PM   #9
river2c
The cam bolts can be used to adjust the castor to some degree but are not the preferred method on JKs. Once you have installed the cam bolts you can't go back to a standard adjustable control arm with joints without welding up the holes.
Unread 01-08-2010, 09:01 AM   #10
Swagger
Sure you can.....just use the same cam bolt.
Swagger is offline   Reply With Quote
Unread 01-08-2010, 09:09 AM   #11
McKBrew
Militaryman4455
Dude, you need to chill. Sometimes it takes more than 20 minutes to get your answer. I used to think that there were a bunch of Jeep Gnomes in a dark room who did nothing but answer questions, but I found out they are real people.
Chances are the guy withthe best answer is on the west coast and hasn't had his morning coffee yet.
McKBrew is offline   Reply With Quote
Unread 01-08-2010, 12:06 PM   #12
JLC08JK
What was I thinking?
JLC08JK's Avatar
Originally Posted by McKBrew View Post
Militaryman4455
When I first became a member here it took me awhile to figure out why the forum got so quiet around 8pm. And every morning the list of new posts was a full page long.
Then it hit me
Jim
Jim's Jeep; THE OBSESSION LIVES ON!
Jim's JK D44 Rear Axle Build
99% of Your JK Questions will be Answered Here
JK F.A.Q./WILL IT RUB and Popular Threads
Protect Our Rights to Freedom and the Environment
Visit the EnviroBeat
JLC08JK is offline   Reply With Quote
Unread 01-08-2010, 02:58 PM   #13
Xtremjeepn
TJs had them factory, 1 ton Dodge trucks have them factory. I would say for the engineers at Chrysler they are preferred.
After market suspension companies have made us believe we need $500 of their adjustable product to move the castor 1/8". This was fine on a TJ that came with stamped steel weak control arms. On a JK there is no reason to spend all the extra cash. It's marketing hype.
You can use the cam bolts all you want and will adjust the castor as much as you need to for proper alignment.
I'm not sure why this kit comes with arms at all. The stock stuff on a JK is plenty beefy and comes with longer life bushings. Another case of marketing hype.
Cole Ford
Xtremjeepn is offline   Reply With Quote
Unread 01-08-2010, 03:01 PM   #14
MilitaryJK4455
2010 JK Wrangler
Got the front end done for the most part. Still have to reinstall the brake lines on the extended brackets and put in my dual stabilizers. Should finish up tomorrow with it all though! Update on pics
Unread 01-08-2010, 03:38 PM   #15
MilitaryJK4455
2010 JK Wrangler
Well you could get it without the arms, and i think thats what i should have done. But the new arms are greasable polyurethane bushings but other than that it does seem about the same as stock. the way i look at it. If i brake something. i still have a replacement
