4 door Rubicon rock rails modified for 2door - JeepForum.com
post #1 of 24 Old 08-23-2010, 01:57 PM Thread Starter
xj37
2014 JK Wrangler
Has anyone modified the stock 4 door Rubicon rock rails to fit a 2 door. I picked ap a pair from Craig's list and plan to modify them to fit and add a rail/step to them. The front mounts line up and it looks like I can just cut them shorter and weld the ends closed instead of the plastic end caps.
xj37 is offline
post #2 of 24 Old 08-23-2010, 02:19 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
It should work.
Take off a rear wheel and then you should be able to mount them and see for sure!
I think that the 4 door just adds an additional mount in the rear. The curve of the body will be the deciding factor.
Let us know how it goes
Jim
JLC08JK is offline
post #3 of 24 Old 08-23-2010, 02:24 PM Thread Starter
xj37
2014 JK Wrangler
I did notice the slight curve but hope that is not a problem. It would just be more work.
xj37 is offline
post #4 of 24 Old 08-23-2010, 03:31 PM
Warlord2
I just got done making my passenger rock guard there is a curve in the 2 door and Im sure the 4 door as well. The rear goes inwards an inch or two and I had to redo my rear bracket . No clue how the stock one mounts up but Im sure its doable!
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #5 of 24 Old 08-23-2010, 11:08 PM Thread Starter
xj37
2014 JK Wrangler
Was too lazy to remove the rear tire so I just took a chance and cut them. I cut them a bit long, marked them, and re-cut them at the length I wanted. They fit the curve perfectly with about 1/8" gap to the body. I will get some bolts, nuts, and some metal for the steps later this week.
xj37 is offline
post #6 of 24 Old 08-23-2010, 11:43 PM
JLC08JK
JLC08JK's Avatar
So the body mounts are in the same place?
It's good to hear that they will work for you
Jim
JLC08JK is offline
post #7 of 24 Old 08-23-2010, 11:51 PM Thread Starter
xj37
2014 JK Wrangler
Yup, they use the front 2 mounts. The back 19" does not have any support and I can't see anywhere the stock 2 door rails would have another mount. I have never looked under a 2 door rubicon to check if they have 2 or 3 mounts. They do appear to be about 3/16'" thick and pretty strong.
xj37 is offline
post #8 of 24 Old 08-24-2010, 12:20 AM
JLC08JK
JLC08JK's Avatar
The 2 door only has the 2 mounts.
Go here for the install instructions. http://www.quadratec.com/Assets/Installation/75746.pdf
Jim
JLC08JK is offline
post #9 of 24 Old 08-24-2010, 12:30 AM
tavic
2010 JK Wrangler
I'm planning to do the same thing. Definitely post some pics of the finished product!
tavic is offline
post #10 of 24 Old 08-24-2010, 01:32 AM
Warlord2
I didnt like how the rear was open like that either, I ended up drilling a hole just before the rear body mount instead of using the middle bolt like most of the rails use. Im glad it bolted up perfect, had no idea it would be that easy.
Warlord2 is offline
post #11 of 24 Old 08-24-2010, 08:40 AM Thread Starter
xj37
2014 JK Wrangler
Thanks Warlord2. Now I know they only have 2 mounts and can see the hardware I am missing. Here are a couple pics on how they fit. I will post more pics as I get more done.
xj37 is offline
post #12 of 24 Old 09-27-2010, 10:00 AM Thread Starter
xj37
2014 JK Wrangler
Here are a couple of pics of what I have done so far. Still have to make a step and weld it on.
xj37 is offline
post #13 of 24 Old 09-27-2010, 10:12 AM
DAYJ
those are lookin real nice.... look very clean
DAYJ is offline
post #14 of 24 Old 09-27-2010, 10:25 AM
Vin
You might as well trim the pinch seam while you are at it.
Vin is offline
post #15 of 24 Old 09-27-2010, 01:10 PM Thread Starter
xj37
2014 JK Wrangler
I thought about triming the pinch seem but was not sure if I really want to. I may add another bracket in the back for more support.
@djay Thanks
xj37 is offline
rubicon rock rails-mounting illini33 JK Wrangler Technical Forum 6 11-10-2009 03:54 PM
OEM Part# for Rubicon Rock Rails? dmock JK Wrangler Technical Forum 7 01-01-2009 05:17 PM
How to install factory Rubicon Rock Rails giefker TJ Wrangler Technical Forum 6 12-19-2007 06:16 AM
Rubicon Rock Rails whiteTJgirl TJ Wrangler Technical Forum 27 07-28-2006 11:52 PM
Rubicon Rock Rails ?? nspurk TJ Wrangler Technical Forum 11 04-13-2005 06:39 PM
