4.56 vs 4.88 in 2dr 6 speed JK - JeepForum.com
post #1 of 29 Old 05-15-2011, 12:17 AM Thread Starter
burr_83
2010 JK Wrangler
Does anyone have any opinions about these two gears? I will be driving the highway a lot and it's a manual. I'm leaning towards the 4.56 because I won't be doing extensive rock crawling, what say ye?
edit: Oops I keep omitting very important information. This is a 2010 2 dr jk SPORT, 6 speed manual tranny, I'm going to put a 3 inch lift and 35 inch tires on it. Stock gearing 3.21 i believe. This is why I am debating the two gears 4.56 vs 4.88
Thanks
burr_83 is offline
post #2 of 29 Old 05-15-2011, 12:22 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
No profile listed - stock tires and rims? Rubi or Sport? What is current gearing? A little more info would help. Also the FAQ section on gearing and tire selections.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 29 Old 05-15-2011, 12:39 AM
jeeperjk
2009 JK Wrangler
Yeah, and an honest gut check answer on the biggest tires you will be running in the foreseeable future.
jeeperjk is offline
post #4 of 29 Old 05-15-2011, 10:25 AM Thread Starter
burr_83
2010 JK Wrangler
Sorry guys, yes it is stock 2010 jeep jk sport, 3.21 gears then i believe.
I want to go with a 3 inch lift and 35 inch tires. I want to do it all up and do it all up the right way the first time and spend what ever money to make sure i'm not cutting corners or undermining any physics of components on the jeep (e.g. ds, yoke, etc)
burr_83 is offline
post #5 of 29 Old 05-15-2011, 10:47 AM
jeeperjk
2009 JK Wrangler
With 35's, go to at LEAST 4.88's. If you think you might go beyond 35's in the near future (your definition of near will depend on how soon you can stomach the cost of another regear), then go ahead and go for the 5.13's.
jeeperjk is offline
post #6 of 29 Old 05-15-2011, 10:58 AM Thread Starter
burr_83
2010 JK Wrangler
Wait did you see the sizing ratio chart for JK above in this thread?? It shows that FOR A MANUAL 4.88 is optimal for rock crawling but not so good for daily drives. I am driving this thing long distances that is why I am thinking 4.56 which shows to be good on trails and good on highway. Look at that chart again and then tell me if u still think that based on highway driving...
Don't get me wrong I do plan on taking this thing hard through the trails too.
burr_83 is offline
post #7 of 29 Old 05-15-2011, 11:07 AM
Imped
Imped's Avatar
The whole point of gearing properly is to keep the engine in its powerband. With the NSG370 and 35" tires, 4.88 will do that. Yes, you'll be running slightly higher RPM's at any given speed but those tires are tall/heavy and your motor isn't powerful....the lower gears are giving your motor the required leverage it needs to turn those tires without issue. The 3.8 needs to be in the 2.5-3k range to run efficiently, given the extra rotational mass and non-aerodynamic nature of the jeep. Go 4.88. The nice byproducts will be a slower crawl speed, better engine braking when going downhill, and optimized fuel mileage.
OlllllllO
IndyORV
Imped is offline
post #8 of 29 Old 05-15-2011, 11:11 AM Thread Starter
burr_83
2010 JK Wrangler
Excellent I keep going back to 4.56 and then someone will post something like you did and then persuade me back to the 4.88. Don't forget I'm in a manual 6 speed AND sometimes I drive this thing 840 miles almost all in one sitting. Do you still think that 4.88 will be not annoy me when driving this far?? It's my DD. Thanks
burr_83 is offline
post #9 of 29 Old 05-15-2011, 11:26 AM
jeeperjk
2009 JK Wrangler
You'll be fine. I'm' on 35's and 5.13's and I spin about 3k rpms at 71mph. I just turn up the radio if it's too loud.
If you're that worried about the DD factor, just do 33's on 4.56's.
jeeperjk is offline
post #10 of 29 Old 05-15-2011, 11:30 AM Thread Starter
burr_83
2010 JK Wrangler
NO WAY MAN!
35's and 4.88 sounds like a plan!
Edit: hey should I get a high angle DS for this lift?
burr_83 is offline
post #11 of 29 Old 05-15-2011, 11:42 AM
jeeperjk
2009 JK Wrangler
Just do it then!
You'll need/want beadlocks , bumpers, a winch, rock rails, a Flashpaq, skid plates...
Oh, sorry, I got carried away again.
jeeperjk is offline
post #12 of 29 Old 05-15-2011, 11:44 AM
Will16
I have a 6 speed, 35's and 4.88's. Love it! My buddy had the same thing except with 4.10's... Took about a week before he gave in and did 4.88's as well.
Will16 is offline
post #13 of 29 Old 05-15-2011, 11:54 AM Thread Starter
burr_83
2010 JK Wrangler
Just do it then!
YES YES YES YES AND MORE YES!!!! Wait what are beadlocks again lol? Which flashpaq? or is there only one?
burr_83 is offline
post #14 of 29 Old 05-15-2011, 02:45 PM
PanthersFan
You have a manual transmission, so you can test that. Just stay in 5th gear for a while on the interstate and see if the higher RPMs bother you.
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is online now
post #15 of 29 Old 05-15-2011, 02:55 PM
river2c
2014 JK Wrangler
Definitely go with the 4.88s. I have a 6 speed manual and it's the perfect ratio for 35s. For highway driving, you are in overdrive so the RPMs are fine. An AEV Procal will adjust your speedometer.
2014 JKU Copperhead
river2c is offline
Quick idle speed question - Weber Carb - Speed Screw 2.5 turns in, but 0 vacuum unlucky YJ Wrangler Technical Forum 1 04-22-2011 05:30 PM
A/C blows defroster at high speed, regular at low speed tumminello123 TJ Wrangler Technical Forum 3 07-11-2009 11:15 PM
will a 95 cherokee np231 from a 4.0 5 speed fit on my 99 wrangler sport 5 speed? subzeroedj TJ Wrangler Technical Forum 2 08-15-2008 09:35 AM
2.5 liter speed ?. Cruise speed 33'12.5" ironwoodsmith TJ Wrangler Technical Forum 10 05-31-2006 01:28 PM
Anyone kno nething about the 4 speed auto? What year start useing? bolt into 3 speed? jeepcj7 TJ Wrangler Technical Forum 6 06-23-2004 08:33 AM
