4:10 or 4:56 '13 sport - JeepForum.com
post #1 of 42 Old 03-08-2013, 01:00 PM Thread Starter
jpin321
2015 JK Wrangler
I'm stuck. I've read a ton of threads and can't make up my mind. I have the 6 speed manual and the dreaded 3:21s, I've looked at the charts. I'm running 33s and probably will for some time, eventually 35s maybe?
4:56 is much easier to come by and the thought of the power sounds nice. But I just don't know is that gonna be too much on the interstate?
Help me with my decision...... thanx
Update: I put this in the thread but thought I would update the op as well for anyone searching so you don't have to read through a bunch of posts.
So finally got my gears installed. Decided to go 4.56. Ill try and make a YouTube video of the results soon and post it here. So far I'm happy I can pull out without throttle in first. I'm turning a little higher rpm than the charts specified but that's ok. I'm running 2700rpm at 70mph. Haven't driven enough to comment on milage yet ill try and post back in a few weeks with that info as well. In hindsight anyone staying with 33s go with 4.10s they will be perfect. With that said, I don't regret my choice as of yet.
As I said here is a youtube vid of my regear on the interstate at 70...
"Anyone who has never made a mistake has never tried anything new." ~Albert Einstein
My Jeep History -- 1980 CJ5 > 2005 TJ X> 2013 JK Sport> 2015 JKU Rubicon > ?
jpin321 is offline
post #2 of 42 Old 03-08-2013, 01:59 PM
wranglerboy13
I am in the same boat. looking at the charts 4.10 is plenty gear for the 3.6 and 35's. The problem is you cannot find that ratio anywhere. Its a total drag. Regear for me in my area is $4000 so I will just be trading in the current sahara for a rubicon with factory 4.10's ! Good luck but I bet you will need to end up going 4.56. For both cost and convenience reasons.
wranglerboy13 is offline
post #3 of 42 Old 03-08-2013, 02:01 PM
TheBoss
You'll be better off with 4.10's that will get you from stock sized tires up to 35's. You will need a new carrier up front since you have 3.21's now. If you were thinking about lockers doing so at the time you re-gear would be wise since it will be torn down anyway.
TheBoss is offline
post #4 of 42 Old 03-08-2013, 02:02 PM
TheBoss
4.10's are available ,you just have to search.
TheBoss is offline
post #5 of 42 Old 03-08-2013, 02:50 PM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Alloy USA sells 4.10's for the D30 and D44 that will fit the JK.
Here are the rear ones
Here are the fronts
Don't forget that Extreme Terrain offers a discount for active Jeepforum members as well as free shipping on order of $75 or more. So, shoot me a PM and I can get you the code and answer any questions!
-Zach
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #6 of 42 Old 03-08-2013, 03:10 PM Thread Starter
jpin321
2015 JK Wrangler
So 4:56 is gonna be overkill is what your saying? I'm assuming I will be much happier coming from these dog 3:21's? Has anyone made this switch?
jpin321 is offline
post #7 of 42 Old 03-08-2013, 03:43 PM
wrestlerobx
Ok, so my situation may not be of much help so take it for what its worth.
I run 33s on an 08 unl. I had 3.73s automatic and I was advised to not go higher than 4.56 as that would get me right where I "wanted to be." However knowing that someday I may want 35s I said screw it and got 5.13s even after being advised it may or may not be a good jump for me. In the end I am very very pleased with my decision to go higher as the charts posted in here put me at borderline performance range. Even interstate driving is good for me. I can cruise WITH CRUISE CONTROL no problems
Therefore going a little high may be the way to go is all im saying.
JEEP
wrestlerobx is offline
post #8 of 42 Old 03-08-2013, 04:44 PM
TheBoss
Big difference between the 2007-2011 and the 2012-2013 as far as gearing demands.
TheBoss is offline
post #9 of 42 Old 03-08-2013, 06:31 PM Thread Starter
jpin321
2015 JK Wrangler
So my model is higher geared than the older models so I should go with the lower 4:56? Is that what your saying here?
jpin321 is offline
post #10 of 42 Old 03-08-2013, 06:33 PM
Spank
2014 JK Wrangler
No, you have more horsepower than the previous engine, so you don't need to go as low to make up for the power loss.
4.56 will be overkill for 33's, but not for 35's. 4.10 is fine for 33's and even 35's, but might be a little too high if you want to go with 37's, which will be fine if you go with 4.56.
Ultimately, you need to decide on your tire size first.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #11 of 42 Old 03-08-2013, 06:35 PM Thread Starter
jpin321
2015 JK Wrangler
Essentially it will be 33s for some time. 35s in the distant future.
jpin321 is offline
post #12 of 42 Old 03-08-2013, 06:42 PM
Spank
2014 JK Wrangler
4.10 is going to be your best bet then.
Spank is offline
post #13 of 42 Old 03-08-2013, 06:47 PM
TheBoss
You say you will be considering 35's in the future so 4.10 's would be the ideal gear for 80/20 in/off road driving for you. If were going up to a 37 or rock crawling every weekend then yoy may consider 4.57 -and up.Most 35's you would be running on the street will not measure a true 35" . They run a bit smaller 34.2-34.8 besides this is probably your DD and spinning 2400+ rpms isn't going to be a treat.
TheBoss is offline
post #14 of 42 Old 03-08-2013, 06:51 PM Thread Starter
jpin321
2015 JK Wrangler
I can see that. In the end my hope is to be able to stay in 6th on the interstate. Now I'm hitting 5th, 4th, and sometimes 3rd to pass.
jpin321 is offline
post #15 of 42 Old 03-08-2013, 06:52 PM
brianjw
I have a 2012 on 35s with stock 4.10s. It really isn't bad but I wouldn't intentionally gear it this way personally, at least for my use. What I mean is, i would want to spend $1500 to re-gear and end up with what I have currently. 4.10s and 33s would be great. But 4.56 gears with 33s would probably be over kill for this engine. So you're going to find yourself in the middle somewhere if you want to gear now and change tires way down the road. Hope I succeeded in making your decision more difficult. Lol
brianjw is offline
