37's on an Unlimited with a 4" Lift anyone? - JeepForum.com
post #1 of 9 Old 06-07-2008, 02:25 PM Thread Starter
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
Have an Unlimited X package with a 4" lift, 4.88 gears and currently running 35's. Would 37's be too much for this set up?
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline
post #2 of 9 Old 06-07-2008, 04:07 PM
scrogg
How much lift did you actually get out of the 4" lift? Supposedly you can fit 37's under a 4" lift. But if 4" is how much actual lift you got, then you would more than likely have rubbing issues. You would more than likely need to trim the pinch seam in the front of the rear wheel well, and look for rubbing elsewhere.
I am running 37" tires myself with a 4" Teraflex lift. But in the rear I have a pair of 2.5" BB spacers and in the front I have a set of ACOS Pros. So when all said and done I am about 7.25" total suspension lift. After some bumpstop tweeking I am now able to run and flex the 37" tires without any adverse rubbing issues and I haven't done any trimming.
scrogg is offline
post #3 of 9 Old 06-07-2008, 06:52 PM
Slenny
That is a sweet Jeep you have. Can you post more pics
Slenny is offline
post #4 of 9 Old 06-07-2008, 08:11 PM
BigJerm
here is my friend. Rubi on 37's with Teraflex 4" lift. He said he really got more like 4.5" out of it in the front with the AEV bumper, close to 5" in the rear.
07 Jeep Wrangler Unlimited Rubicon
BigJerm is offline
post #5 of 9 Old 06-07-2008, 08:13 PM Thread Starter
PSYCH0
PSYCH0's Avatar
2016 JK Wrangler
Very nice jeep! I have my pinch welds trimmed already and I have 2" spacers for front and rear (if needed) but I don't have adjustable control arms only adjustable track bars.
PSYCH0 is offline
post #6 of 9 Old 06-09-2008, 10:08 AM
DeepSky
Any more advice on this subject? I'm in the same boat as SickBoy and would like to know more.
Also is there a good writeup anywhere on trimming the pinch seams?
DeepSky is offline
post #7 of 9 Old 06-09-2008, 10:22 AM
BigJerm
a saw and a steady hand. Cut the pinch seam at an angle. I would suggest them giving the metal a nice coat of primer and/or paint.
BigJerm is offline
post #8 of 9 Old 06-09-2008, 10:59 AM
DeepSky
Doing so won't mess with the 'structural' integrity of that area?
Also I have an angle grinder and a dremel. Which would you recommend?
DeepSky is offline
post #9 of 9 Old 06-09-2008, 11:09 AM
VegasJeep
VegasJeep's Avatar
You will not loose the structural integrity of the area by cutting back about 1.5" at an angle. I use a angle grinder with a cutting wheel as well as a 90* grinder wih a cutting wheel to trim corners of the body and bumpers. I then will finish them off with a file if need be on plastic mostly.
VegasJeep is offline
KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift. mudb8 TJ Wrangler Technical Forum 338 01-07-2016 09:17 PM
4" lift and 37's....coming up! Tomb Raider JK Wrangler Technical Forum 29 09-23-2010 03:43 PM
Unlimited Sahara overall height after 4" lift and 37's ravenite SC JK Wrangler Technical Forum 4 09-03-2009 08:04 PM
37's with a 3" lift. *temporary* BiGEN JK Wrangler Technical Forum 18 02-21-2009 09:15 AM
Any one running 37's with RC 6" lift RubiExpressTJ TJ Wrangler Technical Forum 18 02-01-2009 11:16 AM
