35's on stock 2dr JK will fit right ?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 35's on stock 2dr JK will fit right ??
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-12-2013, 06:34 PM   #1
JeepMahn08
Just making sure....35s will fit on a stock jk or will i need spacers ?
JeepMahn08 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 06:51 PM   #2
tonka_yellow
no.. no they will not
tonka_yellow is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 06:54 PM   #3
DAYJ
spacers, or off set wheels, and no fenders
New- 2013 Commando Green Rubicon
Old-2010 Flame Red Rubicon Unlimited
Utah Jeep Crew Member #47
Cheyenne Trail Junkie
ROADS!? Where we're going, we don't need roads... (Doc)
DAYJ is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 07:28 PM   #4
MikeHoncho88
2015 JK Wrangler
There are ways to make them fit for cheap, but completely stock, no way.
Add some bumpstop extensions, or trim your fenders, or get a budget boost. Just a few cheap ways to make 35's fit.
“Race fans, I had inferred from my one trip to the Brickyard 400, fell into one of two categories: tattooed, shirtless, sewer-mouthed drunks, and their husbands.” - Steve Ruchin
MikeHoncho88 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 07:41 PM   #5
222Doc
you going to bump out 3 inches of travel? do that and you will be riding on the bumps.
or remove the plastic fenders and 1.5 spacers or no way.
You could get the metal C. high fenders but those will set you back 1K+ but no lift, still must have spacers.
You have at least 3:73 gears?
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 08:47 PM   #6
Erbo1Kanerbo
315 70 17 stock just 4.5" backspace cragars 17x8. No rubbing lock to lock turning. Its fine on the road. Offroad dont even think about it. If i hit a ditch or driveway really hard it will rub.
ZJ Build thread:
[URL="http://www.jeepforum.com/forum/f197/my-slow-zj-build-1024680/"]http://www.jeepforum.com/forum/f197/my-slow-zj-build-1024680/[/URL]
ZJ's: If you dont know what it is you cant afford it.
Erbo1Kanerbo is offline   Reply With Quote Quick reply to this message
Unread 07-12-2013, 08:48 PM   #7
MikeHoncho88
2015 JK Wrangler
32's to 35's is only 1.5" of travel. Not the best idea, but it can be done. Off road performance will suffer, but it will "probably" ride like stock on the street.
Unread 07-13-2013, 01:46 AM   #8
maniacal_rick
They absolutely will fit, you can run 37's with flat fenders and no lift.
2012 2Dr JK - Metalcloak - Currie - Prorock - ARB - Poison Spyder - RCV - Synergy - Etc...
maniacal_rick is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 02:23 AM   #9
cconn
Mud Bogger
cconn's Avatar
With stock fenders, 35's might fit, but will rub hard over any bump or ditch. I put 35's on my Jeep with a 2.5" RC budget boost, and they still rubbed going through ditches. Replaced the lift with a RK 2.5" and problem solved.
2013 Commando Sport. Rock Krawler 2.5" X-Factor lift. 35" MT/R's, 17x9 Pacer black wheels. ProRock 44 front axle. RCV shafts, ARB front and rear lockers. 4.56 gears. Coast 1310 drive shafts. TeraFlex adjustable tire carrier. AEV front bumper. Warn 9.5 CTI winch. TrekArmor seat covers, Spiderweb shade
Build Thread : http://www.jeepforum.com/forum/f96/c.../#post15031329
cconn is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 08:54 AM   #10
JeepMahn08
Righto.....im think of just going 2.5' lift and some spacers....untill i save for some dominant suspension. Also im trimming my guards and removing the lining underneath. So hopefully all that will safice. Thanks guys ! Great help ! Much love, JK love
Unread 07-13-2013, 08:56 AM   #11
JeepMahn08
Yeah man ive got a silver 2dr also, yours looks sick man ! Im just blacking out most of the little details then the stock rims untill i get more money for nicer rims !
Unread 07-13-2013, 09:15 AM   #12
Remmy18
You may need to trim the sheet metal on the rear pinch seam in the wheel well.
Remmy18 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 09:29 AM   #13
JeepMahn08
Ohh yeah ok! Ill have a look at that, never heard of this before ! Sweet as !
Unread 07-13-2013, 01:53 PM   #14
invest2m4
I have the same set-up on my 2-door, but with a 2.5" lift and I rub when backing up if I turn the wheels too far in either direction. You must have the factory "no rubbing" package! Hahaha.
invest2m4 is offline   Reply With Quote Quick reply to this message
Unread 07-13-2013, 03:32 PM   #15
Erbo1Kanerbo
Yeah i plan on getting a 2.5" coil lift soon. I had my last day of work at a Tires Plus so i figure id take advantage of my 50% off discount. I got the 315s and just for fun decided to test fit and they cleared.
ZJ Build thread:
