35's with a 2 inch lift? - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > 35's with a 2 inch lift?
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-20-2013, 01:46 PM   #31
Maertz
2009 JK Wrangler
Originally Posted by wilson1010 View Post
So, are you saying the OP should buy some 35's and see how they fit?
I'm confident the 33's will fit. And, I was responding to someone who said that 35 is the standard for a 2" lift, which, of course, it is not.
Never said that, but hell if they want they can run 37s on no lift. Its up to the op on what they want to do. Im saying there should be no standard. 35s on 2" sounds great to me.
Wishing I Wasn't Part Of The 'JK' Crowd...
[URL="http://www.jeepforum.com/forum/f96/maertzs-half-build-thread-1857370/"]A JK On Junkyard 60s[/URL]
Maertz is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 01:51 PM   #32
wilson1010
Originally Posted by Maertz View Post
Never said that, but hell if he wants they can run 37s on no lift. Its up to the op on what they want to do. Im saying there should be no standard. 35s on 2" sounds great to me.
I'm guessing that the OP did not want to go cutting on his relatively new Wrangler. And, he may want the wheels to turn far enough to get into that good parking space at the mall. So, although he needs no approval, it may not fulfill his needs.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 01:55 PM   #33
Maertz
2009 JK Wrangler
I'm guessing that the OP did not want to go cutting on his relatively new Wrangler. And, he may want the wheels to turn far enough to get into that good parking space at the mall. So, although he has our approval (he can put 44's on there without my OK) to put the tire of his choice, it may not fulfill his needs.
Theres your issue, your guessing. Personally i like cutting my wrangler. Im saying its possible, but id say he gets the issues or is at least looking into them. Not sure why steering is suddenly an issue... As it was from the beginning, and as i said its up to them on how much they want to do.... Sorry if i pissed in your cornflakes
Unread 12-20-2013, 02:04 PM   #34
JustJeepin85
Lol, lots to figure out Wilson... metal cloak has a setup where you can run37s on stock jk suspension... the jk already sits higher then any previous jeep with proper bs and some minor trimming 35s are a sinch...
That said op, do what you think is best for your uses your the one living with it and driving it daily. What your asking has lots of options, in the end if you don't like it redo it at a cost...
JustJeepin85 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 02:09 PM   #35
wilson1010
Haha! I like you guys over here. Good sense of humor.
The OP did say his rig would not see much trail use, so I still think (as I did in post #2) the 33's are his ticket.
Unread 12-20-2013, 02:16 PM   #36
Maertz
2009 JK Wrangler
I never said what was or wasnt his ticket.....
Unread 12-20-2013, 03:02 PM   #37
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
I'd skip 33's. There is barely any difference between those and the stockers. If you already have a 2" lift installed, go with 35's. You will not need to trim the pinch seam. May need spacers ($100/pair) if you use the stock wheels, however.
And yes, 2-2.5" is standard lift on a JK for 35's. The JK wheel wells are much larger than previous Wranglers.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 03:38 PM   #38
zjilla
33's by 12.50 are what goes with a 2 inch lift. Even then, you gotta check you bump stops.
because you said so......
to the OP:im running 35s with about 1.5" lift
they fit even without my flat fenders. just had to trim the rear pinch seam or it rubbed offroad. on road it was fine
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
www.annirlane.blogspot.com
October 2013 JK of the month
My Slowly but surely JK build thread:
http://www.jeepforum.com/forum/f96/s...hread-1562595/
zjilla is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 08:56 PM   #39
robski85
Here's my 2 door w/35's. I have a 2" in the front 1" in the rear spacers and 18/59 springs. Running smittybilt fenders as well. No rubbing at full flex and disco'd... Barely....
robski85 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 09:02 PM   #40
Jrdchiropractic
2009 JK Wrangler
Mom sounds cool
(0|||||||0)
09 JK w/ a winch and duratracs
Just enough to get through most of the time,
get stuck sometimes, and still get home
Jrdchiropractic is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 12:58 AM   #41
MountainMan864
Don't forget to strengthen up that front axle before adding the 35s. Also another reason to go stay with 33s.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 10:29 AM   #42
JTPhoto
Lol. I'll bet if you take a poll there are more JKs on this board with 35s and no strengthened diff housing then there are 33s. And 0 issues. That has become an old wives tale in the JK world unless you are doing extreme wheeling.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline   Reply With Quote Quick reply to this message
Unread 12-21-2013, 10:42 AM   #43
JustJeepin85
The jk front axle is superior to prior years but aside from that this is going to be a mall crawler, isn't much of a need to to strengthen the axle. It'll be an open diff on pavement, may as well be a soccer moms 2wd jk... wait they did make those...
Unread 12-22-2013, 09:21 AM   #44
Jared89
2011 JK Wrangler
^ +1 I dont know why eveyone thinks the new dana 30 cant handle 35's.
2011 rubi- 2.5" teraflex-35" nitto trail grapplers on xd addicts-shrockworks stubby bumper-20" light bar-TF proformance rotor kit - aluminum Psc crusher flares-
Jared89 is offline   Reply With Quote Quick reply to this message
Unread 12-22-2013, 09:37 AM   #45
JTPhoto
The Dana 30 and Dana 44 fronts are the same strength. C's and tubes are exactly the same. Difference is a smaller carrier and axles on the 30. Only extreme wheelers with 37" + tires are gonna bend it. However, you're likely to snap axle shafts before that.
^^Jeff^^
nitto , tire choice , wrangler
