35" Tires won't work even with a 2.5" lift? - JeepForum.com
post #1 of 30 Old 04-17-2014, 06:00 AM Thread Starter
joecatch
Thinking about what I want to do with my new 2012 2 door JK in the next year or two. Someday I would like 35" tires, a 2.5" lift and 4.88 gears. I want to do in stages so I can afford it!
I don't have alot of plans to go crazy off roading, just would like to increase the height 2.5". But my dealer is telling me that with a Teleraflex 2.5" lift that 35" tires will rub, even with after market wheels with a smaller offset. Is it true that with 2.5" lift and different wheels, I will still get rubbing?
If so then I assume the biggest tires that would fit a 2.5" lift are 33'? And if I go with 33" tires I assume I can use the stock 17" wheels. I believe the stock tires are 32", so I don't know what one inch would buy me. Thanks for your input.
JC
P.S. If I go with a 2.5" lift and 33" tires, will it look funny? I mean, will there be too much space around the tires to make it look strange?
joecatch is offline
post #2 of 30 Old 04-17-2014, 06:03 AM
HappyTrails
HappyTrails's Avatar
Your dealer must only sell Jeeps, not drive them.
You can fit 35's on a JK w/o any lift.
Most people run 2.5" of lift with 35's. (I run 37's w/flat fenders on 2.5" of lift.)
If your wheels are at 4.5" of offset (stock wheels are ~6.75" of offset), you should have no problem with rubbing.
You will be fine with the Teraflex 2.5" lift and 35's. Don't listen to the dealer.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #3 of 30 Old 04-17-2014, 06:05 AM
MrSmiley
You can do 35s and 2.5in of lift. You might just have to run extended bumpstops as to not rub the fenders while completly flexed out. Also, you would need tires that have at least 4.5in of backspacing as to not rub the sway bar while turning. But if you want 35s go for it hopefully someone else will post up pictures of that set up in here considering how common of a setup it is.
Edit: Happy beat me too it, guess i dont type fast enough.
MrSmiley is offline
post #4 of 30 Old 04-17-2014, 06:43 AM
paul84043
Sounds like your salesman doesn't quite know what he's talking about.. He's not completely wrong, but he's not right either.
The biggest issue is that 35's will most likely not work on stock wheels depending on the tire.
35's will fit on STOCK suspension, though they will rub and I wouldn't recommend it as a permanent setup. I know because I ran them for a month or so before installing my lift on my 2012 JKU. But I had also replaced my wheels with some that have 4.5" of backspace.
Your stock wheel is going to be the immediate issue. Even with 33's...they might contact the control arm a bit.
Even just a Budget Boost and cut the pinch seams and you'll be in good shape on 35's.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #5 of 30 Old 04-17-2014, 06:45 AM
SLADE
You need 2" - 2.5" extended bump stops to clear 35's with stock flares and no body lift.
You only need enough suspension lift to cover the needed bump stop.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #6 of 30 Old 04-17-2014, 06:45 AM
cyberpyrot
33's but as you can see I have loads of room. I do have the teraflex 2.5
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #7 of 30 Old 04-17-2014, 07:35 AM
ROCKR8R
I agree with all these guys. I typically don't believe anything a car salesman says. There is high turn over in car sales, they move on to different dealerships and really don't know about what they are selling because they aren't anywhere long enough.
I had the same 2.5" TF lift and 35's. No problem.
-Dan
ROCKR8R is offline
post #8 of 30 Old 04-17-2014, 07:52 AM
duneslider
A lot of this depends on the circumstances.
Lift height really has less to do with fitting and not rubbing than other things.
I have 35's and when fully flexed I just kiss the stock fenders, not bad enough to worry about it. However, I rub the front bumper hard. In fact there is a little lip of metal on the inside of the bumper that took some chunks out of my tire. I need to grind that edge off. The back also kisses the fenders but not enough to cause damage. I also have teraflex sway bar disconnects and when stuffed and turned I rub those really hard. It looks like synergy's bracket will solve some of the issues with the terflex part.
I think if you are going to run 35's with a 2.5" lift you probably should be running 3" bump stops and that would probably alleviate most of the rubbing issues. I have 2.5" bumps and I am planning to try some 3" bumps in the front to see what a difference it makes. However, if you don't plan on disconnecting and you are just doing easy dirt roads and easy trails then 35's and a 2.5" lift won't be a problem. I only notice issues when I am disconnected and flexed.
I have noticed some of the higher end lift companies generally recommend 3" bump stops with 35" tires, regardless of the lift height. Some even sell adjustable bump stops to dial in exactly the amount of bump stop that you need.
Even with 35's and fully stuffed I do not contact the pinch weld or the rubicon sliders.
duneslider is offline
post #9 of 30 Old 04-17-2014, 10:54 AM Thread Starter
joecatch
It is not the jeep dealer salesman talking to me but the service guy who supposedly does these alot. But anyway I don't know of anyone in the Hudson Valley here besides the Jeep dealer who does this kind of work.
I decided to go with the Teraflex 2.5" budget boost (with new shocks) for $510 from Quadratec. Tires and wheels will come next year. I figure by then the stock tires which have 24,000 miles on them will be ready to be replaced anyway.
But if anyone can give me some advice on finding a local 4x4 guy, that would be nice. I Googled that and found nothing where I live!
JC
joecatch is offline
post #10 of 30 Old 04-17-2014, 12:47 PM Thread Starter
joecatch
Found a local Jeep guy who installs mods and repairs, JVS, in New Windsor, NY. So when I order my kit I can bring it to him if I can't do it.
JC
joecatch is offline
post #11 of 30 Old 04-17-2014, 01:08 PM
duneslider
Too bad you can't find someone to help you, it really is a pretty easy install. I did my first one (same lift) with just the occasional help of my wife. Lots of good writeups of that particular lift. If you were closer I would lend a hand. These JK's are one of the easier things I have worked on.
post #12 of 30 Old 04-17-2014, 02:08 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
geez - my brother bought an 11 sport, used certified - from a dealer.
Had 35X12.5 on the stock 17" wheels...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #13 of 30 Old 04-17-2014, 02:28 PM
davyboyXJ
2.5 rc lift (coils and shocks) with 35s and flat flares
davyboyXJ is offline
post #14 of 30 Old 04-17-2014, 02:50 PM
SubAtomicGenius
2011 JK Wrangler
2.5" will fit 35s easy. To go with 33"s or 35"s is personal preference. Each has their benefits and drawbacks. If you get new tires, make sure the stock rim width is suitable for the brand of tire that you choose.
PS. Your salesman is a moron.
SubAtomicGenius is offline
post #15 of 30 Old 04-17-2014, 03:44 PM Thread Starter
joecatch
Very nice!
joecatch is offline
