35" Tires on stock Rubi wheels? - JeepForum.com
post #1 of 13 Old 12-18-2006, 09:07 AM Thread Starter
Roadtrip
Junior Member
Roadtrip's Avatar
Anyone running 35" tires on stock rubi rims? If so do you have pics and were there any width issues?
I am torn between:
Toyo MT (worried about the width)
Procomp Extreme MT (not available yet)
Nitto Mud Grapplers (have never seen a set on 17" rims let alone in person)
Mickey Thompson Baja Claw Radial (So far, the likely choice)
Roadtrip is offline
post #2 of 13 Old 12-18-2006, 09:32 AM
JacksJeep
You will need a wider rim that comes stock on the Wrangler to stay within the rim dimensions specified by the tire manufacturers for 35 inch tires.
JacksJeep is offline
post #3 of 13 Old 12-18-2006, 10:11 AM
UTAH
UTAH's Avatar
Well... maybe. It depends on how you'll be using your Jeep.
If you're going to be airing down off-road, you'll keep the bead seated better by "overtiring." And, as an added benefit, you'll better protect those nice Ruby rims.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #4 of 13 Old 12-18-2006, 10:54 AM
ColoradoTJ
ColoradoTJ's Avatar
Your stock rim will be fine, you may however encounter clearance issues due to the lack of backspacing on your factory rims. May you should look into some wheel spacers. Also, in your list of tires I noticed that Goodyear MT/R's where not listed as an option. In my experience they are an excellent tire, you should give them a look.
Clint
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline
post #5 of 13 Old 12-18-2006, 11:27 AM Thread Starter
Roadtrip
Junior Member
Roadtrip's Avatar
Thanks I am glad to here this and yep, I bought Spidertrax 1.25" backspacers and a Fulltraction Lift 3" (waiting for it since Nov).
I had those Goodyear's on my Ford and would love to get them again but they don't come in 35" x 12.5" x 17". unless it's a new size that I wasn't aware of.
Roadtrip is offline
post #6 of 13 Old 12-18-2006, 11:42 AM Thread Starter
Roadtrip
Junior Member
Roadtrip's Avatar
Bill
If I don't air down will it affect the bead, or will it be more susceptable to punctures?
Roadtrip is offline
post #7 of 13 Old 12-18-2006, 11:52 AM
Karamba
Look at the wheels and tires on this description. Guy who made the conversion posts here - you may ask him how does it work.
Karamba is offline
post #8 of 13 Old 12-18-2006, 12:05 PM Thread Starter
Roadtrip
Junior Member
Roadtrip's Avatar
What a small world I was just cruising his site... Man he has some wicked custom Jeep's.
Roadtrip is offline
post #9 of 13 Old 12-18-2006, 12:10 PM
UTAH
UTAH's Avatar
Good question. The bead is best kept seated by maintaining pressure. So, it's happiest to stay with higher psi. You just don't want to go low enough where the tire gets sloppy and pops the bead Ė particularly if itís loaded from the side. Some guys here run really low pressures (e.g., 10 psi and lower) off-road and you probably won't be down that low. I don't go lower than 15 psi only because I don't like to worry about it.
Besides, airing down is mainly to increase traction - it increases the contact patch while also allowing the tire to wrap around and grab things better. If you're getting enough traction you need for the type of off-road driving you do, there's no need to risk going too low on air pressure.
I donít know whether airing down increases the chance of punctures or not. I'll bet some of our died-in-the-wool rock crawlers will chime in with an answer on that one.
Bill
'97 Land Rover D90
'03 TJ Rubicon
UTAH is offline
post #10 of 13 Old 12-19-2006, 01:26 PM
canucksjk
Tried to put 35 Ta ko's with a 2.5 teraflex budget boost. The backs fit but the fronts will rub alot
Decided to put 33's and wait for new Rims to clear the front sway bar.
Perry
canucksjk is offline
post #11 of 13 Old 12-19-2006, 02:15 PM
mackssrt
Is it rubbing on the fender or what? TeraFlex makes that wheel spacer. I'm curious as I'm working on a deal right now for an unlimited and was planning on the 2.5 budget with 35's on the rubicon rims but had heard the spacers are needed to get the backspacing to fit. Thanks.
Craig
1999 Jeep Grand Cherokee
2005 Ram srt10 regular cab
2005 Dodge Magnum RT AWD
mackssrt is offline
post #12 of 13 Old 12-21-2006, 08:03 AM
canucksjk
No fender rub. It Rubs on the Sway bar with the 35's and no backspacing. I did not want to run back spacers so I opted for the 33's for the winter and will install 35's Mud terrains with correct wheeels in the spring
I'll have pics up today for ya,
P
post #13 of 13 Old 12-21-2006, 04:41 PM
CheEng1
First post here.
Does it rub when wheeling only or on pavement?
CheEng1 is offline
Tires on stock Rubi wheels with 4" lift greenrover TJ Wrangler Technical Forum 11 12-18-2009 06:29 PM
RE/Mopar 4.5 long arm kit and stock Rubi Wheels/tires steelefx4 JK Wrangler Technical Forum 3 07-27-2009 09:06 AM
33 x 11 MTRs (or other tires) on stock Rubi wheels IndyJpr JK Wrangler Technical Forum 0 08-09-2007 07:30 PM
35'' Tires On Stock Rubi Wheels? 05fulltraction TJ Wrangler Technical Forum 9 11-16-2006 05:26 AM
Anyone selling Rubi Stock Wheels/Tires? FourbyFour TJ Wrangler Technical Forum 6 09-02-2006 11:28 PM
