35" tires with front dana 35 - JeepForum.com
post #1 of 9 Old 08-01-2011, 11:20 AM Thread Starter
justjeepinorfw
I'm wanting to get a 2012 Wrangler Unlimited. And want to add a lift and 35" Duratracks. I would only go wheeling maybe twice a year, mostly trails with some rock (Natural Bridge, KY; Livingston, KY; etc.). I've love a rubicon but hate the extra $5k expense for just a few rides a year!
My question is... how many of you out there with 35s and front dana 35s have had problems?
-O|||||||O- Have fun out there. Jeep
justjeepinorfw is offline
post #2 of 9 Old 08-01-2011, 11:21 AM
JerzeyBoyWJ
2003 WJ
its a dana 30...not 35
2003 4.0l wj- 6.5 inch IRO+.75 spacers. 4.56 gears. dana44a swap. 35x12.50 MTR Kevlars
http://www.jeepforum.com/forum/f197/jerzeyboy-03-wj-build-1155698/
JerzeyBoyWJ is offline
post #3 of 9 Old 08-01-2011, 11:26 AM
JCJeep97
I run 35's on a front 30 just fine. I wheel carefully though, which you should anyway Keep in mind that many here will advocate upgraded steering and brakes along with you move to 35's.
Also, if you have 3.07 gears, you will need to regear before mounting them. I have 3.73's in the diffs and it is on the very bottom edge of "tolerable."
JCJeep97 is offline
post #4 of 9 Old 08-01-2011, 11:36 AM
greg123168
mine has never had problems
greg123168 is offline
post #5 of 9 Old 08-01-2011, 12:23 PM
RCS
I've been told as long as u put the C gussets on & maybe the sleeves, the 30's ok with 35's
RCS is offline
post #6 of 9 Old 08-01-2011, 01:33 PM
dsjk
2011 JK Wrangler
I ran those Duratracs for over a year with hard wheeling on a dana 30 and it held up just fine even without gussets and sleeves.
Originally Posted by voodooJK View Post
Something you said after the fact exposed that part of me... like a catholic school girl normally would.
dsjk is offline
post #7 of 9 Old 08-01-2011, 01:33 PM
tavic
2010 JK Wrangler
The smallest ratio the JK has available is 3:21s. The wider wheel stance compared the TJ Gen I Dana 30 axle has given the axle tubes a better chance of bending even though the Gen II Dana 30 has thick tube walls.
To sum it up, if you're just doing light wheeling such as fireroads you'll be ok. But if your into beating on your rig pretty good I highly recommend Gusseting and Sleeving with 35s.
tavic is offline
post #8 of 9 Old 08-01-2011, 02:02 PM Thread Starter
justjeepinorfw
Thanks guys!
post #9 of 9 Old 08-01-2011, 02:08 PM
McKBrew
JK Wrangler
There are more than a couple Unlimiteds that have had damaged housings possible caused by larger tires and the smaller front axle (With both Dana 30's and 44's). My housing broke with 33's and a low speed hill climb where I spun the front tire a few times.
At a minimum I'd consider sleeving and gusseting the axle to provide that extra bit of protection. The Dana 44 for the JK's is the same tube thickness as a Dana 30, so upgrading to a Rubicon still isn't going do much for you.
It's a rare situation to experience a breakage, but IMO better to spend a few hundred bucks upgrading the axles just to be sure than experiencing a break on the trail.
McKBrew is offline
35" tires on a dana 35? dlloydj TJ Wrangler Technical Forum 32 01-05-2011 01:10 AM
Adding 33" tires and locker to Dana 35 axle; What lift for 33" tires tjg1491625 TJ Wrangler Technical Forum 16 07-13-2010 10:08 AM
31" tires on dana 30/35 JRocker TJ Wrangler Technical Forum 7 09-17-2007 07:47 PM
33" Tires on a Dana 30/35 Stryker187 TJ Wrangler Technical Forum 16 09-19-2006 12:09 PM
Dana 35 and 35" tires jeeps-r-us TJ Wrangler Technical Forum 31 05-20-2006 01:34 PM
