35's with a 2 inch lift? - JeepForum.com
post #1 of 55 Old 12-18-2013, 01:20 PM Thread Starter
SamMLB33
So I'm new to the forum and I've got a question that's been on my mind for a month or so now. I grew up in a Jeep family, and My mom decided to give me her 2008 JK Unlimited X when she got a new vehicle. She had put a 2' lift on it with 32 inch Terra Grapplers on 17 inch Pacer wheels. Everything else is stock. I was wondering if I could maybe fit a set of 35x12.5-17 Nitto Mud Grapplers on there. Would I have to do anything else in order to do that? Would 33's be easier?
SamMLB33 is offline
post #2 of 55 Old 12-18-2013, 02:18 PM
wilson1010
33's by 12.50 are what goes with a 2 inch lift. Even then, you gotta check you bump stops.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #3 of 55 Old 12-18-2013, 02:29 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to JK Forum.
Wheelin98TJ is online now
post #4 of 55 Old 12-18-2013, 02:58 PM
Maertz
2009 JK Wrangler
Ive seen 35s on no lift. Depend on your fenders, if you cut them youll have no problems assuming your pacer rims have a decent backspacing. As said you will need to adjust your bumps.
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #5 of 55 Old 12-18-2013, 06:11 PM
awinski
like stated by maertz, 35s fit, do a lil pinch seam trimming, and bump stops need to be longer so when stuffed the tire doesn't come in contact with the body. btw even 37s fit.
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #6 of 55 Old 12-18-2013, 07:22 PM Thread Starter
SamMLB33
So a little trimming and the bump stops should do the trick?
Also, thanks for the replies. I didn't think anyone would help. Haha.
SamMLB33 is offline
post #7 of 55 Old 12-18-2013, 07:32 PM
awinski
yep just a lil trimming, i went for the full trim to fit 37s, it's basically like getting free flat fenders, and i personally like that on the trail they flex when up against something
awinski is offline
post #8 of 55 Old 12-18-2013, 07:34 PM
MikeHoncho88
2015 JK Wrangler
Longer bumpstops will be needed. You will have very little uptravel on the suspension.
You may have to do some trimming up front as well but that depends on the actual tire size and wheel offset.
MikeHoncho88 is offline
post #9 of 55 Old 12-18-2013, 09:34 PM
suicideking
Lots of people do 2.5" with 35's. 2" can definitely work. May also want to trim the fenders if they rub.
Definitely not a problem on road, will rub off road especially if you disconnect the sway bar.
suicideking is offline
post #10 of 55 Old 12-18-2013, 09:50 PM
41jeep41
2010 JK Wrangler
I am running a 2.5" lift and 35's, on mine the only thing that has been changed is the pinch weld has been trimmed to stop the tire from being cut under flex and I also have highline fenders.
41jeep41 is offline
post #11 of 55 Old 12-19-2013, 10:13 AM Thread Starter
SamMLB33
That was another question I had. Will I have to do any chopping or replacing with the front bumper?
SamMLB33 is offline
post #12 of 55 Old 12-19-2013, 10:38 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Aside from physical size, what gears do you have in your rig? You'll notice a definite change in the way the Jeep drives when you jump from 32's to 35's. If you have the towing package (4.10) or the optional 3.73's you may be ok. But if you have the 3.21's you might start considering gearing.
Just something else to think about besides trimming/fenders/bump stops/other physical clearance limitations. Let me know if you have any other quesitons!
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #13 of 55 Old 12-19-2013, 11:00 AM Thread Starter
SamMLB33
-Ryan
I've got 3.73, so I figured I'd be alright with that. Thanks for bringing that up!
SamMLB33 is offline
post #14 of 55 Old 12-19-2013, 11:17 AM
41jeep41
2010 JK Wrangler
I do not run a factory front bumper on mine but I do have the factory rear bumper. The rear bumper clears my tires without a single issue. I do believe that on the front of yours with the stock bumper and 35s that you will have to remove/trim the plastic airdam that is below your sway bar.
41jeep41 is offline
post #15 of 55 Old 12-19-2013, 11:30 AM
98GAXJ
I know a guy who wheeled on 37's & no lift but he didn't have any up travel.
98GAXJ is offline
nitto , tire choice , wrangler
