35" MTRs mounted!!!! Pics inside - JeepForum.com
post #1 of 36 Old 05-15-2012, 11:39 AM Thread Starter
zjilla
60pounds (98 dollars) later i got them mounted and balanced. Funny thing was that the mechanic here in the UK never encountered tires this big and had to make sure they fit on his balancer machine before he took on the job. I didn't really want to use weights on the outside but i was scared the 15" rims would rub with sticky inside weights. Anyway: i played it safe and no issues with rubbing on the calipers. The rear tires are about an inch from rubbing my rockers but it should help when i take the old 33" tires and wheels out of the back of the jeep. The difference in a 15" wheel and 17" wheel is night and day with the way the jeeps rides (a lot smoother). I`m sure the extra two inches of rubber helps too.The MTRs grip the road way better than the mickey thompson MTZs. A lil quieter too...but only time and wear will tell with noise. Still waiting on my 5th tire and wheel to come in the mail so i don't look so much like a poser driving down the road with a stock sized spare on the lift gate.
15" MB72s
35X12.5R15 GY MTRs
on a 2.5 inch skyjacker lift (which i need to address this front sagging problem next)
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #2 of 36 Old 05-15-2012, 11:41 AM
DesertSage
Looking good, bro
DesertSage is offline
post #3 of 36 Old 05-15-2012, 11:54 AM
GauchoMark
2011 JK Wrangler
I like it. Are you lifted? That rear tire looks pretty close to your flares! Do you have any rubbing?
NM the lifting thing. I just saw the 2.5" Skyjacker below the pic.
GauchoMark is offline
post #4 of 36 Old 05-15-2012, 12:00 PM
goldenglory18
They look great, but that's with a lift???? I would seriously think about sending these pictures to Skyjacker.
This is what my 35" MT/R's look like on a 2.5" lifted Unlimited...
Gone and I dont miss it at all - 2011 JKU
goldenglory18 is offline
post #5 of 36 Old 05-15-2012, 12:18 PM
222Doc
222Doc's Avatar
even with the lift he has I would cut that pinch seam and what looks like a, Rubi rocker rail? The better way to do this way better is to have adjustible rear CA's set it back about 5/8, no need to cut the Jeep wont hit the rear bumper. Also making the rear back is always a good thing anyway. Stufs in like a glove. On road you may not flex it enough to hit the pinch. I would check it have a spotter. With the set up you have (i have about the same rims and K's on a 012 Rubi) off road you can run as low as 9psi-12 for most on road is about 27-28 If you are on say a 15x8 35"x12.5x15 at least start at 27. Tire max is 35 but thats on a 9-10 rim and the weight of a light truck.
Great tire can be harsh/noise for a DD. Did you gear for these?
222Doc is online now
post #6 of 36 Old 05-15-2012, 12:18 PM
paul84043
Those tires look awesome. I wish they were practical for my type of driving, but alas, I need to concentrate on 80% highway..... Guess I'll have to settle for pics of other peoples.
paul84043 is offline
post #7 of 36 Old 05-15-2012, 01:05 PM Thread Starter
zjilla
wow i see the difference. I bought the jeep with the lift on it. it has the spacers on top of the coils and skyjacker shocks and it sat a tad bit higher than stock jeeps but it sits way lower than yours. my jeep only has 22k miles on it so it couldn't be from springs sagging. my front bumper weighs down the front but the rear looks like it has way less clearance than yours. does skyjacker sell any spacer lifts smaller than 2-2.5"?
zjilla is offline
post #8 of 36 Old 05-15-2012, 01:11 PM
J33p3r5
2011 JK Wrangler
very nice, Jeep. Wonderful to see Jeeps from the other side of the pond!
J33p3r5 is offline
post #9 of 36 Old 05-15-2012, 01:43 PM Thread Starter
zjilla
its from your side of the pond. I shipped it to the UK when i got station here from Missouri.
zjilla is offline
post #10 of 36 Old 05-15-2012, 02:02 PM
goldenglory18
Take a picture of the spacers for us.
My guess is that you have a leveling kit (or similar minimal spacers) and skyjacker shocks. Not a "true" lift like I bet the dealer/seller led you to believe.
post #11 of 36 Old 05-15-2012, 02:21 PM
RebelDiety
Good looking
RebelDiety is offline
post #12 of 36 Old 05-15-2012, 02:55 PM
tomsryt
I'm sure it blows the minds of 90% of the people in UK/Europe to see a flagrant gas guzzling American all purpose road machine.
I occasionally see a Trabant in the Czech Republic, (2 cycle), and it's rare to see a US brand.
Do you have a diesel engine?
Oops, didn't see the part about you shipping it.
tomsryt is offline
post #13 of 36 Old 05-15-2012, 03:09 PM
JKilla
My husband (Zjilla) just measured the spacers and they are 2". Im thinking we need to add
JKilla is offline
post #14 of 36 Old 05-15-2012, 04:02 PM
TripleJeep_99
Looks good....but time for a coil spring lift or add some flat fenders as you got some serious sagging!!! The stock springs are horrible and sag like an 80 year old's titties when you add bumpers & winch.
08 Sahara Van/6spd - 3:73 gearing/35x12.50R17 STT's/LoD bumpers/OME HD Coilspring lift/AEV snorkel & AFe drop-in filter/Warn XD9000i/Superchips
TripleJeep_99 is offline
post #15 of 36 Old 05-15-2012, 04:46 PM
goldenglory18
Yup, time for a legitimate lift.
Dealer "fixed" a leak. Now it's worse. Pics inside Dronac JK Wrangler Technical Forum 4 03-16-2010 02:43 PM
load range in tires (c vs e) 37" MTRS or 40" MTRS SomerJeep TJ Wrangler Technical Forum 10 04-08-2007 01:20 AM
Flex Pics of 2" Pro Comp...Also a bit of a concern when flexed..Look inside... 97grntjsahara TJ Wrangler Technical Forum 5 05-27-2004 04:17 PM
KC Slim Lites, mounted / installed "pics" T0DD YJ Wrangler Technical Forum 12 10-15-2003 06:00 PM
Any Pics of Tj w/31 mtrs + 2"coil spcr lift? Shawno TJ Wrangler Technical Forum 29 09-27-2002 05:47 PM
