35" KM2 0n stock 17" Moab-Spare mount - JeepForum.com
post #1 of 9 Old 07-20-2010, 04:56 PM Thread Starter
fan45acp
2010 JK Wrangler
OK guys I need a little help here.Can I temporially mount a 35/12.50R/17
BFG KM2 to the spare tire mount on a stock 17" Moab rim.Thanks in advance for your help.
fan45acp is offline
post #2 of 9 Old 07-20-2010, 05:17 PM
MilitaryJK4455
2010 JK Wrangler
yes but you will need an extender... Please search next time.
MilitaryJK4455 is offline
post #3 of 9 Old 07-20-2010, 05:20 PM Thread Starter
fan45acp
2010 JK Wrangler
Military, I'm searching right NOW! Are you talking about using a spacer?
fan45acp is offline
post #4 of 9 Old 07-20-2010, 05:30 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
An 1" or 1" wheel spacer will work or you can get an extension from R.C. or some of the other companys.
If you want a single spacer you'll have to buy two.
I have a set that I'm not using, If you want just one send a PM I'll make you a good deal.
Jim
JLC08JK is offline
post #5 of 9 Old 07-20-2010, 06:03 PM
MilitaryJK4455
2010 JK Wrangler
And I have the extender that will do the same
post #6 of 9 Old 07-20-2010, 07:44 PM Thread Starter
fan45acp
2010 JK Wrangler
Hey guys thanks,I'll let you all know what I'm going to do after I get them mounted tommorrow.Again Thanks.
fan45acp is offline
post #7 of 9 Old 07-21-2010, 08:30 PM
09GRNJK
I have mine mounted with no spacer. The 3rd Brake light is bent a little bit. But I have been running it for approx. 5 months with no issue.
09GRNJK is offline
post #8 of 9 Old 07-21-2010, 10:04 PM
BenderX
2010 JK Wrangler
I have a 35 mounted without any extra hardware. Sits perfectly snug in the stock Rubicon rear bumper cutout.
BenderX is offline
post #9 of 9 Old 07-22-2010, 09:25 AM
McKBrew
JK Wrangler
Depends on the tire and rim combo.
You can buy a spacer to push it out, or an extender, etc...
You might also want to consider some extended tire stops (the round rubber things on the tailgate). Daystar makes those.
McKBrew is offline
35" tire , JK Wrangler , stock tire carrier , tire carrier , wrangler
Recommendations on 35" spare tire mount? DocJake JK Wrangler Technical Forum 58 05-13-2010 02:20 AM
Will a 33"x 13.5" spare fit on the factory mount? Mudtastic YJ Wrangler Technical Forum 10 08-03-2009 10:35 PM
33-35" spare tire mount 89_Jeeper YJ Wrangler Technical Forum 4 01-26-2008 09:54 PM
7" stock wheel and 31" spare tire govols TJ Wrangler Technical Forum 7 06-21-2007 09:11 AM
33" spare tire mount '88YJ YJ Wrangler Technical Forum 15 03-10-2006 02:21 PM
