34" Wheels on 2014 JK Unlimited - What lift? - JeepForum.com
post #1 of 14 Old 02-12-2014, 04:29 PM Thread Starter
MoparManJK
2014 JK Wrangler
I just purchased the Nitto 285/75/17 (34" wheels) and wanted to know what size lift I can get away with. I was looking at the 2.5" Rubicon Express lift with springs and mono shocks. Think it comes out to about $700.00. Would that be enough lift for 34" wheels? Moderate off roading, mostly trails/mud not so much with the rock crawling. Appreciate the help!
MoparManJK is offline
post #2 of 14 Old 02-12-2014, 04:40 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Welcome to the forum.....for your answer, check the FAQ section first, then get back here...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 14 Old 02-12-2014, 04:52 PM
715racing
Before you do anything else...wheels are the hard thingies that bolt to the vehicle. TIRES are the soft rubbery thingies that go around the wheels. Very few wheel thingies are 34"...many, many tire thingies are 34".
Welcome to the forum! Hope to be able to follow another neat Jeep build.
P-51 Dolly...when you are out of Mustangs, you are out of fighters.
715racing is offline
post #4 of 14 Old 02-12-2014, 05:08 PM Thread Starter
MoparManJK
2014 JK Wrangler
Haha I stand corrected! So to clarify, I have 17" wheels and 34" tires. I found quite a few threads on 33" and 35", but nothing on 34" tires. I'm looking to keep the cost of the lift under 1k and wanted to find out from you seasoned folk if the 2.5" Rubi lift would suffice.
post #5 of 14 Old 02-12-2014, 05:48 PM
JoonHoss
2011 JK Wrangler
2.5" is plenty of lift, and can accommodate a 35" tire, with bumpstops properly adjusted.
33's on properly backspace wheels can fit stock; 34's only require 1/2" more clearance (basically).
I have 2.5" lift up front, and 2" out back, and room enough for 35's (but prefer my 33's)
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #6 of 14 Old 02-12-2014, 05:56 PM
222Doc
222Doc's Avatar
so then the FAQ's are wrong and should be removed then, yes??? or something is BS.
222Doc is online now
post #7 of 14 Old 02-12-2014, 06:15 PM
1222
RIP John
1222's Avatar
Here’s the link to the “JK F.A.Q. - Frequently Asked Questions / Will It Rub and Links to Popular Threads!”; lots of useful info.
(2011-2016)
1222 is offline
post #8 of 14 Old 02-12-2014, 06:29 PM Thread Starter
MoparManJK
2014 JK Wrangler
Great! Thanks for the info and links.
post #9 of 14 Old 02-12-2014, 07:12 PM
JoonHoss
2011 JK Wrangler
No, it's good general info to start, but it simply doesn't give you every option, including actual tire size, or aftermarket wheels with a different backspacing than stock.
Hoss
post #10 of 14 Old 02-12-2014, 08:33 PM
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
I have the 34" toyo at2's on my stock wheels. I am installing a 2.5" spring with rs9000 adj shocks. I picked up a full set or RE adj arms as well. I keep telling myself I want a expedition type ride rather than a crawler like my LJ. But I don't know how long Ill be able to keep 37"+ out of my head.
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline
post #11 of 14 Old 02-13-2014, 01:43 AM
zjilla
flat fenders should do the trick.
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #12 of 14 Old 02-13-2014, 08:57 AM
RedRubiconLJ
2015 JK Wrangler
yup.especially if ya don't want to lift right away. I've been torn on doing that vs the springs. I opted for the springs cuz I don't like my front end sag
SOLD 2013 JKUR
2004 TJ sold
1993 YJ sold
post #13 of 14 Old 02-13-2014, 09:25 AM
zjilla
dont hate on the sag
zjilla is offline
post #14 of 14 Old 02-13-2014, 11:36 AM
taoshum
as an aside... how do you like the tires?
Geezer from NM
"Wisdom isn't cheap; we pay for it with pain
taoshum is offline
