33s or 35s with 4.10s? opinions please! - Page 3 - JeepForum.com
post #31 of 74 Old 07-23-2010, 03:17 PM
JIMBOX
Heh Heh, no doubt--what tire pressure do you use when you go off-road??
Originally Posted by MilitaryJK4455 View Post
I agree that he could wheel it like it is... But that is not what he asked... And Big 33's are pretty much super swampers and they still only usually measure a true 33 or a 34 maybe depending on which model you get... My 35's measure a 34 and 1/2 on a 9 inch rim...
If you drop to 12/14psi, then your 35's are at about 32", right??, why'd you get 35's ??
My 33\", which are actually 33.2 at 30psi and they're not swampers !!
I'm just commenting on the statement that, "you NEED 35's/34's to go wheeling, thats BS !!
We all wheel in different environments and with a jeep, you don't "NEED" anymore than you want, for YOUR JEEP--RIGHT !!
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now
post #32 of 74 Old 07-23-2010, 03:28 PM
MilitaryJK4455
2010 JK Wrangler
JIMBO
Absolutely correct... I agree with you on that subject... I never said that you NEED 35's to wheel... And the reason you need gears has more to do than just the diameter of you tire its also the weight of the tire... My tire does not get lighter when I lower the pressure, it simply gets a flat spot on the bottom of it... And by your terms... all you should ever need to be satisfied is a 31 because whenever YOU lower the pressure in YOUR tire according to YOU its only about a 31... SO why even go to 33's?
I told him that if he gets 33's then he will regret it if he is thinking about 35's... I know this from personal experience... You are arguing with numbers and MANY peoples personal experiences... Why dont you just give it up
MilitaryJK4455 is offline
post #33 of 74 Old 07-23-2010, 03:43 PM
JIMBOX
All right, this topic is dead
QUOTE=MilitaryJK4455;9839321]Absolutely correct... I agree with you on that subject... I never said that you NEED 35's to wheel... And the reason you need gears has more to do than just the diameter of you tire its also the weight of the tire... My tire does not get lighter when I lower the pressure, it simply gets a flat spot on the bottom of it... And by your terms... all you should ever need to be satisfied is a 31 because whenever YOU lower the pressure in YOUR tire according to YOU its only about a 31... SO why even go to 33's?
I told him that if he gets 33's then he will regret it if he is thinking about 35's... I know this from personal experience... You are arguing with numbers and MANY peoples personal experiences... Why dont you just give it up [/QUOTE]
This is my last entry on this thread, I will just suffer thru my miserable trailer/off-road travel with these poor little 33" tires
JIMBO
Yellow Jeep No. 683
post #34 of 74 Old 07-23-2010, 03:56 PM
Crasher
One more observation, as if one was needed. When measuring the true usefull diameter of a tire, you just need to know the distance from the ground up to the center of the hub and multiply by 2. No matter what the tire says, that is the rolling diameter the drivetrain is supporting. My 305X75R17s calculate to 34.2", but at 28 psi it measures 16" from the ground up to the hub. 16X2=32"s. That is what I put in with my superchip and the speedo is right on with the GPS. If I carried more pressure, my rolling diameter would increase. I'm guessing that the stock BFG MTs that are supposed to be 32", measure 15" from the ground to the hub carring 35psi. I know this to be true, because I gained 1" of clearance when I put the MTRs on.
Just another observation.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
post #35 of 74 Old 07-23-2010, 04:05 PM
MilitaryJK4455
2010 JK Wrangler
JIMBO[/QUOTE]
I am not saying that anything is wrong with 33's... If that is all that you want/need then that is a fine size tire that is cheap and plenty capable...If that was all that he wanted/needed then he would not ask about a 35 though... He more than likely asked because he wants a 35 but was worried that it would cause problems with his current gear set up... But it will not... That is all that was meant by my entire argument, for some reason, it took you the entire thread to figure that out (or give up) or either you just like seeing how many different ways Ill explain a simple concept if you continue to disagree with me...
post #36 of 74 Old 07-23-2010, 07:37 PM
drowe303
bushwacker flares..
drowe303 is offline
post #37 of 74 Old 07-23-2010, 08:16 PM Thread Starter
andrew c
I was thinking the same thing... Why not say a mustang or a camaro or even a WRX... i mean come on... A HONDA!??!
I actually just traded up a 2002 z28 6 speed for this jeep. haha loved the speed, but i just missed 4wd too much!
andrew c is offline
post #38 of 74 Old 07-24-2010, 08:19 AM
MilitaryJK4455
2010 JK Wrangler
Originally Posted by drowe303 View Post
bushwacker flares..
Yeah... The way I see it... You can either fill up the fender wells with rubber or plastic.... All ya'll know my stance on flares...
post #39 of 74 Old 07-24-2010, 03:30 PM
fan45acp
2010 JK Wrangler
Originally Posted by andrew c View Post
Thanks guys! im going to 4 wheel parts to pick up a 2.5 procomp coil, and 35 inch km2s!
Andrew,I just put a set of KM2's on.They are @34 1/4" (35/12.50/17) and I love em.Your 4.10's should be ok.Good Luck and have fun in the High Country.
fan45acp is offline
post #40 of 74 Old 07-24-2010, 03:32 PM
fan45acp
2010 JK Wrangler
Military, I just knew that Jeep got cleaned up now and then.NICE RIG bud...J.H...
fan45acp is offline
post #41 of 74 Old 07-24-2010, 05:04 PM
MilitaryJK4455
2010 JK Wrangler
Actually, its a lot dirtier than you can tell in that pic but I do like it clean just as much as I like it dirty
post #42 of 74 Old 07-24-2010, 06:39 PM Thread Starter
andrew c
thanks! i sure will! i am picking them up at 2 on monday after i pick someone up from dallas. i leave for Colorado in 2 weeks...I CANNOT WAIT!
andrew c is offline
post #43 of 74 Old 07-25-2010, 03:01 PM
Rustler55
I had 3.21 gears in mine and I really like the 4.88 regar granny 1st gear lots of power and I can cruise 70mph @ 2700 rpm...........Tires measure 34.25 Goodyear 35 12.50 15
My 3.21 were dogs with the 34" tires.
I will sleep when I am dead.
Rustler55 is offline
post #44 of 74 Old 07-25-2010, 03:04 PM
panman
I just bought a 2007 2 dr x, 6 speed, with 4.10 gears. i am buying a lift and gears this weekend and i need some opinions. i am keeping the 4.10s, so should i get 33s, or 35s? i am going to be driving it from Tx to Colorado to drive trails for a week and im concerned about power and mpg with 35s. im a college student and cant waste money experimenting! opinions PLEASE!
33's for 4.10s are max tire size.
panman is offline
post #45 of 74 Old 07-25-2010, 03:06 PM
panman
33's are the max for the gears. 35's would be like filling the cab with everything possible for weight.
panman is offline
33" tires , 35" tires , 4.10 gears , gear tire question , JK Wrangler , wrangler
what should i do need opinions ert9218 TJ Wrangler Technical Forum 2 11-05-2009 11:53 AM
Opinions please! 350 into a YJ YJyoungster YJ Wrangler Technical Forum 38 05-19-2009 12:38 PM
opinions please flys_yj YJ Wrangler Technical Forum 14 04-09-2008 07:37 AM
I need some opinions here Marine_Mike YJ Wrangler Technical Forum 7 03-21-2008 03:26 PM
need some opinions! 86comanche TJ Wrangler Technical Forum 1 12-08-2004 10:52 AM
